POV-Ray : Newsgroups : povray.general : Need Help With Radiosity Server Time
23 Jul 2025 23:45:49 EDT (-0400)
  Need Help With Radiosity (Message 1 to 10 of 11)
Subject: Need Help With Radiosity
Date: 17 Aug 2006 10:45:00
Message: <web.44e480a7f1ba7a5c744ea2480@news.povray.org>
Hello......I am hoping somebody can help me with radiosity settings.  I
import my scenes into PovRay from Chief Architect, and almost all of the
settings I need automatically come with my import, but the scenes are set
to no radiosity.  I need to up the quality of light in my renderings, but
have no idea how to set radiosity to what would be a medium-high level.
Can somebody please give me very specific instructions on how to do this (I
have tried reading the documentation with PovRay and I don't understand at
all how to do this!)
Thanks in advance,
Cheri
Subject: Re: Need Help With Radiosity
Date: 17 Aug 2006 11:03:23
Message: <44e4853b@news.povray.org>
>Thanks in advance,
>Cheri
A good starting point would be to #include "rad_def.inc" and then follow
the instructions in that file to try out some of the different types of
settings.
Hope this helps,
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 17 Aug 2006 14:36:04
Message: <44e4b714$1@news.povray.org>
"Cherry363" <che### [at] gmailcom> wrote in message
news:web.44e480a7f1ba7a5c744ea2480@news.povray.org...
> (I
In addition to Sherry's advice, if you need further help, you could also
post a sample scene to the povray.binaries.images group.  Good radiosity
settings are generally very dependent upon the other lighting and objects in
an image.  In other words, what works well in one situation will not work
well in another.
Another short answer is simply to keep increasing "count" and keep lowering
"error_bound" until you see something that looks good.  That barely
scratches the surface, if you want good quality that renders in a reasonable
time, but it's a good start.
e.g.
global_settings {
  assumed_gamma 1.0
  radiosity {
    count 200
    error_bound 1
Decreasing "error_bound" (imho) will create deeper shadows, whereas
increasing "count" will make smoother shadows (meaning fewer blotchy
spots/artifacts).
Date: 18 Aug 2006 00:05:00
Message: <web.44e53bf7630de5424433558a0@news.povray.org>
> > (I
> well in another.
> e.g.
> global_settings {
>   assumed_gamma 1.0
>   radiosity {
>     count 200
>     error_bound 1
> spots/artifacts).
Sorry to be such a bother, but I tried to enter the settings you suggested
and I keep getting errors....this is how I entered it:
global_settings {radiosity {count 200, error_bound 1}{ max_trace_level 100
ambient_light rgb<0.830000, 0.830000, 0.830000> assumed_gamma 1.0}
// sunlight
light_source { < 4226.182699, 14281.480312, 9063.078165 >, rgb <1.000000,
1.000000, 1.000000>
  parallel point_at < -0.422618, -1.428148, -0.906308 > fade_power 0}
The radiosity line keeps getting errored....what am I doing wrong?
Date: 18 Aug 2006 00:39:47
Message: <44e54493$1@news.povray.org>
news:web.44e53bf7630de5424433558a0@news.povray.org...
> // sunlight
> 1.000000, 1.000000>
To have a good radiosity scene, I normally turn off ambient_light.  In this
case, I think that is what's getting in the way.
change it to say:
"ambient_light off" for a full radiosity scene
It's possible that this could cause you other problems (if everything goes
black), but if it's a radiosity scene, even with relatively "weak"
radiosity, you should be fine.
I hope that helps.  If not, we'll figure it out.
Jeremy M. Praay
www.beantoad.com
Date: 18 Aug 2006 11:20:00
Message: <web.44e5d9b2630de5424433558a0@news.povray.org>
> > // sunlight
> > 1.000000, 1.000000>
> change it to say:
> Jeremy M. Praay
> www.beantoad.com
Hi everyone!
