POV-Ray : Newsgroups : povray.general : How to extract the fifth value of a 5D vector? Server Time
5 May 2026 20:10:36 EDT (-0400)
  How to extract the fifth value of a 5D vector? (Message 1 to 8 of 8)
Subject: How to extract the fifth value of a 5D vector?
Date: 28 Oct 2005 08:30:01
Message: <web.43621989499ae6d9c0c113bc0@news.povray.org>
I found a little "problem" (with solution) that i'd like to share with you.
According to the reference Pov-Ray supports 5D-Vectors but there seems to be
no way to extract the fifth value (directly) or am i missing something? the
first four values can be extracted with .x .y .z and .t and thats it!?
I managed to handle with this problem with the following piece of code:
//start of code
#include "math.inc"
#declare someVector = <0,3,2,1,5>;
#declare value1 = someVector.x;
#declare value2 = someVector.y;
#declare value3 = someVector.z;
#declare value4 = someVector.t;
#declare value5 = VLength5D(someVector-<value1,value2,value3,value4,0>);
//end of code
Is this really the only possibility? Isn't it somehow silly to support
5D-Vectors without supporting a fifth dot-operater to get this additional
value?
Greetings Roman
Subject: Re: How to extract the fifth value of a 5D vector?
Date: 28 Oct 2005 08:56:18
Message: <+mcMWCAs$hYDFwDA@econym.demon.co.uk>
>//start of code
>#include "math.inc"
>//end of code
>value?
This works
#declare value5 = someVector.transmit;
Don't get confused by the fact that ".t" is the same as ".filter", and
isn't short for ".transmit"
Mike Williams
Gentleman of Leisure
Date: 28 Oct 2005 10:25:01
Message: <web.436233b293f5284339b8d62e0@news.povray.org>
> value?
Actually, 5D-vectors are to be thought of as colors... see:
3.2.1.4.3  Operators
<...>The dot operator is also used in color expressions which are covered
later.
3.2.1.5.4  Color Operators
<...>You may use the dot operator to extract a single component from a
color. Suppose the identifier Shade was previously defined as a color. Then
Shade.red is the float value of the red component of Shade. Similarly
Shade.green, Shade.blue, Shade.filter and Shade.transmit extract the float
value of the other color components. shade.gray returns the gray value of
the color vector.
Hoping this helps!!!
JYR
Date: 28 Oct 2005 10:30:01
Message: <web.4362358b93f5284339b8d62e0@news.povray.org>
Sorry, i didn't see that Mike Williams had already addressed this
question!!!
JYR
Date: 28 Oct 2005 12:15:01
Message: <web.43624d6593f5284337c5f0ab0@news.povray.org>
Ahh! that helps a lot. as you wrote I supposed .t to be short for .transmit
(like .r, .g, .b are short for .red .green .blue) and tried .f for .filter.
Thanks. Roman
Date: 28 Oct 2005 17:59:42
Message: <43629f4e$1@news.povray.org>
>>//start of code
>>#include "math.inc"
>>//end of code
>>value?
> This works
Paragraph 3.2.1.4.3. of Da Rulez:
"For a 4D vector use .x, .y, .z, and .t to extract each float component."
John
Date: 29 Oct 2005 04:00:00
Message: <web.43632ad393f5284337c5f0ab0@news.povray.org>
> Regards,
> John
Paragraph 0.0.0.0.1 of Da Rulez:
"Read the question before answering" ;-)
Just kidding
Roman
Date: 29 Oct 2005 05:03:06
Message: <43633aca$1@news.povray.org>
>>Regards,
>>John
> Just kidding
> Roman
also in exams, read the rubrics (sp?)
ie 2 questions from part A and 5 from part B
