POV-Ray : Newsgroups : povray.general : render from external application Server Time
6 Mar 2026 21:03:21 EST (-0500)
  render from external application (Message 1 to 10 of 10)
Subject: render from external application
Date: 30 Dec 2007 17:10:00
Message: <web.4778156b6207088cb34397d20@news.povray.org>
i am trying to launch Pov using a Python script in order to generate
automatically thousands of images (changing some float values).
However i can open the .pov file, but i do not know how to give the command for
rendering the image. Is it possible to set a default render after opening the
file?
Thanks
Francesco
Subject: Re: render from external application
Date: 30 Dec 2007 17:25:36
Message: <47781ae0$1@news.povray.org>
Francesco napsal(a):
> Hi,
> file?
> Thanks
> Francesco
the harder way: GUI extensions
the easier way: command line options (esp. -i and -o), see the docs
Date: 30 Dec 2007 17:50:01
Message: <web.47781ff1bebf7afd8c382b80@news.povray.org>
guess it's a problem only under Windows... :)
Date: 30 Dec 2007 17:53:06
Message: <47782152$1@news.povray.org>
> command for
> the
> file?
With the Windows version you can call a POV render from the DOS
command line with
pvengine /EXIT +I"filepath\scene.pov" +W640 +H480
to render a certain scene and then exit, it does open the editor
and splash every time though. There are modified versions of POV
around if you need to do it without bringing up any windows.
Date: 31 Dec 2007 08:01:08
Message: <4778e814@news.povray.org>
Francesco wrote:
> Hi,
> file?
While we're at it, is there a way to have POV-Windows render to a window
whose handle is supplied by an external program?  I'd like to have
render previews in the modeler I'm working on.
John
Date: 31 Dec 2007 08:25:54
Message: <4778ede2@news.povray.org>
  Yes. Moray does exactly that. I can't help you with the specifics,
though, but the winpov source code should have some help text.
Date: 31 Dec 2007 08:41:33
Message: <6cshn3l9osgnkij795621bteianuijt30o@4ax.com>
On Mon, 31 Dec 2007 08:00:59 -0500, John VanSickle <evi### [at] hotmailcom>
You could try asking Hugo Arnaut at www.bishop3d.com
He is doing that for his modeller, Bishop3D.
Regards
Date: 31 Dec 2007 12:10:01
Message: <47792269$1@news.povray.org>
> command line with
POVWIN is quite capable of accepting a render request without firing up a new
instance or displaying a splash screen, and you don't need a GUIEXT to do it.
To demonstrate, start an instance of POVWIN, and make sure that 'keep single
instance' is set on. Then, issue a render command like so:
  pvengine /render somefile.pov
The render will start in the existing instance of POVWIN.
-- Chris
Date: 31 Dec 2007 12:20:00
Message: <web.4779249cbebf7afdb65ac5f90@news.povray.org>
I have searched the source and there is ONLY one instance of:
render_window = (something besides NULL)
that is: render_window = CreateWindowEx (
So right now I dont see how it is possible without
"render_window = some_handle_from_cmd_line".
As for the "render from external application" as described, multiframes from
multifiles with some change, mirc is perfect for this.
this exported my molecules back when this all started:
alias object_export {
; ($1 = parameter1 = some pov file)
  var %d = c:\programing\povray3.6\bin\pvengine.exe
  if (!$exists(%_.pveng)) set_pvengine
  %d = %_.pveng
  if ($exists(%d)) run %d /RENDER $1
  else echo -s No Render Engine
"but i do not know how to give the command for
rendering the image"
the command is "/render"
Date: 1 Jan 2008 12:31:42
Message: <477a78fe@news.povray.org>
GUI extensions let you do that.
