POV-Ray : Newsgroups : povray.general : Fog and Media sphere Server Time
5 May 2026 13:08:05 EDT (-0400)
  Fog and Media sphere (Message 1 to 7 of 7)
Subject: Fog and Media sphere
Date: 7 Jun 2006 15:45:01
Message: <web.44872c3c307411394e7319190@news.povray.org>
This is my first message here, so I will introduce myself briefly :
I live in the south of France, I'm 36 and in real life, I'm ground
instructor in a flight school. I've used Povray 10 years ago, when my PC
needed to compute all night long to display the famous yellow ball ;-)
I started again raytracing a few days ago, and here is my first problem (I
didn't find any solution searching the web and the news) :
I want a fire in my fog :-)
The problem is that my sphere containing the media is visible in the fog :
http://www.chezgligli.net/img/light_fog_01.jpg
I had the same problem with the water reflection and no fog, but with
max_trace_level 10 it disappeared :
http://www.chezgligli.net/img/light_fog_02.jpg
Hope someone can help ;-)
Here is the scene, the sphere and the fog are at the end :
global_settings
  max_trace_level 10
#include "textures.inc"
camera
    location  <0, 2, -26>
    look_at <0,0,10>
light_source
    <0, 0, 0>, rgb <1, .2, 0>
    translate <0, 5, 150>
plane
    y, -1
    pigment
        bozo
        pigment_map
            [0.1 color <0, .5, .7>]
            [0.3 color <.3, .8, .7>]
            [0.6 color <.2, .6, .5>]
            [0.9 color <0.2, .2, .9>]
        turbulence .5
// L'eau / Water
box
    <-150, -.9, -100>, <150, -.8, 1000>
    texture
        pigment
            rgbf 1
        normal
            ripples 0.75
            frequency 2
            scale y*.1
            turbulence .1
        finish
            reflection {0.1, 1 fresnel}
            conserve_energy
    interior
        ior 1.33
// Le Soleil / the Sun
sphere // transparent sphere containing media
    0, 1 pigment { rgbt 1 } hollow
    interior
        media
            emission 1
            density
                spherical density_map
                    [0 rgb <0, 0, 0>]
                    [0.5 rgb <1, .3, 0>]
                    [1 rgb <1, 0, 0>]
    scale 30
    translate <0, 5, 200>
  sky_sphere {
      gradient y
      color_map {
        [0.000 0.002 color rgb <1.0, 0.2, 0.0>
                     color rgb <1.0, 0.2, 0.0>]
        [0.002 0.200 color rgb <1.0, 0.2, 0.0>
                     color rgb <0.2, 0.2, 0.3>]
      scale 2
      translate -1
    rotate -95*x
// Flammes / Flames
sphere
    <0,0,0>, 1
    hollow
   no_shadow
    pigment {rgbf 1}
    scale <.6, 1, .3>
    interior
        media
            intervals 5
            samples 5
            emission 6
            absorption 1
            density
                spherical
                scale <5, 25, 4>
                warp
                    turbulence 10 lambda 2 octaves 4
                density_map
                    [0 rgb 0]
                    [.5 rgb 0]
                    [.7 color Orange]
                    [.8 color Orange]
                    [.9 color Red]
                    [1 color Red ]
    translate <2, 2, -20>
// Brouillard / Fog
#declare Brouillard=1;
#if(Brouillard)
    fog
        distance 8
        color rgbf<.8, .9, .8, 1>
        fog_type 2
        fog_offset 2
        fog_alt 1
        turbulence <1, 1, 1>
        turb_depth .8
        octaves .2
        lambda .5
        omega 1
Subject: Re: Fog and Media sphere
Date: 7 Jun 2006 15:49:09
Message: <44872db5@news.povray.org>
If I remember correctly, there are some issues related precisely to
the combination of fog and transparent objects (I don't remember if
media was necessary to trigger the misbehaviour or not). IOW there's
some kind of bug relating to this in POV-Ray and I don't know of a
simple way around it.
Date: 7 Jun 2006 22:54:40
Message: <44879170@news.povray.org>
> #if(Brouillard)
>     fog
>         distance 8
>         fog_type 2
>         fog_offset 2
>         fog_alt 1
>         turb_depth .8
>         octaves .2
>         lambda .5
>         omega 1
> #end
Remove the filter component from your fog color and it should work, i.e.
"color rgb<.8, .9, .8>".
I forget the long explanation behind this, but I had the same issue for
my "mystery lights" IRTC entry, and there was a good description posted
here when I asked.  The final answer though was that fog with a filter
component results in an incorrect calculation along the length of the
ray so you end up seeing the media container.
RG
Date: 8 Jun 2006 01:05:01
Message: <web.4487af9da15f45264e7319190@news.povray.org>
It works !
Thank you very much :-)
Date: 8 Jun 2006 15:29:35
Message: <44887a9f@news.povray.org>
I rendered it. Hmm... It reminds me somehow for a beautiful sunset in the
ocean. But just partially. I am curious what the final result will be...
Greetings,
Sven
Date: 10 Jun 2006 06:25:00
Message: <web.448a9cf3a15f45264e7319190@news.povray.org>
Well, I just gave you the parts of the scene that were the problem. Since I
had to chose a subject for my first work, I'm trying the IRTC theme "Light
and Fog".
No chance to have a prize, of course, but the important thing is to take
part ;-)
Is it ok to show the picture here or do I have to wait the end of the
competition ?
Date: 10 Jun 2006 13:00:20
Message: <448afaa4@news.povray.org>
news:web.448a9cf3a15f45264e7319190@news.povray.org...
> part ;-)
Of course :-)
> competition ?
It's ok but not quite here, on povray.binaries.images
Marc
