POV-Ray : Newsgroups : povray.general : lighting problem? Server Time
27 Aug 2025 07:12:16 EDT (-0400)
  lighting problem? (Message 1 to 5 of 5)
Subject: lighting problem?
Date: 22 Jan 2006 00:30:01
Message: <web.43d3183c456346d5e618711f0@news.povray.org>
Hellow, I am new to povray and have a question on an apparent lighnting
problem.
I too the phot_met_glass example and added a translate <10, 10, 10> to all
objects inclusing light and camera.  This had an unexpected effect of
dramatically altering the bluish highlights in the rendered scene.  I then
created another file with the translations still in there but set to:
translate <0, 0, 0> and the bluish hightlights came back.  This leads me to
believe there may be a default light source which I am not moving when I
add the translations.  Anyone know wha is going on?
Subject: Re: lighting problem?
Date: 22 Jan 2006 01:20:34
Message: <43d32432$1@news.povray.org>
"dragonmage" <dra### [at] gmailcom> wrote in message
news:web.43d3183c456346d5e618711f0@news.povray.org...
> problem.
> to
Not sure exactly what you are saying here without further clarification or
posting your scene, but it coul dpossibly be an 'ambient' problem.  Try
explicitly declaring "ambient 0" in all your object textures to remove any
ambient effect on them and see if that helps.
-tgq
Date: 23 Jan 2006 18:30:01
Message: <web.43d565b88752e2dbe618711f0@news.povray.org>
> > problem.
> > to
I don't know how/where to declare ambient 0 yet - need to read up on POVRay
more .  The scene is not large so I include the two examples below FYI.
THey only differ by where
the scene is positioned in the environment.
The first scene is as follows:
#version 3.5;
#include "glass.inc"
global_settings {
  assumed_gamma 1
  max_trace_level 25
  photons {
    spacing 0.03
    autostop 0
    jitter 0
  location    <20, 5, 10>
  right       2*x
  look_at     <0,-1,0>
  angle       34
  translate <0, 0, 0>
light_source {
  <-3, 10, 18>
  color rgb <1.3, 1.2, 1.1>
  translate <0, 0, 0>
  photons {
    reflection on
    refraction on
plane {
  y, -1
  translate <0, 0, 0>
      color rgb 1.0
sphere {
  0, 1
  translate <0, 0, 0>
      gradient y
      color_map {
        [0.0 color rgb 1.0 ]
        [0.3 color rgb <0.6, 0.65, 1.0> ]
    finish { ambient 1 diffuse 0 }
  scale 1000
  hollow on
#declare Metal_Texture =
  pigment { color rgb <0.5, 0.5, 0.6> }
  finish {
    ambient 0.0
    diffuse 0.15
    specular 0.3
    roughness 0.01
    reflection {
      0.8
      metallic
#declare Box = box { -1, 1 }
#declare Metal_Obj_1 =
difference {
  object {
    Box
  object {
    Box
    scale <0.8, 0.8, 1.5>
  object {
    Box
    scale <0.8, 1.5, 0.8>
  object {
    Box
    scale <1.5, 0.8, 0.8>
  texture { Metal_Texture }
    rotate 12*y
  translate <0, 0, 0>
#declare Metal_Obj_2 =
difference {
  cylinder { -1.0*y, 0.0*y, 6.0
  translate <0, 0, 0>
  cylinder { -2.0*y, 1.0*y, 5.8
  translate <0, 0, 0>
union {
  object { Metal_Obj_1 }
  object { Metal_Obj_2 }
  sphere {
    <0,0,0>, 1
  translate <0, 0, 0>
    material {
        pigment { color Col_Glass_Clear }
        finish { F_Glass6 }
      interior {
        I_Glass_Exp(2)
        fade_color Col_Red_03
  photons {
    target
    reflection on
    refraction on
    collect off
the same scene translated by (10,10,10) is:
#version 3.5;
global_settings {
  assumed_gamma 1
  max_trace_level 25
  photons {
    spacing 0.03
    autostop 0
    jitter 0
  right       2*x
  look_at     <0,-1,0>
  angle       34
light_source {
  <-3, 10, 18>
  photons {
    reflection on
    refraction on
plane {
  y, -1
      color rgb 1.0
sphere {
  0, 1
      gradient y
      color_map {
  scale 1000
  hollow on
  finish {
    ambient 0.0
    diffuse 0.15
    specular 0.3
    roughness 0.01
    reflection {
      0.8
      metallic
difference {
  object {
    Box
  object {
    Box
  object {
    Box
  object {
    Box
    rotate 12*y
difference {
union {
  sphere {
    <0,0,0>, 1
    material {
        finish { F_Glass6 }
      interior {
        I_Glass_Exp(2)
  photons {
    target
    reflection on
    refraction on
    collect off
> -tgq
Date: 23 Jan 2006 21:29:32
Message: <43d5910c$1@news.povray.org>
the problem is in one of your spheres:
//start
sphere {
  0, 1
      gradient y
      color_map {
  scale 1000
  hollow on
//end
You are misusing translate and scale here, or at least its not operating as
you expect it to.  When you scale something, it gets scaled based at the
origin, so translating *then* scaling does not equal scaling *then*
translating.  In the original, the sphere was placed at <0,0,0> with a
radius of 1, then scaled 1000x.  Since it was centered at the origin, the
result is that the sphere remains centered around the origin but now has a
radius of 1000.   In your example here, you made a 1 radius sphere at the
origin and translated it <10,10,10> giving you a sphere with its center at
<10,10,10>. Then you scaled it 1000, which scaled the sphere larger, but
because scale centers on the origin, the <10,10,10> translation gets scaled
to a <10,10,10>*1000 translation giving you a 1000 radius sphere at
<10000,10000,10000> and therefore reflects in your other objects
differently.  To get the correct results, move the translation after the
scale:
//start
sphere {
  0, 1
      gradient y
      color_map {
  scale 1000
  hollow on
//end
Hope this helps you figure out what's going on.
-tgq
Date: 24 Jan 2006 22:35:00
Message: <web.43d6f0dc8752e2db5820684d0@news.povray.org>
Thanks Trevor,
yes that sphere definition was the problem, it works fine now!
I had a moment's thought about the ordering of the scale/translate but then
passed it up and forgot about it.
cheers,
chris
