POV-Ray : Newsgroups : povray.general : Parametric object: max gradient Server Time
25 Aug 2025 19:04:35 EDT (-0400)
  Parametric object: max gradient (Message 1 to 6 of 6)
Subject: Parametric object: max gradient
Date: 13 Jan 2008 06:45:01
Message: <web.4789f96486befbeb6fbc0f680@news.povray.org>
What type of values can I input for the max_gradient of the parametric object?
The docs don't give a default value, or describe what the effect of changing
the values are. Also, the example provided in the docs has two question marks
("??") instead of a float value. This causes the render not to start.
Subject: Re: Parametric object: max gradient
Date: 13 Jan 2008 20:25:26
Message: <478aba06$1@news.povray.org>
> object?
> changing
> marks
This is the same as for isosurfaces, I think, so the default would be 1.1.
Larger numbers render slower... it's a float value so you can turn it up
if you are willing to wait... and you can look at the discovered
max_gradient warning to set it just a bit over what is needed.
Date: 14 Jan 2008 08:29:28
Message: <478b63b8@news.povray.org>
Tim Attwood napsal(a):
>> object?
>> changing
>> marks
I always use precompute 20 x,y,z. It doesn't take much time to parse and
renders a lot faster.
Also, I try to avoid parametrics whenever possible.
Date: 14 Jan 2008 14:50:01
Message: <web.478bbbe9e8c145c5a46b932a0@news.povray.org>
Yeah, they're really slow.
Date: 14 Jan 2008 20:28:16
Message: <478c0c30$1@news.povray.org>
You can make parametrics much faster by converting them into
meshes with Ingo's meshmerizing macros.
http://code.google.com/p/mmgm/
Date: 16 Jan 2008 15:00:00
Message: <web.478e61c1e8c145c5368884fc0@news.povray.org>
Thanks for the tip! I'll have to try that.