Thanks for all the help so far.  I'm trying to implement your ideas, but I
keep getting errors on the radiosity line.  The problem is this.....I do
not understand how to change the global settings line.  I don't know how to
enter things in the right order, or place.  What would really help me, is
for somebody to copy and paste EXACTLY what the global settings block
should look like, from top to bottom, with everything shown.  Because I
have no idea whatsoever what any of these settings mean, or where to put
them.  It is very frustrating, because Chief Architect uses the PovRay
program, but my CA is malfunctioning and the internal PovRay won't work.
In Chief, all you have to do is select the level of radiosity (none, low,
med, or high), select the level of anti-aliasing, and click start.
Super-easy.  No need to enter settings, no need to know the PovRay
language.....it's all just done automatically!  I just really need to "see"
what the block should look like with high radiosity settings.
Thanks in advance!
Date: 18 Aug 2006 11:21:46
Message: <44e5db0a@news.povray.org>
>// sunlight
>1.000000, 1.000000>
It looks to me like you've just got some misplaced brackets.  Try this:
global_settings {
  radiosity {
    count 200
    error_bound 1
  max_trace_level 100
  ambient_light rgb < 0.830000, 0.830000, 0.830000 >
  assumed_gamma 1.0
light_source {
  rgb < 1.000000,1.000000, 1.000000 >
  parallel
  fade_power 0
--Sherry Shaw
Date: 18 Aug 2006 22:47:15
Message: <44e67bb3$1@news.povray.org>
Cherry363 nous apporta ses lumieres en ce 18/08/2006 00:03:
The opening brace "{" before max_trace_level must go. This cause an error as
your braces are unmatched.
> // sunlight
> 1.000000, 1.000000>
Always COUNT your braces. Make sure that they are matched in a way that makes sence.
Your bracing is as follow: {{}{}light_source{}} whitch places your light INSIDE
the global_settings block, whitch is not allowed, causing your error.
In radiosity scenes I usualy add this line:
default{finish{ambient 0 diffuse 1}}
This prevent objects from emiting light by themself.
Remember that any object with a finish different from zero will actualy emit
light in a radiosity scene. It can cast darkness if the ambient is set to a
negative value.
The ambient_light in global_settings is multiplied to the ambient value that you
set in the finish of your objects. You don't need to alter ambient_light in the
global_settings unless you want to globaly alter the colour of the ambient part
of your finish. Setting it to zero, as some often propose, will dissable any
ambient object you may want to use to illuminate your scene.
What happens if you get scared half to death twice?
Date: 18 Aug 2006 23:03:47
Message: <44e67f93@news.povray.org>
Cherry363 nous apporta ses lumieres en ce 18/08/2006 11:16:
>>> // sunlight
>>> 1.000000, 1.000000>
>> change it to say:
>> Jeremy M. Praay
>> www.beantoad.com
> Hi everyone!
> Thanks in advance!
Strict minimum global_settings for a radiosity scene using all default parameters:
global_settings{radiosity{}}
With high settings:
global_settings{
	radiosity{pretrace_start 0.08 // tiles of 8% of the render size for the
pretrace part
		pretrace_end 0.00125 // tiles of 0.125% the render size. 7 pretrace steps.
		count 1600 // Maximum value allowed. Affect rendering speed.
		error_bound 0.2 // Big effect on rendering speed.
		low_error_factor 0.1 // how much error_bound is reduced during the last
pretrace step.
		nearest_count 20 //integer, 4 to 20
		media on // OPTIONAL! If you have emissive media that you want to shed light.
		normal on // OPTIONAL! To enable normal to be evaluated for the radiosity.
Huge effect on the render speed.
It's advisable to place the radiosity block before or after everything else, on
it's own line(s), as it can improve readability.
Q. What's the difference between Batman and Bill Gates?
A. When Batman fought the Penguin, he won.
                                            -- J. Levine
Date: 24 Aug 2006 08:20:00
Message: <web.44ed9965630de542fc1dc6790@news.povray.org>
The problem is the comma (,) between the count and error bound.
global_settings { radiosity { count 200 error_bound 1} // and so on }
should get rid of the error messages.
jussi
