POV-Ray : Newsgroups : povray.general : Re-render without new parsing Server Time
21 May 2025 01:08:55 EDT (-0400)
  Re-render without new parsing (Message 1 to 9 of 9)
Subject: Re-render without new parsing
Date: 12 Oct 2006 11:40:00
Message: <web.452e60d15b1e79155a402aa0@news.povray.org>
this might be an unusal question, but is there any possibility to run POVRAY
on the same scene using different parameters (e.g. antialiasing, viewport
extremly big files (>100Mb) which have to be rendered with different
options. It'd be really neat if there were an option that allows POVRAY to
cache the parsed .pov-file so it could be rendered several times using
different options.
kind regards
psy
Subject: Re: Re-render without new parsing
Date: 12 Oct 2006 12:16:10
Message: <452e6a4a@news.povray.org>
> si?ze) without actually reparsing the file?
  No.
  In a future version of POV-Ray probably yes. Not yet.
Date: 12 Oct 2006 14:41:59
Message: <452e8c77$1@news.povray.org>
news:452e6a4a@news.povray.org...
>> POVRAY
>  No.
   That's like... 15 years away..?
     ~Steve~
>                                                          - Warp
Date: 12 Oct 2006 20:47:13
Message: <452ee20f@news.povray.org>
  Not necessarily. The cleanup for SMP brings positive side-effects to the
core code.
Date: 13 Oct 2006 14:32:39
Message: <452fdbc7@news.povray.org>
news:452ee20f@news.povray.org...
the
> core code.
might not be the ideal place to ask, but
with all this cleaning of the code, is it still the POV-team's intention
to do a complete rewrite for POV-Ray 4 ?  Or will it be some kind of
gradual rewrite? :)
cu!
Date: 13 Oct 2006 16:13:43
Message: <452ff377$1@news.povray.org>
Zeger Knaepen wrote:
> "Warp" <war### [at] tagpovrayorg> wrote in message news:452ee20f@news.povray.org...
>> core code.
> with all this cleaning of the code, is it still the POV-team's intention to do a
complete rewrite for POV-Ray 4 ?  Or will it be some kind of gradual rewrite? :)
The answer is another question: Does it matter much? It is in the future, so
nothing is set in stone anyway.
	Thorsten
Date: 13 Oct 2006 16:25:54
Message: <452ff652$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:452ff377$1@news.povray.org...
future, so
it doesn't really matter to me, no.  As long as I can keep on tracing,
I'm happy :)
I was just wondering
cu!
Date: 14 Oct 2006 03:20:03
Message: <egq2un$rkl$1@chho.imagico.de>
To make sure this does not get misunderstood - nothing has changed about
the intention that the next major revision of POV-Ray ("POV-Ray 4.0") is
planned to be released under a new, OSI-compatible license.
Despite the major changes POV-Ray 3.7 is quite closely based on the 3.6
codebase in a lot of things - which isn't a bad things since this is
mostly well tested and reliable code.  This also ensures a high level of
backwards compatibility.
http://www.imagico.de/ (Last updated 20 Aug. 2006)
Date: 17 Oct 2006 00:07:58
Message: <4534571e@news.povray.org>
> different options.
This is internally supported in 3.7 but not tested and most likely will not
be implemented in the released version (i.e. the support is there* but we
would not necessarily enable it via the user interface or command-line since
it would require more testing and possibly delay the final release).
Once the source code is released it's possible** someone will add it.
-- Chris
* 3.7 is based on a 'scene/view' model where the act of parsing a scene is
  completely separate from rendering it (via a view). the view determines
  the camera location and type, output resolution, AA, and so forth.
** possible == 'next to certain' in this case IMO.
