POV-Ray : Newsgroups : povray.general : intersection test Server Time
19 May 2025 08:16:56 EDT (-0400)
  intersection test (Message 1 to 10 of 10)
Subject: intersection test
Date: 12 Apr 2008 15:45:00
Message: <web.48011111c11fed705245d3740@news.povray.org>
Can I use the "intersection" operator as intersection test, i.e. check wether
the result is empty?
TIA
Steven
Subject: Re: intersection test
Date: 12 Apr 2008 16:11:55
Message: <4801178b@news.povray.org>
  No.
Date: 13 Apr 2008 18:24:49
Message: <48028831$1@news.povray.org>
>> wether
>  No.
Intersection is a keyword for a CSG object in POV.
This should work though...
#include "rand.inc
#macro collision(A B rez)
   #local result = false;
   #if (((min_extent(A).x > max_extent(B).x ) |
         (min_extent(B).x > max_extent(A).x ) |
         (min_extent(A).y > max_extent(B).y ) |
         (min_extent(B).y > max_extent(A).y ) |
         (min_extent(A).z > max_extent(B).z ) |
         (min_extent(B).z > max_extent(A).z ))=false)
      #local AB = intersection{object{A} object{B}};
      #local Mn = min_extent(AB);
      #local Mx = max_extent(AB);
      #local S1 = seed(1);
      #local Pt = VRand_In_Box(Mn, Mx, S1);
      #local cnt = 0;
      #while ((result = false) & (cnt < rez))
         #if (inside(AB, Pt))
            #local result = true;
         #local cnt = cnt + 1;
   result
Date: 14 Apr 2008 06:52:17
Message: <48033760@news.povray.org>
  If the intersection of the objects is extremely small, there's a big
chance that your macro won't detect it.
>       #local cnt = 0;
  Why the first Pt? It's not used anywhere.
Date: 14 Apr 2008 21:29:26
Message: <480404f6$1@news.povray.org>
The odds are in favor of finding a collision if it's there.
The bounding of the intersection object is used so
the volume tested can be small even though the primary
objects are large. Additionally in cases where the ratio
of intersection volume to testing volume is small the
repeated test should still find most of the collisions.
For example, if a rez of 1000 is used, then a collision
that has a ratio of 1% in the testing volume will be
detected with (1-(0.99^1000)) ~ 99.995% accuracy.
There also will never be a false collision, and if a
collision is missed it's likely to be in a "forgiving"
location where the viewer is likely to not be able to
see it.
>>       #local cnt = 0;
Hmm, yeah, you're right, not sure what I was thinking,
it's been a while since I wrote it.
Date: 14 Apr 2008 22:07:59
Message: <48040dff@news.povray.org>
> objects are large.
How do you think POV-Ray would calculate the bounding of an
intersection? If the primary objects are big, chances are the bounding
object for the intersection will be a lot bigger than it should be.
> see it.
Well, it's *random*. Given a sphere (which takes more than half its
bounding box), it's absolutely possible it will hit everywhere *but* the
sphere :)
But if you make it clear that your code isn't deterministic, seems good
enough.
Date: 15 Apr 2008 12:45:00
Message: <web.4804da9e32e497e5245d3740@news.povray.org>
Thanks, Tim.
I realize your method doesn't guarantee to always detect a non-empty
intersection, but the odds are good, and for my current project seems to work
well.
Date: 16 Apr 2008 06:29:50
Message: <4805d51e$1@news.povray.org>
> How do you think POV-Ray would calculate the bounding of an intersection?
> If the primary objects are big, chances are the bounding object for the
The bounding of the intersection is the intersection of the
bounding boxes. So for example if you have two spheres...
#declare A = sphere {<0,0,0>,1};
#declare B = sphere {<1.99,0,0>,1};
Then the bounding of the intersection would be
box {<0.99,-1,-1>,<1,1,1>} which has a volume of
0.04, compared to the bounding of the sphere which
has a volume of 8, and the bounding of the union
which is 15.96, the volume of the intersection is
(pi/12)*(4*R+d)*(2R-d)^2 =
(0.261)*(5.99)*(0.0001) = 0.000157
so the ratio of the intersection is 0.00157/0.04 = 0.39%
the accuracy at 1000 tests will be (1-(0.9961^1000)) ~
98%, but at 2000 tests it will be 99.95% accurate.
> sphere :)
The worst case scenario for this macro is long narrow cylinders that
aren't parallel to any axis, in those cases the bounding fails to conform
well to the object. For normal objects the chance of this failing is like
the chance of flipping a coin a thousand times and having it always
come up tails.
> enough.
Since the random generator in POV is deterministic, this will fail
in deterministic ways... it won't introduce jittered movment to an
animation for example, but yeah, it can fail to detect collisions if
the rez used is low. Something like 30000 is enough to detect hard
cases, but it's quite slow for that... I was thinking about re-writing
it to use trace, that might improve the accuracy a bit.
Date: 16 Apr 2008 12:03:11
Message: <4806233f@news.povray.org>
en ce 2008/04/16 06:29 :)   ->
You pick a random point on one of the faces of the bounding box and shoot toward
the oposite face. Using the smalest face will probably help.
You exit on the first non-zero normal.
Advantage of using trace:
Advantage: you no longer test points but lines. One test will check millons of
points.
Stay out of my head, its a bad neighborhood.
Date: 16 Apr 2008 22:59:45
Message: <4806bd21$1@news.povray.org>
> toward the oposite face. Using the smalest face will probably help.
Yeah, but then you might miss long skinny things aligned that way sometimes.
Yeah, the old one was early exit too, the poorest performance is for non-
collisions since all the checks have to run.
> millons of points.
Yeah, after a few tests it feels a bit more accurate, this should
be able to find collisions with low volume that have a larger surface
area easier too. I'm not sure what the math for figuring out the
failure rate is for this method, theoretically there are an infinite
number of points on a line segment, I guess in practice you could
count them as being points 0.001 apart.
      #local cnt = 0;
         #local Norm = <0,0,0>;
         #local Hit = trace(AB,<Pt.x,Mn.y-0.1,Pt.z>,y,Norm);
         #if (vlength(Norm)!=0)
         #else
            #local Hit = trace(AB,<Mn.x-0.1,Pt.y,Pt.z>,x,Norm);
            #else
               #local Hit = trace(AB,<Pt.x,Pt.y,Mn.z-0.1,>,z,Norm);
   (result)
