POV-Ray : Newsgroups : povray.general : quicker render alternatives to povray Server Time
23 May 2025 15:08:34 EDT (-0400)
  quicker render alternatives to povray (Message 1 to 10 of 50)
Subject: quicker render alternatives to povray
Date: 16 Mar 2008 15:20:00
Message: <web.47dd807ac23a6d959eba08c0@news.povray.org>
I use povray to render molecules from co-ordinate files. Unfortunately the
specifics of my problem demand that I write my own parser (rather than use VMD
, rasmol etc.) that parses from my coordinates to a .pov.
My scene is basically nothing more than a large number of spheres(of different
sizes and colors) Povray works great for me for rendering an excellent high
quality final output.
Unfortunately there are parts in my development cycle where I need a faster
render. Low quality acceptable. Are there any options people would recommend?
I dont even need the full ammunition of a raytracer. But something that could
act on  a similar-to-povray file would be ideal. (or something that a povray
...pov file could easily be parsed into)
The idea is to allow users to adjust molecular positions in an editor (vi or
emacs) and have a second window display these changes dynamically. So I need
something fast. I know I can probably code it in OpenGL or something but I was
just checking if there are other easier alternatives?
Any suggestions are, of course, greatly appreciated!
-Rahul
Subject: Re: quicker render alternatives to povray
Date: 16 Mar 2008 15:23:37
Message: <47dd81c9$1@news.povray.org>
If you do it in OpenGL, and you want speed, you need to bother with
drawing only visible spheres, etc. yourself.
Did you try +q2 on POV-Ray?
Date: 16 Mar 2008 16:10:00
Message: <web.47dd8b8e72535d7259eba08c0@news.povray.org>
Exactly! That's the part I wanted to avoid. So to put it better: I was
interested if there was any command line tool that did hidden surface removal
etc. but not with the photo-realistic precision of povray (or ray tracers in
general)
I really don't need light-sources, shades, textures etc. in my intermediate
renders. Although I do have them in the final povray raytraced output which
looks great!
My current command line looks something like this.
"povray  +Irpn.pov +W600 +H600 Antialias=true +FP -GA +Oother_file"
I just add a +Q2 at the end? I tried but didn't seem to change much.
-Rahul
Date: 16 Mar 2008 16:19:02
Message: <47dd8ec6$1@news.povray.org>
Disables shadows, for a start.
You could also try +Q0 but then you won't even get lighting (spheres
will look like flat circles).
Date: 16 Mar 2008 16:21:37
Message: <47dd8f61$1@news.povray.org>
Rahul napsal(a):
> general)
> looks great!
> -Rahul
turn off the antialiasing. You don't need it and it can slow things down
quite a lot in some cases.
You know you've been raytracing too long when...
you start thinking up your own "You know you've been raytracing too long
when..." sigs (I did).
-Johnny D
Date: 16 Mar 2008 18:10:00
Message: <web.47dda81572535d7259eba08c0@news.povray.org>
I tried turning it off. Acceptable quality degradation. But not too much
improvement in render times.
Downgrading till +Q2 causes no discernible quality loss. But no performance gain
either.
Are there any other non-raytraced analogs of povray? Something that has a
primitive scene-definition language but no cpu-hogging raytraced details?
-Rahul
Date: 16 Mar 2008 18:55:00
Message: <web.47ddb31e72535d727a680aea0@news.povray.org>
> either.
hmm, if no AA nor +Q2 change much I imagine there must be a humongous amount of
spheres around...
Probably won't do much either, but you could try halving the resolution as well.
 And grouping the spheres in unions, as a last resource...
I don't think there's anything much faster or memory-efficient for this kind of
problem (huge amounts of spheres) than a raytracer.
Date: 16 Mar 2008 20:23:38
Message: <47ddc81a$1@news.povray.org>
Scanline rendering could actually be *slower* if the bottleneck is in
the sheer number of objects.
Ouch.
William Tracy
    In the land of the blind, the autopilot is king.
     -- Kim Stanley Robinson, _Red Mars_
Date: 17 Mar 2008 04:24:16
Message: <47de38c0$1@news.povray.org>
"Rahul" <nomail@nomail> wrote in message
news:web.47dd8b8e72535d7259eba08c0@news.povray.org...
> removal
> in
> general)
> intermediate
> which
> looks great!
Might I suggest you post an example POV file to povray.binaries.scene-files
so we can all have a play and see if we can speed it up.
Where is the most time spent? In the parsing or the rendering? How long does
the final render take, and how long do you want (would you accept) the
intermediat renders to take?
My suggestions are:
    1)    Group logical blocks of spheres together in unions or merges to
improve the bounding box detection
    2)    Don't put the whole texture in every sphere. #declare or #local
the textures at the top and use texture{T_MyTexture} in each sphere.
    3)    Remove the textures (especially any reflection/refraction) in the
intermediate renders. Thiscould be done my #declaring simple textures as per
suggestion 2 or by surrounfing all texture{} blocks with a #if()#end block.
    4)    I would suggest writing your output to an INC file instead of
rewriting the POV file each time you do a new molecule. That way you can
preserve any changes in the POV file with only the geometry of the object
changing.
Rarius
Date: 17 Mar 2008 06:10:35
Message: <47de51ab$1@news.povray.org>
> different
> high
> faster
> recommend?
Write it in OpenGL or DirectX.  A modern machine should be able to draw
10000 spheres in real-time (ie at least 30fps), with per-pixel specular and
diffuse lighting.
