Hello,
I try to simulate the projection, through distorting lenses, of a sinusoidal
grid. I found (thanks to Alain !) how to use photon option to project the
shadow of an object through a lens. But actually, my sinusoidal grid is
performed using a texture option. Accordingly, the projected shadow is the
one of the object and not the one of the texture. Is it any solution to
produce the shadow of a texture ? Hereunder my code to generate the
sinusoidal grid:
#declare H = 2;
#declare W = 2;
#declare nb_periods = 3;
#declare length_period = H / nb_periods;
intersection{
// container
box{
<-H/2,-1,-W/2>
<H/2,1,W/2>
pigment {transmit 1}
// signal
plane {
y, 0 hollow
gradient x scale H/nb_periods
sine_wave
color_map {[0 rgb 1] [1 rgbf 1]}
The resulting shadow is the one of the box and not the one of the signal. If
anyone could help me, i should be very grateful ! Thanks in advance...
>... Is it any solution to
A hollow plane is still conceptually solid for CSG,
a intersection of a plane and a box results in a box...
By texturing the box with Clear on 5 sides you just
see into the hollow box, if the box happens to be
sitting with a clear bottom that is coincident to
some other object (like the default checkered
plane) then you see thru that as well. Since you
only really want the textured side, use clipped_by.
And since you are trying to "fake" shadows, you
probably don't want to see the texture itself.
I might be OK just to make your texture mimic
the shadow color, then place it near a flat surface,
or use the object pattern to place it as a partially
transparent layer on something.
#declare H = 2;
#declare W = 2;
#declare SinePig = pigment {
sine_wave
color_map {
[0 color <0,0,0> transmit 0.2]
[1 color <0,0,0> transmit 1]
// as a "sticker"
plane { y, 0
pigment { SinePig }
clipped_by {
box {
<-H/2,-1,-W/2>,
<H/2,1,W/2>
translate <0,-0.999,0>
// as an object pattern
plane {y,-1
pigment{checker White Wheat}
object {
sphere {<0,-1,2>,1}
pigment {Clear}
pigment {SinePig}
Hello,
Thank you really, the solution with the "sticker" works perfectly !
Best regards from Switzerland,
> #declare H = 2;
> #declare W = 2;
> sine_wave
> color_map {
> // as a "sticker"
> plane { y, 0
> pigment { SinePig }
> clipped_by {
> box {
> <-H/2,-1,-W/2>,
> <H/2,1,W/2>
> plane {y,-1
> texture {
> texture {
> pigment {
> object {
> sphere {<0,-1,2>,1}
> pigment {Clear}
> pigment {SinePig}
