POV-Ray : Newsgroups : povray.general : Several views of the same model Server Time
26 Aug 2025 19:00:10 EDT (-0400)
  Several views of the same model (Message 1 to 5 of 5)
Subject: Several views of the same model
Date: 30 Jul 2006 05:05:00
Message: <web.44cc75a72fecdf33a1174f60@news.povray.org>
Let's say I wanted to render several views of the same model in one image,
but didn't want the objects interfering with each other (shadows and
reflections, and such). Could I just surround each model with a box with
the no_shadow and no_reflection attributes set?
How could I accomplish this?
Subject: Re: Several views of the same model
Date: 30 Jul 2006 05:15:01
Message: <web.44cc78496c8173dd4c8475090@news.povray.org>
Render each of the views, then open the resulting images in an image editor
and move them around until you like the result.
Date: 30 Jul 2006 16:00:43
Message: <44cd0feb$1@news.povray.org>
"nomail" <nomail@nomail> wrote in message
news:web.44cc78496c8173dd4c8475090@news.povray.org...
>> image,
You can make an animation of the different views and in the final frame
of animation use image maps of the first frames in an orthographic camera
to paste them together automatically.
#switch(clock)
#case(0)
   camera{}
#break
#case(0.25)
   camera{}
#break
#case(0.5)
   camera{}
#break
#case(0.75)
   camera{}
#break
#case(1)
         orthographic
         location <0,0,1>
         look_at  <0,0,0>
         right 1*x
         up 1*y
      light_source {
         <0, 0, 30>
         color rgb <1, 1, 1>
         parallel
      box { // this box fits exactly in view
         <-0.5, -0.5, 0>, <0.5, 0.5, 0>
            pigment{ //front
               image_map {
                  sys "file1.bmp"
                  once
               scale 0.5
               translate <0,-0.5,0>
            pigment{ //top
               image_map {
                  sys "file2.bmp"
                  once
               scale 0.5
               translate <0,0,0>
            pigment{ //right
               image_map {
                  sys "file3.bmp"
                  once
               scale 0.5
               translate <-0.5,-0.5,0>
            pigment{ //corner
               image_map {
                  sys "file4.bmp"
                  once
               scale 0.5
               translate <-0.5,0,0>
#break
#if (clock != 1)
scene
Date: 30 Jul 2006 22:15:01
Message: <web.44cd66f36c8173ddeeb007370@news.povray.org>
> >> image,
Ack! That sounds too complicated.
Thanks anyway!
The method I've found most worthy of trying, so far, involves placing a
plane between each rotated model that is the same color as my background. I
then turn the plane so that it's parallel with the camera.
Date: 30 Jul 2006 23:35:26
Message: <ugRoHlA3mXzEFwFr@econym.demon.co.uk>
There's a facility in MegaPov that allows several views to be combined
in a single render. You can use one view of the scene as a pigment on an
object within the scene.
In your case, you want to arrange things so that the boxes on which
you're displaying the views are not visible within any of the
camera_views, like the camera_views/subviews.pov example.
Mike Williams
Gentleman of Leisure
