POV-Ray : Newsgroups : povray.general : Defining new materials in a way similar to RenderMan ... Server Time
7 Mar 2026 04:30:14 EST (-0500)
  Defining new materials in a way similar to RenderMan ... (Message 1 to 4 of 4)
Subject: Defining new materials in a way similar to RenderMan ...
Date: 24 Aug 2007 09:10:00
Message: <web.46ced7a9a702e3b3948923d30@news.povray.org>
Does POV-Ray possess a native shading language enabling the user to define
new materials
in a way similar to RenderMan?
As an example, I could use such a language to generate a scene depth map by
painting the surfaces with their  distance from the camera ...
Thanks a lot for any hint,
Subject: Re: Defining new materials in a way similar to RenderMan ...
Date: 24 Aug 2007 09:20:21
Message: <46cedb15@news.povray.org>
> new materials
  Not really. There exists a patch called povman which implements a
subset of the renderman shader language, though.
Date: 24 Aug 2007 20:21:42
Message: <46cf7616$1@news.povray.org>
In general Warp is correct, the tricks done with procedural textures in
packages like RenderMan translate poorly to POV.
> by
This particular example is very doable in POV though.
You can place all your objects in a single union and then
texture it with a spherical pattern pigment centered on the camera.
If you are using an orthographic camera you can use a gradient
instead. Here's a minimal example scene.
global_settings {
  assumed_gamma 1.0
  hf_gray_16 on
#declare CLOC = <0.0, 0.5, -4.0>;
  location  CLOC
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
union { // scene
   plane {y, -1}
   sphere {0.0, 1}
      spherical
      color_map {
         [0 rgb 0]
         [1 rgb 1]
      scale 15
      translate CLOC
   finish {ambient 1}
Date: 25 Aug 2007 21:45:01
Message: <web.46d0da6d7f6cd557d55e4a40@news.povray.org>
I find for complex scenes it can get annoying to sort out the texture
changes required. MegaPOV's post-processing feature can output a depth map
without requiring any changes to objects, and unlike some of the
post-processing options it doesn't take much time to render.
Tom
