POV-Ray : Newsgroups : povray.general : Collective Short Code Wisdom Server Time
25 Aug 2025 21:07:04 EDT (-0400)
  Collective Short Code Wisdom (Message 1 to 10 of 20)
Subject: Collective Short Code Wisdom
Date: 30 Nov 2007 10:40:01
Message: <web.47502e7612ffcf68e2b2e7080@news.povray.org>
Since no objection from Mr. Bourke (or anyone else) has been forthcoming, I
shall proceed with my declared intention of opening a thread for tips on
know more about such things (that would be most of the people reading this)
will add their knowledge to the pool.  Thus begins:
THE UNOFFICIAL, LARGELY DISORGANIZED LIST OF POVRAY SHORT CODE TIPS, TRICKS &
METHODS:
avoid having to specify these.  You can also eliminate one of these and still
object definition.  For example:
7.  Vector expressions with zero values can be shortened as follows:
8.   Although rather non-specific, this general approach can be helpful.  Search
the features that you want to work with to see where you can get away with
using a default value.
Thanks in advance to all contributors,
Mike C.
Subject: Re: Collective Short Code Wisdom
Date: 30 Nov 2007 12:28:06
Message: <47504826@news.povray.org>
If there is a number followed by another token (like a keyword), the
current POV-Ray parser allows you to skip the whitespace. For example:
diffuse 0.6ambient 0.1
For numbers in the 0-1 range, you don't really need the leading 0 here, so:
diffuse .6ambient .1
And in this particular case, where the number starts with a period
instead of a digit, you can even do this:
diffuse.6ambient.1
Same goes for negative numbers, which start with a dash instead of a digit.
I'm using diffuse and ambient just to give an example. In practice, you
would use *nothing* according to Mike's tip #4 :) But this tip is useful
for other keywords.
Date: 30 Nov 2007 12:40:01
Message: <web.47504a61e1f3da1ec150d4c10@news.povray.org>
Also:
"<1,0,1>" becomes x+z
"<2,0,2>" becomes 2*(x+z)
or other combinations
-tgq
Date: 30 Nov 2007 12:47:30
Message: <47504CB2.8040001@hotmail.com>
> Also:
7 chars -> 7 chars. not much of an improvement ;)
I would suggest in stead: 2-2*y or 2-y-y
Date: 30 Nov 2007 13:02:07
Message: <4750501f$1@news.povray.org>
[snip]
In addition, you can seperate tokens by "preprocessor declarations":
	sphere{0,1}
or
	sphere{0 1}
becomes
	sphere{0#local r=.422;1}
Of course this makes only sense if you need the "#local r=.422" anyway :)
Florian
Date: 30 Nov 2007 15:45:00
Message: <web.47507567e1f3da1ec150d4c10@news.povray.org>
> > Also:
Sorry, bad example, more applicable to larger numbers
<20,0,20> -> 20*(x+z)
Probably better to scale the whole scene though instead...
-tgq
Date: 30 Nov 2007 16:08:14
Message: <47507bbe@news.povray.org>
>> Also:
If you'll need such values *often*, you can #local xz=x+z; Then you can
use 2*xz which is only 4 chars.
Date: 30 Nov 2007 17:05:40
Message: <47508934.1000800@hotmail.com>
>>> Also:
20-20*y is still shorter ;)
> -tgq
Date: 30 Nov 2007 19:45:00
Message: <web.4750ad9ce1f3da1e8442668d0@news.povray.org>
"Mike the Elder" <zer### [at] wyanorg> wrote:
of course, at the cost of flat scenes.  It can be useful if you're not going for
photorealistic 3D scenes and is mostly concerned with colors, shapes and
composition.
Date: 3 Dec 2007 16:50:37
Message: <47547a2d$1@news.povray.org>
One thing I enjoyed playing with and exploiting last time is the default
color maps for POV textures.  Using the scale and poly_wave keywords can
create some selectivity within the default colors
