POV-Ray : Newsgroups : povray.general : Unexpected results with prisms Server Time
7 Mar 2026 17:02:01 EST (-0500)
  Unexpected results with prisms (Message 1 to 4 of 4)
Subject: Unexpected results with prisms
Date: 25 Aug 2006 03:35:00
Message: <web.44eea77dd88dd40f9bc721f00@news.povray.org>
I've been doing various things with conic-swept prisms, and I've been
getting some very unexpected results. I tried reducing my problem to a
simpler scene file, and though it did not come up with exactly the same
unexpected results as before, it's still not working as I expected. Here is
a simple example. With a normal perspective camera, it is a nice square
pyramid. With a directly overhead orthogonal view, however, the whole thing
appears green. Though I am not sure, from my previous experimentation I
believe that only the base is appearing, and not the walls of the pyramid,
similar to results one receives when using back-face culling with reversed
normals.
//camera {location <5, 7, 2> look_at <1,0,0>}
camera {orthographic location <0, 10, 0> look_at <0, 0, 0> up x*3 right z*4}
light_source {<5,5,5> rgb 1}
difference {
    prism {
        conic_sweep
        linear_spline
        0, 1, 5,
        <-1, 1>, <1, 1>, <1, -1>, <-1, -1>, <-1, 1>
        scale <1, -1, 1>
        translate y*1
        gradient y
        color_map {
        [0.0 color <0, 1, 0> ]
        [1 color <0, 0, 1> ]
        scale y*.2
    finish {ambient .5}
Subject: Re: Unexpected results with prisms
Date: 25 Aug 2006 03:45:00
Message: <web.44eea9b5cc351d989bc721f00@news.povray.org>
Oops, don't ask why I put it in a difference, I was doing a more complicated
example before. Now that part can be deleted.
> normals.
> difference {
>     prism {
>         conic_sweep
>         linear_spline
>         0, 1, 5,
>         scale <1, -1, 1>
>         translate y*1
>     pigment {
>         gradient y
>         color_map {
>         scale y*.2
>     finish {ambient .5}
Date: 25 Aug 2006 04:04:59
Message: <44eeaf2b$1@news.povray.org>
"clum" <nomail@nomail> wrote in message
news:web.44eea9b5cc351d989bc721f00@news.povray.org...
> complicated
>> is
>> thing
>> pyramid,
>> reversed
>> normals.
>> z*4}
>> difference {
>>     prism {
>>         conic_sweep
>>         linear_spline
>>         0, 1, 5,
>>         scale <1, -1, 1>
>>         translate y*1
>>     pigment {
>>         gradient y
>>         color_map {
>>         scale y*.2
>>     finish {ambient .5}
Hi Clum,
If you change the camera to
  camera {orthographic location <0.0000001, 100, 0> look_at <0, 0, 0> up x*3
right z*4}
it should fix this particular problem (possibly not some of the others you
elude to).
I can't recall the exact reason for this problem, but it's to do with having
the camera directly over the look_at point, which I think used to raise an
error in earlier versions of POV-Ray. I think it's something to do with
divide-by-zero errors that arise quite a lot when calculating for that
particular condition.
Chris B.
Date: 25 Aug 2006 04:35:00
Message: <web.44eeb5afcc351d989bc721f00@news.povray.org>
Thanks, that fixed all of my problems. I was trying to make an overhead 2-d
"map" of my scene, and all of the prisms weren't rendering correctly, but
now they are.
