POV-Ray : Newsgroups : povray.general : povray for isosurfaces plots? (quantum physics) Server Time
21 May 2025 07:15:09 EDT (-0400)
  povray for isosurfaces plots? (quantum physics) (Message 1 to 10 of 11)
Subject: povray for isosurfaces plots? (quantum physics)
Date: 10 Aug 2006 09:40:01
Message: <web.44db361920f88a35ed745e5c0@news.povray.org>
hello,
i'm wondering is it possible to plot an isosurfaces (density) 3D-plots based
on the complex double precission numbers (ASCI file)? i haven't got explicit
formula for this surface, data comes from my numerical calculations...
i need to know it before i start learning povray
(because maybe it isn't a software which i'm looking for)
regards,
gawryl
Subject: Re: povray for isosurfaces plots? (quantum physics)
Date: 10 Aug 2006 10:18:54
Message: <44db404e@news.povray.org>
"gawryl" <gaw### [at] gmailcom> wrote in message
news:web.44db361920f88a35ed745e5c0@news.povray.org...
> hello,
> based
> explicit
> regards,
> gawryl
Hi Gawryl,
Just to clarify what you're trying to do a little:
It sounds like you will have a file containing a series of 3D coordinates
that represent points on a surface and that you will then want to plot them
and generate a 3D image of the results - is that right?
The next question is whether you want to generate a 3D surface from these
points or just to plot the points themselves to illustrate the density of
the points as they are distributed around the conceptual surface?
If you just want to display a dot at each location, then it should be quite
easy to format the input file as an ASCII CSV file with the coordinates of
each point on a single line in the file, then write a short POV-Ray macro to
read each point and place a sphere at each location.
If you want to draw a surface then it gets a bit more tricky because you
need something that's going to work out how to join all of your points
together and in which sequence etc. So you'd probably be better off
pre-processing the set of points using some external tool to generate a mesh
object that could potentially then be fed into POV-Ray to render.
Chris B.
Date: 10 Aug 2006 10:45:01
Message: <web.44db4583f98bfec2dcd30180@news.povray.org>
> Regards,
> Chris B.
First of all - thanks for you help ;-)
Yes, I'm thinking about the surface but maybe your idea with points
(spheres) is also good. So - could you help me and send an example code
with an answer how to do this?
My data is 3d grid of real numbers (for simplicity) - feel free to chose
your own favorite format - i can reorganize my data - and i need to choose
color of particular sphere at point (x,y,z) as a some functions, witch
depends of a value of this point f(x,y,z).
regards,
gawryl
Message: <web.44db463ff98bfec2b1b469160@news.povray.org>
"gawryl" <gaw### [at] gmailcom> wrote:
> hello,
> regards,
> gawryl
format to create images using emitting media. I believe that there is a
programme called df3maker that can create these files from a text file.
http://news.povray.org/povray.general/thread/%3C3### [at] yahoocomau%3E/
If you have the data in slices like a MRI scan you can use tga2df3 to create
some manipulation of colour maps they can be polychromatic as well. I
cannot say what the precision of programmes are.
Date: 10 Aug 2006 10:47:41
Message: <XzLWjLAIU02EFwb9@econym.demon.co.uk>
Wasn't it gawryl who wrote:
>hello,
If you can convert your data into .df3 format then POVRay can deal with
it. It's good at displaying media where the foggyness is controlled by
the density values in the data. It's not so good at plotting isosurfaces
from the points where the data has a particular value, the surfaces tend
to end up looking like a collection of boxes.
See http://www.econym.demon.co.uk/isotut/patterns.htm#density
Mike Williams
Gentleman of Leisure
Date: 10 Aug 2006 11:52:00
Message: <44db5620$1@news.povray.org>
news:web.44db4583f98bfec2dcd30180@news.povray.org...
>> mesh
>> Regards,
>> Chris B.
> regards,
> gawryl
Hi Gawryl,
Judging from the responses from Mike and Stephen, df3 sounds like a pretty
good way to go and would give you a whole range of options for displaying
your data. If your data is actually a uniform grid rather than a random set
of points then you should also be able to use some of the mesh generating
macros available for POV-Ray to generate a surface.
