POV-Ray : Newsgroups : povray.general : Perfect Image Re-Render? Server Time
5 May 2026 21:27:49 EDT (-0400)
  Perfect Image Re-Render? (Message 1 to 10 of 11)
Subject: Perfect Image Re-Render?
Date: 13 Oct 2005 14:45:00
Message: <web.434eaaf55d09ff87af56bf270@news.povray.org>
I'm having a mental block at the moment.  This seriously can't be hard...
I'm attempting to render an image_map of a previously traced scene - the
goal of which is to allow me the luxury of rendering a frame/border/special
effect of some sort around the original image.
I need to re-render my image_map such that every pixel traced is correlated
to the original image_map pixel.  How can I set up my image_map (distance
from camera, mainly) to ensure this to be the case?  After some basic math,
I've gotten close, but it's not a perfect match.
Any thoughts?
- How
Subject: Re: Perfect Image Re-Render?
Date: 13 Oct 2005 16:48:12
Message: <434ec80c$1@news.povray.org>
"How Camp" <hac### [at] gmailcom> wrote in message
news:web.434eaaf55d09ff87af56bf270@news.povray.org...
> correlated
> math,
> Any thoughts?
> - How
If you're using a perspective camera you'll get problems because you'll need
to adjust for the distortion that perspective introduces (and that is likely
to be inordinately difficult). You should be able to achieve this fairly
simply with an orthographic camera.
Chris B.
Date: 13 Oct 2005 17:09:04
Message: <434eccf0@news.povray.org>
  If the plane containing the image map is completely perpendicular to
the direction of the camera, can you explain what kind of perspective
distortion happens there?
Date: 13 Oct 2005 18:36:09
Message: <434ee159@news.povray.org>
news:434eccf0@news.povray.org...
>> need
>> likely
>                                                          - Warp
Ah. I think I'm wrong. I was thinking of the distortion you get when a flat
surface is projected onto the curved surface of a retina, but of course the
camera in a ray tracer is a perfect point and the projection is onto a flat
plane, so you should be able to get a mapping from one plane to another.
With the default image_map scaling giving you an image from <0,0,0> to
<1,1,0> you should then be able to set the up vector to y and the right
vector to x with the camera at <0.5,0.5,-1> and look_at <0.5,0.5,0> and get
a perfect pixel for pixel mapping.
Chris B.
Date: 14 Oct 2005 06:55:01
Message: <web.434f8dc6cfbe6099af56bf270@news.povray.org>
Well, I'm silly.  Yes, this is what I was doing... but I applied an
antialias value without thinking about it.  Blush.
Thanks, both Chris and Warp.
- How
Date: 14 Oct 2005 08:05:01
Message: <web.434f9ec9cfbe6099af56bf270@news.povray.org>
Hmph.  Okay, I'm still a bit of a dunce.
My image now renders perfectly in terms of pixel reconstruction, but the
colors of the 'rerendered' image are significantly darker than the original
copy.
I have no light sources, and my ambient value is 1.  What else am I
forgetting?
- How
Date: 14 Oct 2005 09:58:55
Message: <434fb99f@news.povray.org>
> copy.
  Probably gamma issues.
  Do you have a assumed_gamma setting in your scene? If yes, comment it out.
If no, then try something like 1.0 or 2.2. Or something.
Date: 14 Oct 2005 11:20:00
Message: <web.434fcba0cfbe6099af56bf270@news.povray.org>
You're good, Warp.  :)
No, I don't have assumed_gamma.  I added it, with a value of 1.0, and things
are better, but not perfect.  I ended up lowering the image_map's ambient
value to some screwy value (0.57) to compensate.  Not sure why this is.
My original image has no specific assumed_gamma value, either.  Naively, I
would think if I have identical assumed_gamma values in my original and my
're-rendered' scene, shouldn't I get the same color from each pixel?
Were I to add an assumed_gamma of 1.0 to my original image, I would not
expect any improvement, since originally both renders lacked any
assumed_gamma setting.
- How
Date: 14 Oct 2005 15:49:17
Message: <43500bbd$1@news.povray.org>
Hash: SHA1
> and things are better, but not perfect.  I ended up lowering the
> image_map's ambient value to some screwy value (0.57) to
	I would go with an assumed gamma of 1/2.2 or 1/2.5 (whichever your
disply gamma is) along with the ambient 1.0
		Jerome
*      Jerome M. Berger      *
*  mailto:jeb### [at] freefr   *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.0 (GNU/Linux)
iD8DBQFDUAu9qIYJdJhyixIRAgp0AJsFB1T3ZoSkHw1fvSeDKRbj4FC80wCbB5nC
wXp7h+lymblRazihodmYlfY=
=+ihD
-----END PGP SIGNATURE-----
Date: 15 Oct 2005 12:53:05
Message: <435133f1@news.povray.org>
I'm sorry.. but perhaps I don't understand your problem entirely.
How about smacking that old render onto a plane, scale it down,
add the border and render with a orthographic camera?
Stefan
"How Camp" <hac### [at] gmailcom> skrev i meddelandet
> correlated
> math,
> Any thoughts?
> - How
