My question is: how do you simulate the visual distortions caused by high
heat? I.e., how do you make the air wavy around jet exhausts or candle
flames?
Thanks!
> flames?
> Thanks!
Try a primitive like a box or cylinder. Give it a completely transparent
texture and no reflective properties, then play with normals and the ior
value (you probably should only use a small ior value I would think)
-tgq
I did a little searching and found that the solution would be to use a
variable ior and some sort of a wave pattern. But, this is not possible in
POV-Ray. I will instead try nesting objects with differenet ior inside each
other and see if that gives good results.
"SharkD" <nomail@nomail> wrote in message
news:web.46734008e9b9c8227180a6bf0@news.povray.org...
> each
Hi Shark,
You may want to try a noisy isosurface. Isosurfaces give you lots of control
over the sorts of perturbations you can simulate.
I hacked the following example together based on Mike Williams' isosurface
tutorial at http://www.econym.demon.co.uk/isotut/combine.htm
Chris B.
camera {location <0, 0.8,-1> look_at <0,0,0>}
light_source { <0, 50, -30> color rgb <1,1,1>}
global_settings { max_trace_level 10 }
plane {y,0 pigment {checker scale 0.1}}
#include "functions.inc"
#declare S = function {x*x + z*z + y - 1}
isosurface {
function { S(x,y,z) + f_noise3d(x*10, y*10, z*10)*0.3 }
max_gradient 7
contained_by{sphere{0,2}}
pigment {rgbt 1 } interior { ior 1.03 }
scale <0.1,1,0.2>
rotate z*90
translate 0.2*y
I may combine that with another trick I came up with:
#declare Count = 0;
#declare Increment = 0.01;
#declare Exhaust_Plume = union
#while (Count < 1)
cone
<0,Count * -100,0,>, 6 + Count * 26, <0,(Count + Increment) * -100,0,>, 6
+ (Count + Increment) * 26
open
material
texture
pigment {color rgbt 1}
interior
ior (1.01 - Count * 0.01)
#declare Count = Count + Increment;
object
Exhaust_Plume
SharkD nous apporta ses lumieres en ce 2007/06/15 17:23:
> flames?
> Thanks!
Use some totaly transparent (rgbt 1) object, apply some normal to it. Then give
it an interior with an ior slightly less than 1, something in the 0.93~0.999 range.
In some cases, you may need to use an isosurface.
You may need to use more than one distording onjects, this can help you simulate
variable ior, to a limit.
You know you've been raytracing too long when you've ever "lost" a Julia fractal
because you're not quite sure how to align things in four dimensions.
Dylan Beattie
SharkD nous apporta ses lumieres en ce 2007/06/16 14:06:
> #declare Count = 0;
> #while (Count < 1)
> cone
> open
> material
> texture
> interior
> #end
> object
> Exhaust_Plume
Remember that hot air have an ior that is inferior than that of the ambient air.
Ambient air have an ior of 1 (strictly, it's the ior of vacuum, air is about
1.001 to 1.003 depending on persure ant temperature).
So your hot air should have an ior LESS than 1 by a very small margin:
0.98< HotAirIOR < 1.0
To define recursion, we must first define recursion.
I've tried specifying iors that are less than one but get very different
results. The cones are now striped. It doesn't look very good at all.
Nevermind. I had set the ior to -1.01 instead of 0.99.
I've tried nesting cones with increasing ior as follows. However there are a
lot of shadow-like artifacts introduced which I don't know how to get rid
of.
#declare Increment1 = 0.1;
#declare Increment2 = 0.01;
#declare Count1 = 0;
#while (Count1 < 1)
#declare InvCount1 = 1 - Count1;
#declare Count2 = 0;
#while (Count2 < 1)
intersection
cone
<0,Count2 * -128,0,>, 6 + Count2 * Count1 * 26, <0,(Count2 +
Increment2) * -128,0,>, 6 + (Count2 + Increment2) * Count1 * 26
open
material
texture
interior
ior ((1 - InvCount1 * 0.1) + Count2 * InvCount1 * 0.1)
#declare Count2 = Count2 + Increment2;
#declare Count1 = Count1 + Increment1;
SharkD nous apporta ses lumieres en ce 2007/06/16 17:44:
> of.
> #while (Count1 < 1)
> #while (Count2 < 1)
> intersection
> cone
> open
> material
> texture
> interior
> #end
> #end
Take a look at how many cones you have. The first loop is executed 10 times, the
secont 100 times = 1000 cones. This result in rays having to cross 2000
surfaces! You then need a max_trace_level of AT LEAST 2001 while the maximum
value possible is 255...
Every times you exeed max_trace_level, you get BLACK returned.
A short cut is the longest distance between two points.
