Hi, all.
Maybe I've missed this, but could someone please tell me how I can use HEX
instead of decimal numbers for constants. I trying to use data to construct
3D models with hex values without having to convert them to decimal.
Thank you for your time.
"JS" <bos### [at] yahoo co uk> wrote in message
news:web.459c36d822a5f346188aeae70@news.povray.org...
> Hi, all.
> construct
I can't think of anything in POV-Ray that handles hexadecimal numbers.
Someone else may know better, but I'd say you'll have to convert them.
Here's a simple POV-Ray conversion macro that should enable you to use
hexadecimal numbers inline in your SDL.
#macro X2D(Hex)
#local Digits = "0123456789ABCDEF";
#local Hex = strupr(Hex);
#local I = strlen(Hex);
#local Decimal = 0;
#local Factor = 1;
#while (I>0)
#local Character = substr(Hex,I,1);
#local J = 0;
#local Found = 0;
#while (J<strlen(Digits))
#if (strcmp(Character,substr(Digits,J+1,1))=0)
#local Decimal = Decimal + J * Factor;
#local Found = 1;
#local J = J + 1;
#if (!Found) #error concat("\nX2D - Character position ",str(I,3,0),
"of ",Hex," contains an invalid Hex character\n\n") #end
#local Factor = Factor * 16;
#local I = I-1;
Decimal
#declare MyValue = X2D("01F");
#debug concat("\nDecimal Value: ",str(MyValue,10,0),"\n\n")
Hope this helps,
Chris B.
> > Hi, all.
> > construct
> Hi,
> #macro X2D(Hex)
> #local Decimal = 0;
> #local Factor = 1;
> #while (I>0)
> #local J = 0;
> #local Found = 0;
> #local Found = 1;
> #end
> #local J = J + 1;
> #end
> #if (!Found) #error concat("nX2D - Character position ",str(I,3,0),
> "of ",Hex," contains an invalid Hex characternn") #end
> #local I = I-1;
> #end
> Decimal
> #end
> #debug concat("nDecimal Value: ",str(MyValue,10,0),"nn")
> Hope this helps,
> Regards,
> Chris B.
Thankyou, Chris B, I'll try it out. What about if hex support was added for
a future release of Pov-Ray?
> Hi, all.
> can use HEX
> construct
> decimal.
http://news.povray.org/povray.text.scene-files/thread/%3Cweb.44184ac05017e713dbc416040@news.povray.org%3E/
