What type of values can I input for the max_gradient of the parametric object?
The docs don't give a default value, or describe what the effect of changing
the values are. Also, the example provided in the docs has two question marks
("??") instead of a float value. This causes the render not to start.
> object?
> changing
> marks
This is the same as for isosurfaces, I think, so the default would be 1.1.
Larger numbers render slower... it's a float value so you can turn it up
if you are willing to wait... and you can look at the discovered
max_gradient warning to set it just a bit over what is needed.
Tim Attwood napsal(a):
>> object?
>> changing
>> marks
I always use precompute 20 x,y,z. It doesn't take much time to parse and
renders a lot faster.
Also, I try to avoid parametrics whenever possible.
Yeah, they're really slow.
You can make parametrics much faster by converting them into
meshes with Ingo's meshmerizing macros.
http://code.google.com/p/mmgm/
Thanks for the tip! I'll have to try that.
