POV-Ray : Newsgroups : povray.general : Problem with differences/unions, maybe too many; or a missing "{" or "}"? Server Time
7 Mar 2026 11:31:54 EST (-0500)
  Problem with differences/unions, maybe too many; or a missing "{" or "}"? (Message 1 to 4 of 4)
Subject: Problem with differences/unions, maybe too many; or a missing "{" or "}"?
Date: 24 Dec 2006 04:10:00
Message: <web.458e4323bcd79e8bea53f7190@news.povray.org>
Hi!
To see the effect, a very small resulotion is enough.
I hope I just made some mistake in the syntax :)
The scene is a pot with liquid on a table (box), a plane y*-4, a skysphere,
light, camera, max intersection set to 255, max trace level 50.
Examples of problem:
- Depending on changing the feet of the pot, part of the liquid in the pot
vanishes. (Outcomment the union starting at "DOESN'T WORK", and delete the
union before.)
- When I delete the plane the liquid vanishes too :) (Delete the plane in
the original version, at the end of the scene.)
- Sometimes, when deleting one difference, everything looks fine again (Try
wildly :)
So here is the code:
#version 3.6;
global_settings {
  assumed_gamma 1.0
  max_trace_level 50
  max_intersections 255
//  location  <0.0, 0.7, -4.0>*1.2*2 *0.35   // to watch from the side,  so
you could see the feet
  location  <0,4,0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [10000000 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>
  color rgb <1, 1, 1>
  translate <-30, 30, -30>
    union{
        difference {            // pot
          sphere {  0.0, 1 }
          box {-<1.2,0,1.2>, <1.2,1.2,1.2>}
          sphere {  0.0, 0.98 }
        difference {            // pot-feet
          union {cylinder { <0,-2,0>, <0,0,0>, 0.04 rotate z*35 rotate y*0}
y*120}
y*-120}
 /* DOESN'T WORK        union{       cylinder { <0,-2,0>, <0,0,0>, 0.04
rotate z*35 rotate y*180}
                 cylinder { <0,-2,0>, <0,0,0>, 0.04 rotate z*35 rotate y*60}
y*-60}
          sphere {  0.0, 1 }
          box {-<3,3,3>, <3,-1,3>}
              color rgb <0.8,0.8,1.0>
            finish{
              diffuse 0.3
              ambient 0.0
              specular 0.6
              reflection {
                0.8
                metallic
              conserve_energy
    difference {            // liquid
      box {-<1.2,0.15,1.2>, <1.2,1.2,1.2>}
          color Brown*0.1+Red*0.8
        normal { waves .275 scale .125 translate <0.2,0,0.2> }
        finish{
          diffuse 0.3
          ambient 0.0
          specular 0.6
          reflection {
            0.4
            metallic
          conserve_energy
    difference {            // some fog over the liquid
      box {-<1.2,0.05,1.2>, <1.2,1.2,1.2>}
      box {-<1.2,0.15,1.2>, <1.2,-1.2,1.2>}
      pigment{ color rgbt 0.9 }
      interior_texture { pigment { color rgbt <0,0.1,0,0.9> } }     // try
granite
box { <-5, -1.05, -1.2> , <5, -1, 2>   // table
      color Brown*0.1
    normal { waves .075 scale .25 }
    finish{
      diffuse 0.3
      ambient 0.0
      specular 0.6
      reflection {
        0.4
        metallic
      conserve_energy
 plane {
  y,
  -4
  hollow on
      color Brown*0.2
    finish{
      diffuse 0.3
      ambient 0.0
      specular 0.6
      reflection {
        0.8
        metallic
      conserve_energy
Subject: Re: Problem with differences/unions, maybe too many; or a missing "{" or "}"?
Date: 24 Dec 2006 05:52:18
Message: <458e5be2$1@news.povray.org>
You have a coincident surface with the liquid
surface and the "fog" bottom...
   box {-<1.2,0.149,1.2>, <1.2,-1.2,1.2>} // <-- changed
Date: 24 Dec 2006 06:04:46
Message: <458e5ece$1@news.povray.org>
"D. Hansen" <PoV### [at] Stefaniede> wrote in message
news:web.458e4323bcd79e8bea53f7190@news.povray.org...
> Hi!
> skysphere,
> union before.)
> (Try
> wildly :)
Hi D.
I think your problem is one of coincident surfaces. In this case the top
surface of the liquid and the bottom surface of your 'fog over the liquid'
are in exactly the same place. The transparency in the 'fog over the liquid'
makes the surface visible, but the surface has an indeterminate texture so
POV-Ray chooses whether to give it the surface texture of one or other of
the two surface specifications - This issue is actually explained a lot
better in the FAQ. Other, seemingly unrelated objects in the scene, seem to
influence the decision that POV-Ray makes for each point where it finds a
coincident surface in the scene. I think this is why the changes to the pot
feet, the plane and the table influenced the render.
To get rid of this problem just move one or other surface. Below I've
adjusted the 'y' value for the bottom surface of the 'fog over the liquid'
to 0.149 instead of 0.15 and this seems to cure the problem.
      box {-<1.2,0.149,1.2>, <1.2,-1.2,1.2>}     // Avoid coincident
surfaces
granite
You may wish to check your scene for other coincident surfaces.
For the future I'd recommend reducing your code snippets down before
posting.
Your complex texures made your code look more complicated than it is and
didn't contribute to the problem.
Seeing a long piece of code in a posting puts a lot of people off looking at
the problem.
I reduced your code down to the following before spotting what the problem
might be.
#version 3.6;
  location  <0.0, 0.7, -4.0>*1.2*2 *0.35   // Side View
//  location  <1,3,0>
light_source {<1, 30, -1> color rgb 1}
//  union {
//    cylinder { <0,-2,0>, <0,0,0>, 0.04 rotate z*35 rotate y*0}
//    cylinder { <0,-2,0>, <0,0,0>, 0.04 rotate z*35 rotate y*120}
//    cylinder { <0,-2,0>, <0,0,0>, 0.04 rotate z*35 rotate y*-120}
  union{
    cylinder { <0,-2,0>, <0,0,0>, 0.04 rotate z*35 rotate y*180}
    cylinder { <0,-2,0>, <0,0,0>, 0.04 rotate z*35 rotate -y*60}
  sphere {  0.0, 1 }
  pigment {color rgb <1,0,0>}
  pigment { color rgb <1,1,0>}
plane {-y, 4
  pigment {color rgb <1,0,1>}
regards,
Chris B.
Subject: Re: Problem with differences/unions, maybe too many; or a missing "{" or "}=
Date: 24 Dec 2006 07:15:00
Message: <web.458e6e5b6987e0fd938f4fbd0@news.povray.org>
Thank you all!
Having not used POV-Ray for some monthes I just fall into the first pit :P
A Happy Christmas and a Good New Year to all of you and the whole POV-Ray
team and all contributors.
Greetings
Dieter Hansen
