POV-Ray : Newsgroups : povray.general : Problem by projecting fringes through lenses Server Time
7 Mar 2026 17:12:41 EST (-0500)
  Problem by projecting fringes through lenses (Message 1 to 3 of 3)
Subject: Problem by projecting fringes through lenses
Date: 5 Sep 2006 03:10:01
Message: <web.44fd225dcc224b6d337e73ab0@news.povray.org>
Hello,
I have problem using fringe projection through several lenses. Hereunder my
povray code. If i project fringe through a single lens, fringe shadow
appear clearly. But if i put another lens, also with photon properties, the
shadow appear as a simple black square.
I thank you in advance for any help !
Best regards from Switzerland and have a nice day !
My code:
/*INCLUDES
/* PHOTON TUNING
global_settings {
  photons {
    spacing .07
    gather 5,15
/* LIGHT APPEARANCE
#declare Lightbulb = union{
sphere { <0,0,0>,1 }
pigment {White}
/*BACKGROUND
background {color Cyan}
#declare ALP_H = 5;
#declare ALP_W = 5;
#declare nb_periods = 8;
#declare length_period = ALP_H / nb_periods;
#declare SinePig = pigment {
  gradient y
  scale ALP_H/nb_periods
  sine_wave
  color_map {
    [0 color <0,0,0> transmit 0]
    [1 color <0,0,0> transmit 1]
/* LENS PRIMITIVE
#declare R_LENS   = 55.0; // sphere radius (influences magnification)
#declare K_LENS = 0.995;   // overlapping coefficient (influences lens
diameter)
#declare Lens = intersection{
  sphere{<0,0,0>,R_LENS  translate <-K_LENS*R_LENS,0,0>}
  sphere{<0,0,0>,R_LENS  translate <K_LENS*R_LENS,0,0>}
  pigment {White filter 1}
  interior {ior 1.5}// index of refraction (Glass=1.5)
  photons {
    target //.25
    refraction on
    reflection off
/* PROJECTION SYSTEM (aligned along x axis and then rotated along z axis)
union{
            /* LENS(ES)
            object{Lens}
            object{Lens translate<-120,0,0>}
            /*SIGNAL GENERATION
            intersection{
              plane { x, 0
                pigment {SinePig }
                photons {
                  target //.5
                  refraction on
                  reflection off
                clipped_by {
                  box {
                    <-1,-ALP_H/2,-ALP_W/2>,
                    <1,ALP_H/2,ALP_W/2>
                translate <-1000,0,0>
            /*LIGHT SOURCE
            light_source {
             <-2000,0,0>
             2*White
             cylinder
             radius 10
             falloff 15
             point_at <0,0,0>
             looks_like { Lightbulb  }
            /* TRANSLATION AND ROTATION
            translate <-78,0,0>
            rotate <0,0,-45>
/*PLANE
plane {y,0 pigment {checker color Red*0.2 color Red*0.3 scale 0.5}}
/*CAMERA
orthographic // Telecentric
location 1*<0,10,0>
look_at <0,0,0>}
Subject: Re: Problem by projecting fringes through lenses
Date: 5 Sep 2006 04:30:01
Message: <web.44fd349fd13eec37f1cb1e660@news.povray.org>
"Louis-Severin" <lou### [at] a3epflch> wrote:
> Hello,
In the message pane you get the message below;
  Infinite objects:          2
  Light sources:             1
  Total:                     6
Possible Rendering Error: Maximum trace level reached! If your scene
contains black spots read more about the max_trace_level setting in the
documentation!
Render Statistics
Image Resolution 320 x 240
Pixels:            76800   Samples:           76800   Smpls/Pxl: 1.00
Rays:             443610   Saved:                 0   Max Level: 5/5
In the global settings add a line for max_trace_level
Such as;
/* PHOTON TUNING
global_settings {
  max_trace_level 10
  photons {
    spacing .07
    gather 5,15
Date: 5 Sep 2006 12:10:00
Message: <web.44fda052d13eec37337e73ab0@news.povray.org>
Hello,
Thank you very much for your help ! It's perfect now !
Best regards,
> > Hello,
>   Infinite objects:          2
>   Light sources:             1
>   Total:                     6
> documentation!
> Render Statistics
> Such as;
> /* PHOTON TUNING
> global_settings {
>   max_trace_level 10
>   photons {
>     spacing .07
>     gather 5,15
