POV-Ray : Newsgroups : povray.general : Feature request: speed of light Server Time
19 May 2025 11:02:02 EDT (-0400)
  Feature request: speed of light (Message 1 to 7 of 7)
Subject: Feature request: speed of light
Date: 28 Feb 2008 18:50:00
Message: <web.47c747c81018a7fdd57dbd0@news.povray.org>
I would like to request the addition of speed of the light rays. This would
allow one to explore things like doppler effects, as well as the difference
between the geometric versus apparent positions of the sun, moon and planets.
Subject: Re: Feature request: speed of light
Date: 28 Feb 2008 20:57:51
Message: <47c7669f@news.povray.org>
You'd get interesting effects with long renders; light that had reached
the camera plane on line 1 would be different from the light that
reaches line 200, four hours later...
*snicker*
Tim Cook
http://empyrean.digitalartsuk.com
Version: 3.12
Date: 28 Feb 2008 22:11:03
Message: <47c777c7$1@news.povray.org>
Do the math, and someone will be happy to code it.
John
Date: 28 Feb 2008 23:30:01
Message: <web.47c789b87e6719d3d94a0a670@news.povray.org>
whew!  for a moment I thought it was about render speed...
Date: 29 Feb 2008 03:20:45
Message: <47c7c05d@news.povray.org>
  Would require using GR equations, which means curved rays. Not gonna
happen.
Date: 29 Feb 2008 04:27:34
Message: <47c7d006$1@news.povray.org>
web.47c747c81018a7fdd57dbd0@news.povray.org...
> difference
> planets.
I'm not sure if this is what you need, but there have been a few
"relativistic" POV-Ray versions in the past :
http://physics.syr.edu/courses/PHY312.03Spring/mcdonald/phy312/index.html
http://www.fourmilab.ch/cship/cship.html
http://www.lehrer-online.de/povray-relativistisch.php
G.
http://www.oyonale.com
- Graphic experiments
- POV-Ray, Cinema 4D and Poser computer images
- Posters
Date: 29 Feb 2008 06:43:32
Message: <47c7efe4$1@news.povray.org>
If you're going to worry about light speeds you also have to worry about
astronomical distances.  POVRay doesn't work well with astronomical
distances because of assumptions in the renderer that errors are within
a certain fixed tolerance.
As well, if you're going to explore doppler effects, you need to change
the RGB color model with a spectrum model which is more realistic.  A
spectrum model contains a collection of brightnesses of many different
wavelengths of light.  Objects would absorb some wavelengths and reflect
others.  When you get the final wavelength value, you would convert the
spectrum to RGB to render the pixel.
How do you red-shift an RGB color?  Red shifting a light spectrum is clear.
David Buck
