Dear all,
I am trying to use povray to display the 3d distribution of a value (i.e.
temperature) as color mapped on the surface of a body. So when I do an
intersection with another object, to be able to see the color temperature
mapping on the interior of the first. The values I have is the temperature
for every voxel in space.
I tried to use the following:
intersection {
box { // initial object with the temperature mapping
<0,0,0>, <1,1,1>
translate <-0.5,-0.5,-0.5>
box { // Clipping object
<0,0,0>, <1,1,1>
inverse
interior {
media {
density {
density_file df3 "temp.df3"
interpolate 1
color_map {
[0.00 rgb <1,1,1>]
[0.10 rgb <1,0,1>]
[0.20 rgb <0,0,1>]
[0.40 rgb <0,1,0>]
[0.60 rgb <0,1,1>]
[0.80 rgb <1,0,0>]
[1.00 rgb <1,1,1>]
hollow
but I get a black screen. Is this the correct way of doing?
Vasilis nous apporta ses lumieres en ce 13/11/2006 09:40:
> Dear all,
> intersection {
> <0,0,0>, <1,1,1>
> <0,0,0>, <1,1,1>
> inverse
> interior {
> media {
> density {
> interpolate 1
> color_map {
> [0.00 rgb <1,1,1>]
> [0.10 rgb <1,0,1>]
> [0.20 rgb <0,0,1>]
> [0.40 rgb <0,1,0>]
> [0.60 rgb <0,1,1>]
> [0.80 rgb <1,0,0>]
> [1.00 rgb <1,1,1>]
> hollow
It's basicaly correct, but there is some things missing:
There is no light to make it visible, so you need ether a light_source or make
the media emissive.
Also, your containing box use the default pigment, witch is black and opaque.
Add pigment{rgbt 1} to make the container transparent.
Change is inevitable, except from a vending machine.
