POV-Ray : Newsgroups : povray.general : Can POV be made to "ignore" lights beyond a certain distance? Server Time
26 Aug 2025 05:34:57 EDT (-0400)
  Can POV be made to "ignore" lights beyond a certain distance? (Message 1 to 9 of 9)
Subject: Can POV be made to "ignore" lights beyond a certain distance?
Date: 18 May 2007 15:10:01
Message: <web.464df9a83f9f67649073c0250@news.povray.org>
I'm working on a scene which I would eventually like to light with numerous
"torches" (point lights with fade_distance & fade_power).  Is there a way,
in order to speed up rendering, to cause illumination to be calculated only
for objects within a certain distance of the light source, ignoring those
further away for which the amount of illumination contributed would be very
small?
Thanks in advance for replies.
Mike C.
Subject: Re: Can POV be made to "ignore" lights beyond a certain distance?
Date: 18 May 2007 16:01:20
Message: <464e0610@news.povray.org>
> small?
  You could try to divide your scene into sections and then use
light groups to selectively light only certain sections with certain
lights.
Date: 18 May 2007 16:20:02
Message: <web.464e0a31c42ceaf39073c0250@news.povray.org>
> lights.
I'm hoping that I won't have to do that because the scene contains long
"walls" that would have to be broken up into pieces that could be included
or excluded from the various light groups, but still, that's the best
option so far and I thank you for it.
Mike C.
Date: 19 May 2007 09:55:01
Message: <web.464f0117c42ceaf357033b2e0@news.povray.org>
> > lights.
> >                                                           - Warp
> Regards,
> Mike C.
You could also define a distance vector from the camera to the light source,
then check that before the rendering and only render those that are within
some threshold.
Good luck,
Mike S.
Date: 19 May 2007 09:57:20
Message: <464f0240@news.povray.org>
> some threshold.
  I don't think turning off lights was what he was asking.
Date: 11 Jun 2007 10:33:39
Message: <466d5d43@news.povray.org>
That the exact use of fade_power parameters.. you just need to increase it
up to 1, and additionaly modify your fade distance factor
news:web.464df9a83f9f67649073c0250@news.povray.org...
numerous
only
very
> small?
> Regards,
> Mike C.
Date: 11 Jun 2007 10:38:03
Message: <466d5e4b$1@news.povray.org>
note that, if your fade power is already high (up to 3) , that means that
your parameters are not well made..you must then reset your fade_power to 1,
or 0.9 (what i done often) , and then found the appropriate fade_distance
value ..
after you can play with the fade_power parameters to define the appropriate
level of attenuation .
news:466d5d43@news.povray.org...
> numerous
way,
> only
those
> very
> > small?
> > Regards,
> > Mike C.
Date: 11 Jun 2007 11:35:02
Message: <web.466d6b15c42ceaf3d2f077090@news.povray.org>
> value ..
Thanks for the help.
-Mike C.
Date: 11 Jun 2007 13:04:03
Message: <466d8082@news.povray.org>
Mike the Elder <web.464df9a83f9f67649073c0250@news.povray.org> Friday, 18
May 2007 21:08
> those further away for which the amount of illumination contributed would
> be very small?
I had simmilar idea back like... 3, 4 years ago :) Actually was one of my
first questions to news ever afair.
Light groups are not very comfortable to use, and stronger fade alone doesnt
give performence improvement.
Idea to ignore very distant lights would be nice IMHO.
