POV-Ray : Newsgroups : povray.general : Limits to size and distance? Server Time
7 Mar 2026 08:13:21 EST (-0500)
  Limits to size and distance? (Message 1 to 10 of 12)
Subject: Limits to size and distance?
Date: 7 Mar 2007 10:30:01
Message: <web.45eed98f7f59e8b2556a5ed80@news.povray.org>
Are there built in limits to size and distance in povray?
There seems to be...
If I Add a zero to the scale and Z position of the spheres in the below
starfield generator, the render speed drops to a dead crawl, and the stars
cease to render...The actual cut off point is something between 500,000 and
600,000 distance...I haven't bothered to find the exact limits, but this is
very annoying limitation because it makes modeling things like solar
systems either impossible or painful (try making earth a size of 1 radius,
and you still run out of room before you hit the outer planets, so earth
needs to be like .0001 or something crazy like that...obviously this makes
smaller obects like the moon or a space station suddenly become
...00000000001...bleh)
Does anyone know the limits?  or is there something fundamentally wrong with
my code (beyond a lack of compact-code, or the fact that the memory overhead
for this is far greater than for a bit map).
#declare xrndstar=seed(54321);
union{
#declare Count = 0;
#while (Count<500)
object{
sphere{<0,0,500000>,720}
rotate< rand(xrndstar)*360, (rand(xrndstar)*360+rand(xrndstar)*360) ,
(rand(xrndstar)*360+rand(xrndstar)*360)>
pigment{rgb< 1+(rand(xrndstar)*2) , 1+(rand(xrndstar)*1.5) ,
1+(rand(xrndstar)*1) >*.75}
finish{ambient 2}
no_shadow}
#declare Count = Count+1;
#declare Count = 0;
#while (Count<750)
object{
pigment{rgb< .5+(rand(xrndstar)*1) , .5+(rand(xrndstar)*.75) ,
...5+(rand(xrndstar)*.5) >*.75}
finish{ambient 1.5}
no_shadow no_reflection}
#declare Count = 0;
#while (Count<1000)
object{
pigment{rgb< .25+(rand(xrndstar)*.5) , .25+(rand(xrndstar)*.375) ,
...25+(rand(xrndstar)*.25) >*.75}
finish{ambient 1}
Subject: Re: Limits to size and distance?
Date: 7 Mar 2007 10:34:59
Message: <45eedba3@news.povray.org>
<http://tag.povray.org/povQandT/misconceptions.html#simulatingsun>
Date: 7 Mar 2007 11:35:00
Message: <web.45eee9468c55fdc4731f01d10@news.povray.org>
Things can get dicey when you reach solar system proportions. See this
thread:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4360929f30852916731f01d10%40news.povray.org%3E/?mtop=3
for a lengthy discussion (and partial solution) to this problem when some of
us tried to produce a Ringworld (a big dumb object from Larry Niven's SF
novel of the same name).
Bill
Date: 8 Mar 2007 12:30:01
Message: <web.45f047908c55fdc4556a5ed80@news.povray.org>
Unfortunately this does not really answer my question.
The "stars" in question are not being used as light sources...
Are you suggesting that the problems I am having are due to these objects
trying to recieve light from the light sources in my scene?
Because even without light sources The scene slows to a crawl (about 1/100th
the speed) if i try to place an object at 5 million units away from the
camera...and then no matter how large I make it the object will not show up
unless some edge of the object is within ~500,000 units...
That is what I was looking for a reson for...I am perfectly fine with
running this with the solar system not to actual scale, but stars sould be
quadrillions of units away from the camera yet I can only place them a mere
500k units away before things crash to a standstill.
Date: 8 Mar 2007 12:40:01
Message: <web.45f049d58c55fdc4556a5ed80@news.povray.org>
> thread:
> Bill
Thanks for the link...Looks like I may be up against a wall on an even
slammer scale than ringworld scales...
I have bult a space station (small and retro-sci-fi styled) using 1 unit = 1
foot as a scale...
Then I placed a "Jupiter" like object behind it which is roughly 350k units
distant Z and 250k Units Radius...the problem is that the Stars cannot be
more than 500k out...which means that the back edge of "jupiter" is hitting
the stars...
This causes some obvious issues...
Any suggestions beyond rescallign everything so that 1 unit = 100 miles and
then resizing jupiter, the space station, and everything else and leaving
the stars at 500K units?
Date: 8 Mar 2007 13:05:00
Message: <web.45f04f098c55fdc4f5fba6ef0@news.povray.org>
What is to be kept in mind is that the accuracy interval of POV for the 3D
space of your scenes is something around [1e-5 .. 1e+5], whatever you deal
with: positions (light_sources or objects), distances, sizes, and perhaps
densities, colors ...
You cannot put together a 5mm insect on a 10cm stone, on a 2000m high
mountain, on a 6378.137km earth, with a 150000000km distant sun with
10000000000000 km distant stars. The range of the size-dynamic should be
kept reasonable within those intervals, because of POV internal thresholds
and epsilons, and because of numerical accuracy.
So in order to make a planetary scene, just try POV's maximum possibilities
with a sample scene in order to make yourself an idea. Then you can place
objects where POV can handle them, and far enough for your stars to be
realistic. You could be lead to change your global scene scale from 1 pov
unit = 1 m  to 1 pov unit = 1km. It depends ... but 100k units for the sun
is not far from the max I think.
    Bruno
Date: 8 Mar 2007 13:26:19
Message: <45f0554b@news.povray.org>
Of course, but it won't matter as all as long as you adjust them to their
relative size. Besides, if you really want good looking stars, I would
strongly recommend a texture, not actual objects.
	Thorsten
Date: 8 Mar 2007 15:45:01
Message: <web.45f075c78c55fdc4556a5ed80@news.povray.org>
>  Thorsten
Try the code I posted...You'll like it I think...
However, even if I used a texture as you reccomend, the sphere on which the
texture was painted would still suffer the same limitations (albeit with
less memory overhead)
One thing I was thinking is that the stars can move with the camera location
(not rotationally, but in the prime directions) because according to paralx
you should never get ANY closer to any of the stars in a scene unless you
were traveling at insane speeds...
Date: 8 Mar 2007 17:00:01
Message: <web.45f086a28c55fdc4ee21010a0@news.povray.org>
Don't forget sky_sphere....
Charles
PS Since this seems to come up a lot, I sometimes wish for some sort of an
alternate parse/render mode where every float uses even more bits, not
necessarily defined by what the local architecture/compiler/FPU is designed
around.  Imagine being able to set float bit length to 128, 256, 512!? in an
INI file. I know, I know, it'd be super slow, probably hard to implement and
I'm dreaming ;-)
Date: 8 Mar 2007 19:00:10
Message: <45f0a38a$1@news.povray.org>
FexFX nous apporta ses lumieres en ce 08-03-2007 15:44:
>>  Thorsten
Place your camera at the origin and paint your stare on a large world sphere.
Wrap everything else in a large union, and move that union.
-OR-
Use a sky_sphere. It's a background feature that use an unis sphere centered on
the camera location whose pigment is returned if a ray don't encounter anything
else. It is not rotated if you apply a rotation to the camera.
If you need a planet 10 000 000 unit away, place it only 1000 unit away, but
scale it 10 000 times smaler. The end result will be the same.
History, in general, only informs us of what bad government is.
Thomas Jefferson
