POV-Ray : Newsgroups : povray.general : Simulating a *visible* laser beam Server Time
19 May 2025 10:59:14 EDT (-0400)
  Simulating a *visible* laser beam (Message 1 to 7 of 7)
Subject: Simulating a *visible* laser beam
Date: 10 Feb 2008 01:55:00
Message: <web.47ae9f01e7ebe4ed140a26e60@news.povray.org>
I'm an Optics guy. I have a hard time getting a "visible" light beam from
POVRay.
I would like to generate a beam (e.g. spot light source) which can be visible
and directed towards an object or lens.
I have enabled photons mapping and stuff for the light source and objects, but
the beam is only visible when it hits the object. It's not visible in air or
the background.
How can I simulate a laser beam? Can anybody point me to the right resources
(tutorials, example pov files, etc...)?
I would like to illustrate simple concepts like reflection, refractio,
diffraction on lenses and some other optical objects. But I need to actually
control the beam size and see it. I don't want a *virtual* light source. Thanks
for any help.
Cheers,
Peter "Excalibur"
Subject: Re: Simulating a *visible* laser beam
Date: 10 Feb 2008 06:43:27
Message: <47aee35f$1@news.povray.org>
> POVRay.
> the background.
> for any help.
> Cheers,
> Peter "Excalibur"
Have a look at the "Optics.pov" scene. What you'll need is media which
the light can pass through (like dusty air), the light/laser will then
highlight the media, making it see "visible" just like IRL
You should get something like this :
http://www.soware.co.uk/POVRay/player.php?id=11
(but obviously without the jitter due to me animating the media at too
low a quality
Simon
Date: 10 Feb 2008 11:05:01
Message: <web.47af1f65c0351d35b05f96f70@news.povray.org>
> POVRay.
> the background.
> for any help.
I was playing with this a bit recently, with some frustration.  You might want
to check out the examples and tutorials on http://weblog.sitewww.ch/ as well.
He starts showing visible beams of light passing through lenses and off mirrors
in various combinations on page 10, though its probably useful to read the pages
leading up to it.
My frustration stemmed from getting a reflected beam to be visible after being
reflected.  The beam showed in the scattering media until it hit the mirror,
and the light showed reflective caustics on a target, but the beam wasn't
visible between the mirror and the target.
Eventually I found I needed to turn up the media parameter of the photons, and
significantly turn up the samples of the media to see anything.
I'll post the test scene I got some basic results from in p.t.s-f in case its
helpful.
-The Mildly Infamous Blue Herring
Date: 10 Feb 2008 11:25:00
Message: <web.47af24dec0351d35b05f96f70@news.povray.org>
> helpful.
Scene file:
http://news.povray.org/web.47af219494e592ceb05f96f70%40news.povray.org
Image: http://news.povray.org/web.47af23af94e592ceb05f96f70%40news.povray.org
Date: 10 Feb 2008 13:00:06
Message: <47af3ba6$1@news.povray.org>
> POVRay.
> the background.
cylinder {
   StartPoint,EndPoint,Radius hollow
     pigment { rgbt 1 }
   interior {
     media { emission LaserBrightness absorption LaserBrightness }
John
Date: 10 Feb 2008 15:35:01
Message: <web.47af5f02c0351d35140a26e60@news.povray.org>
Thanks to Blue Herring an Simon. I'll look into those.
John VanSickle <evi### [at] hotmailcom> wrote:
*snip
> cylinder {
>    texture {
>      pigment { rgbt 1 }
>    interior {
Thanks for the reply John, but this is not what I had in mind. I actually want a
real "light_source" to act as a laser as I want to have some realistic
refraction/reflection or dispersion effects.
But if I use a basic cylinder, then it's not meaningful if let's say I redirect
it to a lens. It won't have the same effect as a real light beam
Date: 1 Mar 2008 06:38:59
Message: <47c94053$1@news.povray.org>
<Peter> wrote in message
news:web.47ae9f01e7ebe4ed140a26e60@news.povray.org...
> POVRay.
> visible
> but
> or
> the background.
> resources
> actually
> Thanks
> for any help.
> Cheers,
> Peter "Excalibur"
There's a scene I made a long time ago. It doesn't work with POV v. 3.7, but
works with versions 3.5 and 3.6.
It's not a true laser. Basically, a light source is placed a long way from
the scene (999,900 units, in this case) and the scene is in a box with a
hole in the wall for the "laser" to enter the scene. A media-filled box
allows the laser to be seen. I'll post the image that this scene file
produces in .binaries.images. The code is a bit on the spaghetti-ish side,
and it's been a long time since I wrote it, so I'm not real familiar with
the specifics of it anymore. Feel free to cut-and-paste the parts you need.
Hope it helps.
I've posted the POV file in pov.text.scene-files and the resulting image in
pov.binaries.images
Eric
