POV-Ray : Newsgroups : povray.general : dynamic memory possible? Server Time
5 May 2026 02:33:28 EDT (-0400)
  dynamic memory possible? (Message 1 to 10 of 16)
Subject: dynamic memory possible?
Date: 4 Jun 2007 06:30:02
Message: <web.4663e8a8e799405a678ea4f80@news.povray.org>
Hello there,
I hope you understand my question, it's directly translated from German...
I have a file with some coordinates I want to store in an array. Since I
don't know how to store in an array that was not defined before I do this:
#fopen fsbsp "124440_ACR.txt" read
#declare fs_count = 0;
#while(defined(fsbsp))
  #read (fsbsp,utm_x,utm_y,utm_z)
  #declare fs_count = fs_count+1;
#debug concat("fs_count     ", str(fs_count, 0,0),"n")
#declare a_pos = array[fs_count];
#fopen a_pos_f "124440_ACR.txt" read
#declare fs_count2 = 0;
#while(defined(a_pos_f))
  #read (a_pos_f,utm_x,utm_y,utm_z)
  #declare a_pos[fs_count2] = <utm_x,utm_y,utm_z>;
  #declare fs_count2 = fs_count2 + 1;
Here's what this does:
- opens the file and "counts" the rows
- closes the file (#while(defined(...)))
- defines the array
- opens the file again
- reads and stores values
- closes the file again
Is there any possibility to do this without opening and reading the file
twice? I know Java can do dynamic memory (if that's what it is called), but
POV?
Thanks in advance
Gunnar
Subject: Re: dynamic memory possible?
Date: 4 Jun 2007 07:32:22
Message: <4663f846@news.povray.org>
you should simply answer this question.
Why did you open the same file under 2 differents name ?
news:web.4663e8a8e799405a678ea4f80@news.povray.org...
> Hello there,
> #end
> #end
> - defines the array
but
> POV?
> Thanks in advance
> Gunnar
Date: 4 Jun 2007 07:45:02
Message: <web.4663fa51752edf44678ea4f80@news.povray.org>
You're right, I did that. But I don't think that matters... does it?
Date: 4 Jun 2007 11:49:49
Message: <4664349d$1@news.povray.org>
> POV?
In arrays.inc there is a macro to resize an array.  So you can define
you array initially to take the first item then resize it with each
sucessful read from your file.
Date: 4 Jun 2007 12:34:14
Message: <46643f05@news.povray.org>
  This is not a good solution, especially if the amount of items is large.
  The resizing is done by creating a second array of the new size and
then copying the elements of the first array into the second. If you do
this for all n elements in the input you'll end up doing n resizes and
n+(n-1)+(n-2)+...+1 copy operations, which grows proportional to the
square of n. (For example if the input had 1000 elements it would end up
making 500500 copy operations. That's half million.)
Date: 4 Jun 2007 12:54:54
Message: <466443de$1@news.povray.org>
but what you can do, is start out with a reasonable guess and increase
it from there (by jumps).  You may end up wasting some space by growing
the array too large, but it would work.
-ds
Date: 4 Jun 2007 13:02:25
Message: <466445a1$1@news.povray.org>
<shrug> I know ... but that's his call. And even a slow old 1 gh machine
can still polish off a half a million copies pretty fast can't it? Also
the coding is awkward with the array index, the loop control and the
array dimension to resize to, being offset.  Personally I would probably
print the array declaration into an include file, externally in a
program such as Python.  But we really don't know what his purposes are.
Date: 4 Jun 2007 15:20:02
Message: <web.466464d5752edf447e595fbb0@news.povray.org>
If the data in the file isn't changing very often it might be worth running
a loop to count the lines, then write a new data file with the array size
as a header (maybe from a macro or a separate scene file). Then subsequent
test renders etc with the same data can read the header and create an array
with the correct size.
But maybe that's not convenient... :-)
Date: 4 Jun 2007 15:57:25
Message: <46646ea5$1@news.povray.org>
Yeah, not very self-contained though.  I preliminary counting read is of
course what he is already doing and wants to improve on.  Probably the
best solution would be to write the array declaration to an include file
right from POV. But there are lots of solutions, my guess is he is just
casting around for options, so hence my original answer to his question.
Date: 4 Jun 2007 19:01:39
Message: <466499d3$1@news.povray.org>
Gunnar nous apporta ses lumieres en ce 2007/06/04 07:41:
Not realy, it just use some more memory.
