POV-Ray : Newsgroups : povray.general : image_map with map_type CUBE ? Server Time
26 Aug 2025 21:53:10 EDT (-0400)
  image_map with map_type CUBE ? (Message 1 to 3 of 3)
Subject: image_map with map_type CUBE ?
Date: 27 May 2006 09:20:01
Message: <web.4478511baaed6a2be31c21340@news.povray.org>
Is there a way to have default mapping of image_maps into "cube" -mapping on
 normals of objects - like in " Flat/Cube/Tube/Sphere " in Blender ?
only planar....?
thank-you :-)
Milovann
Subject: Re: image_map with map_type CUBE ?
Date: 27 May 2006 22:54:03
Message: <447910cb@news.povray.org>
> only planar....?
> thank-you :-)
You can change the map type.  From the docs, section "3.5.12.7.2  The
map_type Option", you can read:
"A map_type 0 gives the default planar mapping [...]
A map_type 1 gives a spherical mapping [...]
With map_type 2 you get a cylindrical mapping [...]
Finally map_type 5 is a torus [...]
Types 3 and 4 are still under development"
I'm not sure if it's possible to use normals as references in to
pigments, which is basically what you're asking.  However, the following
might be possible:
1. Compute a function for your normals, based on the location of a point
on the surface.  This is easy for some shapes (ie a sphere, where the
normal of a given point is the location of that point scaled to be a
unit vector), impossible for others (meshes), and somewhere inbetween
for others.  If you know the exact shape you would like to use, you can
post here and we will try to help you out.
2. Use this function as your pigment.
3.  Use a spherical image_map.
...Chambers
PS This might be one of those times I'm full of it, so take this
suggestion with a grain of salt.
Date: 28 May 2006 12:02:04
Message: <pan.2006.05.28.16.02.00.400183@almost.bestweb.net>
On Sat, 27 May 2006 19:53:58 -0700, Ben Chambers wrote:
>> -mapping on
>> only planar....?
>> thank-you :-)
> "A map_type 0 gives the default planar mapping [...] A map_type 1 gives a
> spherical mapping [...] With map_type 2 you get a cylindrical mapping
> [...] Finally map_type 5 is a torus [...]
> I'm not sure if it's possible to use normals as references in to pigments,
> which is basically what you're asking.  However, the following might be
> possible:
> normal of a given point is the location of that point scaled to be a unit
> vector), impossible for others (meshes), and somewhere inbetween for
> others.  If you know the exact shape you would like to use, you can post
> ...Chambers
map image onto a cube:
box {
  -0.5, 0.5
  uv_mapping
    image_map {
      tga "some_pic.tga"
  finish { ambient 0.5 diffuse 0.5 }
  rotate y*20
  rotate x*-20
You might want to peruse the docs for better & more detailed
information on this matter.
It could be that I have misunderstood the question, in which
case I am sorry and please ignore this message.
to all the companies who wait until a large user base becomes
dependent on their freeware, then shafting said happy campers with
mandatory payment for continued usage. I spit on your grave.