On the other hand, if you just want to generate dots from a set of points
stored in a CSV file you could do this with a POV-Ray scene file containing
the following statements:
camera {location <0, 2, -10> look_at <0,2,0>}
light_source { <0, 50, -30> color 1}
#declare Radius = 0.2;
#fopen InputFile "ngtemp125.csv" read
#while (defined(InputFile))
  #read (InputFile, PosX, PosY, PosZ)
  #declare ThisPosition = <PosX, PosY, PosZ>;
  #declare ThisColour   = ThisPosition/4;
  sphere {ThisPosition, Radius pigment {rgb ThisColour}}
This would read a file called 'ngtemp.csv' containing your numbers in sets
of three, separated by commas.
For example:
1,3,8,
1.8938846629843754,3.2984375429843754,1.9877653387655554,
2.1487437664643754,3.9238757989843754,2.4835774777755554,
3.8938846629843754,4.2984375429843754,3.9877653387655554,
In the case above I've simply based the colour of each sphere upon the
position of the dot, but it's quite possible to incorporate more
sophisticated functions to define the colour, or to add the RGB colour
components to the CSV file and just read six values for each position.
Chris B.
Date: 10 Aug 2006 18:00:00
Message: <web.44dbaba1f98bfec2dcd30180@news.povray.org>
my datas are stored in ASCI tex files, in my own format, so i'm interested
in
df3maker software. Finally, i have found only M$ Windows version of this
software but I'm using Linux ! does anybody have got the Linux version of
it ?
> Stephen
Thanks Stephen,
    best regard ----- gawryl
Date: 10 Aug 2006 18:30:00
Message: <web.44dbb331f98bfec2dcd30180@news.povray.org>
> Regards,
> Chris B.
thanks again for your help Chris :)
I slighty modyfied your's code (i have add Hue value as a 4-th parameter in
the data source file) and get quite nice (for me, of course) results (see
pictures at http://alpha.uwb.edu.pl/gawryl/edh/povray-tests.html).
my question - how can i create cloud like (as opposed to a solid) spheres -
is it simple? Stephen was mension something about it in contets of MRI
scan...
regards,
gawryl
Date: 10 Aug 2006 19:13:32
Message: <44dbbd9c$1@news.povray.org>
news:web.44dbb331f98bfec2dcd30180@news.povray.org...
> in
Wow, That was quick.
> spheres -
> scan...
> regards,
> gawryl
Hi Gawryl,
There are quite a few ways. You'd probably want to look at the media
tutorial in the POV-Ray help files (enter the keyword 'media' in the index).
A quick and dirty way of doing something similar is to just add some
transparency to the colour definition, so instead of
pigment {color rgb <1,0,0>}
you can specify
pigment {color rgbt <1,0,0,0.7>}
to give you a red colour with 70% transparency.
Note, that you'll probably need to increase the max_trace_level to get rid
of black regions and the corresponding error message in the message log. You
can do this by adding a line such as
  global_settings { max_trace_level 30}
to the top of your scene file. This slows down the render a fair bit, so you
should keep an eye on the message log to optimise this setting
Chris B.
Date: 11 Aug 2006 12:40:01
Message: <jdouq3-7ns.ln1@badulaque.unex.es>
Among other things, gawryl saw fit to write:
> based on the complex double precission numbers (ASCI file)? i haven't got
> explicit formula for this surface, data comes from my numerical
> calculations...
In case you don't know it, there's a program called VMD
(<http://www.ks.uiuc.edu/Research/vmd/>) which you may find useful. It can
display isosurfaces from volumetric data in OpenGL, have a look at section
7 of this tutorial:
<http://www.theochem.ruhr-uni-bochum.de/~axel.kohlmeyer/cpmd-vmd/index.html>.
By the way, it can also export to POV-Ray (as a mesh, I guess), so you can
fiddle with lighting and textures afterwards.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
