POV-Ray : Newsgroups : povray.general : povray crashes on multiplication? Server Time
7 Mar 2026 00:25:22 EST (-0500)
  povray crashes on multiplication? (Message 1 to 8 of 8)
Subject: povray crashes on multiplication?
Date: 2 Dec 2007 15:00:01
Message: <web.47530db5ce3f99a0e99dba500@news.povray.org>
I'm using a macro which is called only a few (7) times:
/* code starts here *********************************************************/
#macro DrawShelfSection( aLeft, aRight, aY, aSlanting )
    #declare InvCosSl = 1 / cos ( 180 * aSlanting / pi );
    #declare xx = Left;
    #while (xx < Right)
        #if (xx + Bwidth <= Right)
            DrawBook( xx, aY, Bheight, Bwidth, aSlanting, RandomColor > )
        #declare xx = xx + Bwidth * InvCosSl;
/* code ends here ***********************************************************/
When I start rendering the "tokens parsed" counter starts and runs until POVray
crashes at about 270 million (!) tokens parsed.
When I change the last declaration to
    #declare xx = xx + Bwidth;
everything runs fine (with only 660000 tokens parsed).
I first thought the error may have been caused by the 10000x10000 pixel image,
but it also happens on a 500x500.
You can find the error msg dialog at http://www.nenya.be/temp/povray_err.png.
Ideaz anyone?
TIA
Steven
Subject: Re: povray crashes on multiplication?
Date: 2 Dec 2007 15:10:07
Message: <4753111f$1@news.povray.org>
>     #declare xx = Left;
>     #while (xx < Right)
>         #end
>     #end
> #end
Could you post the *full* code, including DrawBook() and without the
'...' replacement? Or even better, remove other stuff until the code is
"small enough" but *still* causes the crash (= a minimal testcase to
reproduce the crash).
Date: 2 Dec 2007 15:24:21
Message: <47531475$1@news.povray.org>
Hash: SHA1
stevenvh wrote:
> Hi,
>     #declare xx = Left;
>     #while (xx < Right)
>         #end
>     #end
> #end
> Ideaz anyone?
	My bet is: at least once in the full code, you call your macro with
a value of aSlanting which causes the cos to be negative, at which
point your macro goes left indefinitely and never reaches the
"Right" position...
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
iD8DBQFHUxRzd0kWM4JG3k8RAjDGAKCOd7tkafVSB4upitJPSSHdjaKJ9wCglC2b
YQSeFNApkRcWu3VJZfnONK4=
=t9LF
-----END PGP SIGNATURE-----
Date: 2 Dec 2007 16:15:00
Message: <web.47531fe3e9e16078e99dba500@news.povray.org>
Hi Nicolas,
thanks for your reply. I was stripping unnecessay code until I had only a few
dozen lines left when I spotted a logical error in my code:
should of course be
    #declare InvCosSl = 1 / cos ( pi * aSlanting / 180 );
and now it seems to be OK. Playing a bit with the argument of cos() I noticed
that POVray goes bananas if the argument falls outside [-pi/2, pi/2].
Is there any reason why it won't accept just any real number, as cos() should?
Steven
Date: 2 Dec 2007 17:18:08
Message: <47532f20$1@news.povray.org>
> Hi Nicolas,
A minimal testcase would be still useful for the devs to find the cause
of the unhandled exception (which should never happen, no matter what
the SDL code does).
Date: 2 Dec 2007 17:21:28
Message: <47532fe8$1@news.povray.org>
Hash: SHA1
> Hi Nicolas,
> should of course be
	Sure there is: read my reply to your first post ;)
		Jerome
iD8DBQFHUy/nd0kWM4JG3k8RAqHBAJ0c/702BfkWlaFtN0lsEIfvRYvoQwCglFYT
M++nMVuvkjRAYSNtWS2q2pU=
=cAAi
Date: 3 Dec 2007 09:46:32
Message: <475416c8$1@news.povray.org>
stevenvh nous apporta ses lumieres en ce 2007/12/02 14:55:
> Hi,
>     #declare xx = Left;
>     #while (xx < Right)
>         #end
>     #end
> #end
> Ideaz anyone?
> TIA
> Steven
The variable "InvCosSl" can go negative. I suggest using the absolute value.
Also, "cos ( 180 * aSlanting / pi )" can evaluate to a very small, even zero,
value, resulting in an extremely large value (overflow) or a divide by zero
error. In fact, you evaluate a cotangent, a functions with asymptotic lines.
   My wife likes to talk on the phone during sex; she called me from Chicago
last night.
	Rodney Dangerfield
Date: 4 Dec 2007 05:15:00
Message: <web.47552864e9e16078e99dba500@news.povray.org>
No, I don't :-). Cotangent would be cos()/sin(), whereas I use 1/cos().
I agree that an infinite loop problem arises when cos() goes negative; that was
the origin of my problem. But that was due to a programming error; (it had been
a long day :-))  in my application aSlanting is limited to just a few degrees.
As for Nicolas' request to post the code, I'm afraid I inadvertently changed it,
since now it just reports an out-of-memory error. As any infinite loop would do.
Muchas gracias, et merci beaucoup, all of you
Steven
