I want to create a number of variants of a scene, where each variant is defined
by a number. No problem so far; I can run an animation loop and use the clock
variable as an index to a lookup table. But I also want to use the numbers in
the output filenames. So when I have
#declare VariantIDs = array[5] { 13, 21, 34, 55, 89 }
I would like to name the output files
Is this possible? In the documentation I only find the automatic numbering, like
Or did I overlook something?
TIA
Steven
en ce 2008/04/15 15:37 :) ->
> TIA
> Steven
You can't set the image's names directly from the scene file.
What you can do, is to use an INI file that will call your scene and set the
name of the images, as it was done before the animation feature got the
autonumbering.
'No, `Eureka' is Greek for `This bath is too hot.'' -- Dr. Who
> autonumbering.
Merci, Alain.
But the next question of course is: how was it done before the animation feature
got the autonumbering? :-)
en ce 2008/04/16 07:44 :) ->
>> autonumbering.
> Merci, Alain.
I don't have an old enough version to test.
You know you've been raytracing too long when you look at waterfalls, dust,
rain, snow, etc, and think: "If only I had a fractalized, vector based
particle-system modeler with collision detection!"
The animation feature always had autonumbering. Before that, there was
no animation feature.
en ce 2008/04/16 14:06 :) ->
>> animation feature
OK. Before the animation you needed to use a script that did everything the
animation feature does automaticaly now, including the naming.
Presbyterian: This shit was bound to happen.
