> Hello,
> Why is it that when Subset_End_Frame and Final_Frame are used in an ini file,
> the built in variable 'final_frame' takes on the value of Subset_End_Frame
> instead of Final_Frame?
The same happens with the initial frame; which is very useful for things
like this:
#if(frame_number = initial_frame)
//do some one-time calculation and save it to data.inc
#else
#include "data.inc"
If initial_frame was set to the Initial_Frame setting, and you render a
subset with a different Subset_Start_Frame, the one-time calculation
would never be done.
