POV-Ray : Newsgroups : povray.general : Lemon Server Time
12 Jul 2025 12:35:55 EDT (-0400)
  Lemon (Message 1 to 9 of 9)
Subject: Lemon
Date: 17 Mar 2006 05:05:01
Message: <web.441a893b5fb92620b6fe43de0@news.povray.org>
I'm trying to create a shape called a "lemon"
(http://mathworld.wolfram.com/Lemon.html) using POV-Ray, but am
encountering problems.
I need it to have a well-defined inside, so simply clipping a spindle torus
won't work.
Also, I'm unsure about the exactness when using a lathe or SOR object.
Does anyone have any suggestions?
Subject: Re: Lemon
Date: 17 Mar 2006 07:01:35
Message: <441aa51f@news.povray.org>
"Shark" <nomail@nomail> wrote in message
news:web.441a893b5fb92620b6fe43de0@news.povray.org...
> Hi,
> torus
> won't work.
How about one of these:
camera {location <0,0,-2.5> look_at 0}
light_source {<10,20,-100>,1}
difference {
  sphere {0,1.0}
  torus {1,1.414}
  pigment {color rgb <0,1,1>}
  translate -x/2
intersection {
  torus {1,1.414 inverse}
  sphere {0,1.0}
  pigment {color rgb <1,1,0>}
  translate x/2
Chris.
Subject: Re: Lemon
Date: 17 Mar 2006 07:20:49
Message: <hdq74DAPgqGEFw+p@econym.demon.co.uk>
Wasn't it Shark who wrote:
>Hi,
>won't work.
Try this:
#declare r1 = 0.6;
#declare r2 = 1.0;
#declare  F = function {x*x + y*y - r2*r2}
isosurface {
  function { F(sqrt(x*x+z*z)+r1, y, z) }
  max_gradient 3.1
  contained_by{sphere{0,r2}}
  pigment {rgb <1,1,0>}
max_gradient will need tweaking for different values of r1 and r2.
Mike Williams
Gentleman of Leisure
Subject: Re: Lemon
Date: 17 Mar 2006 08:03:17
Message: <441ab395$1@news.povray.org>
> Hi,
torus
> won't work.
Even if you put it inside-out with "inverse"?
Marc
Subject: Re: Lemon
Date: 17 Mar 2006 09:29:50
Message: <441ac7de$1@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:hdq74DAPgqGEFw+p### [at] econymdemoncouk...
>>Hi,
>>torus
>>won't work.
> Try this:
> #declare r1 = 0.6;
> #declare r2 = 1.0;
> isosurface {
>  max_gradient 3.1
> Mike Williams
Interestingly on rendering the three solutions side-by-side I see that
Mike's solution is the only one that gets lit correctly.
I'm not sure why this should be. I've adjusted the light in the SDL below to
emphasize the effect, in case anyone can shed light on this.
Chris B.
light_source {<0,20,-20>,1}
#local MajorRadius = 0.6;
#local MinorRadius = 1;
#local SphereRadius = pow(pow(MinorRadius,2)-pow(MajorRadius,2),0.5);
difference {
  sphere {0,SphereRadius}
  torus {MajorRadius,MinorRadius}
  pigment {color rgb <1,0,1>}
  translate -x
torus {MajorRadius,MinorRadius inverse
  clipped_by {sphere {0,SphereRadius}}
  translate x
#declare r1 = 0.6;
#declare r2 = 1;
isosurface {
  max_gradient 3.1
Subject: Re: Lemon
Date: 17 Mar 2006 10:21:41
Message: <441ad405$1@news.povray.org>
"Chris B" <c_b### [at] btconnectcomnospam> wrote in message
news:441ac7de$1@news.povray.org...
> to emphasize the effect, in case anyone can shed light on this.
I assume it's associated with the torus - any known bugs with torii?
Subject: Re: Lemon
Date: 17 Mar 2006 10:29:06
Message: <NKvAtCAaMtGEFwKX@econym.demon.co.uk>
I think the CSG torus solver doesn't do quite the right thing with the
bit in the middle when the minor radius is greater than the major radius
and the major radius is positive.
Once the surface normals are pointing the wrong way, "inverse" doesn't
fix them, it only fixes the situation where the inside is on the outside
and swaps the interior_texture for the texture.
Oddly, these work.
torus {-MajorRadius,MinorRadius
difference {
  torus {-MajorRadius,MinorRadius inverse}
Mike Williams
Subject: Re: Lemon
Date: 17 Mar 2006 12:16:12
Message: <441aeedc$1@news.povray.org>
news:NKv### [at] econymdemoncouk...
>>to
> Oddly, these work.
> difference {
> Mike Williams
Wow !#!*  That's something I didn't even think of trying :-)
I find the 'difference' version the most bewildering, as I would have
thought that slicing the 'inverse' of the torus out of the sphere would have
left the sphere with a bit cut out of the inside, whereas the reverse
happens. I guess it's safest to recommend not using this torus workaround
lest the behaviour gets fixed in a future release (given that your
isosurface provides a perfectly good solution).
Chris B.
Subject: Re: Lemon
Date: 17 Mar 2006 15:13:02
Message: <441b184e$1@news.povray.org>
LOL - I hadn't even noticed that this was the case.
