I'm trying to model the Earth's atmosphere (as a sphere) using scattering
media.
The atmosphere's density follows a e^(height) type function.
The available wave types don't seem to include this. I've played with
spherical mapping and poly and cubic wave types,but it's unsatisfactory so
far.
Is there a way for me to create a radial density pattern of A^Br, where 'r'
is the radius and A and B are constants?
-Eric
>media.
>far.
You can use any function{} as a media density pattern
http://www.econym.demon.co.uk/isotut/patterns.htm#density
You could #include functions.inc and use f_r(x,y,z) as an expression for
r, or you could use pow((x*x+y*y+z*z),0.5).
Mike Williams
Gentleman of Leisure
Thank you! I'd been unable to find that in the docs, and was hoping it was
possible. This works far better than the poly_wave approximation I tried
before.
-Eric
"Eric Buddington" <ebu### [at] wesleyan edu> wrote in message
news:web.44ee43068f5cf101abef64010@news.povray.org...
> media.
> far.
Does this include the troposphere, stratosphere, mesosphere, ozone, etc? Or
is it just a simple function?
-Nekar Xenos
"The truth is out there"
> > media.
> > far.
It uses the barometric formula
(http://en.wikipedia.org/wiki/Barometric_formula)
to calculate air density (assuming constant temperature, so it's just
Ae^B(height)), and uses Raleigh (type 4) scattering on that density. I then
scale it to earth size, and squash it to fit the Earth's ellipsoidosity
(That's a word. Really. I bet.)
It seems a little too thin overall, probably because there's a fair amount
of absorption and isotropic scattering in the troposphere that I haven't
added yet.
Clouds would be cool to add, but I think very computationally expensive to
do well (this is video, so I can't afford even 15 minutes per image)
-Eric
I think the word is ellipticity, or you can use oblateness, since the earth
is an oblate spheroid shape. Though flattening, or equatorial bulge are
probably more descriptive terms.
sphere {0,1 scale (7900/7927)*y}
I did something similar before. I modified the densities in mediasky.pov
according to info from http://en.wikipedia.org/wiki/Earth's_atmosphere and
http://en.wikipedia.org/wiki/Ozone_layer
Interestingly the sky wouldn't look right untill I added the ozone layer.
Unfortunately I have lost these files and I have to do it all over again some
time.
/* Nekar Xenos */#local N=<-20,40,100>;#local K=<20,-40,100>;#local R=seed(0);
blob{#while((K-N).x>0)#local X=N;#local N=N+<rand(R),rand(R),1>/3;#local N=(
vlength(N-K)<vlength(X-K)?N:2*X-N);sphere{<N.y,-N.x,N.z>,1,1 scale .02}sphere{N
,1,1 scale.02}sphere{<-N.x-40,N.y,N.z>1,1 scale.01}sphere{<N.x+40,-N.y,N.z>1,1
scale.01 }#end pigment{rgbt 1}interior{media{emission <2,4,5>*5}}hollow}
