POV-Ray : Newsgroups : povray.general : Background Image Server Time
7 Mar 2026 22:25:24 EST (-0500)
  Background Image (Message 1 to 5 of 5)
Subject: Background Image
Date: 29 Apr 2006 07:45:01
Message: <web.445350c4b8907d159c45cf0f0@news.povray.org>
Is it possible to put an image (instead of a color)as a background in a
scene ?
thanks
Subject: Re: Background Image
Date: 29 Apr 2006 09:33:24
Message: <44536b24$1@news.povray.org>
> scene ?
> thanks
Yes.  Apply the image to a large polygon and put the polygon in the
background.
John
Date: 29 Apr 2006 10:30:00
Message: <web.445377325ecbd4a99c45cf0f0@news.povray.org>
John VanSickle <evi### [at] hotmailcom> wrote:
> > scene ?
> > thanks
> background.
> Regards,
> John
Can you please give me a small example...because I tried:
polygon {
    4,
    <0, 0>, <0, 300>, <300, 300>, <300, 0>
      finish { ambient 1 diffuse 0 }
      pigment { image_map { gif "test.gif"  } }
and the image repeats instead of having the whole picture as my background.
thanks
Date: 29 Apr 2006 10:43:05
Message: <44537b79$1@news.povray.org>
>>>scene ?
>>>thanks
>>background.
>>Regards,
>>John
> polygon {
>     4,
>     texture {
> thanks
the image_map is scaled from <0,0> to <1,1> by default so you have to
either
a:
scale the texture to match the size of your object
or
b:
first apply the texture to a unit sized object then scale up the object.
Date: 29 Apr 2006 18:15:00
Message: <web.4453e2ee5ecbd4a9ee88888c0@news.povray.org>
Hi, use this code for the usual camera type.
You have to adapt the first lines and the name of the background image
to your scene.
If you use z direction as up, you have to change cam_s to z too.
//____________________________________________________________________________
#declare cam_loc = <0,1.5,-8>; // camera location
#declare lookat = <0,0.5,0>;   // camera look_at
#declare cam_ang = 67;         // camera angle
#declare back_dist = 1000;     // how far away the background should be
#declare cam_mirror = 1;       // 1 for normal / -1 for mirror image
#include "transforms.inc"
#declare cam_z = 0.5*image_width/image_height/tan (radians (cam_ang*0.5));
#declare cam_ang_up = degrees (2*atan2(0.5/cam_z,1));
#declare cam_a = cam_mirror*image_width/image_height;
#declare cam_s = y;
#declare cam_d = vnormalize (lookat-cam_loc);
#declare cam_r = vnormalize (vcross (cam_s,cam_d));
#declare cam_up = vnormalize (vcross (cam_d,cam_r));
#declare cam_dir = cam_d*cam_z;
#declare cam_right = cam_r*cam_a;
#declare fz = vlength (cam_dir);
#declare fx = vlength (cam_right)/2;
#declare fy = vlength (cam_up)/2;
#macro OrientZ (p1,p2,cs)          // looks like Reorient_trans macro!
        #local nz = vnormalize (p2-p1);
        #local nx = vnormalize (vcross (cs,nz));
        #local ny = vcross (nz,nx);
        matrix <nx.x,nx.y,nx.z,ny.x,ny.y,ny.z,nz.x,nz.y,nz.z,p1.x,p1.y,p1.z>
        location cam_loc
        up cam_up
        right cam_right
        direction cam_dir
camera {                        // equivalent camera definition
        location cam_loc
        right cam_right
        look_at lookat
        angle cam_ang
//_background________________________________________________________________
box {
        <0,0,0> <1,1,0.1>
                        image_map {png "sky" once map_type 0 interpolate 2}
                finish {ambient 1 diffuse 0}
        translate <-0.5,-0.5,0>
        scale 2*<cam_mirror*fx,fy,0.5>
        translate fz*z
        scale back_dist
        OrientZ (cam_loc,lookat,cam_up)
//______________________________________________________________________________
Regards
Norbert Kern
