POV-Ray : Newsgroups : povray.general : clear glass with transparent liquid inside... Server Time
14 Jul 2025 14:19:12 EDT (-0400)
  clear glass with transparent liquid inside... (Message 1 to 5 of 5)
Subject: clear glass with transparent liquid inside...
Date: 3 Jun 2005 14:35:01
Message: <web.42a0a19cceb3a019b608bc930@news.povray.org>
Okay basically I'm attempting to render a beer mug with beer in it.
Using wings3d I constructed the Mug model...
Using model of mug I created the fluid in the glass... ( I extracted only
the polygons on the INSIDE of the glass to do this...)  then... I exported
both meshs into .obj files
Using Poseray I rewound the triangles and normals on the the fluid for the
mug... this was needed -concidering how i obtained the fluid volume in the
first place from the mug triangles.
Using Poseray I converted both models to povray files...
Using povray 3.6.1 I rendered the Mug & mug fluid...
RESULTS:
  -The Mug by itself is just great... transparent... nice... cool.
  -The Fluid by itself... just as nice.
  -When the fluid is in the mug, you can see the fluid color ONLY if veiwed
from birds eye into glass.
  If I enlarge the volume of the fluid to be slightly larger than the
interior volume of the mug ( but still inside the glass of the mug ) then I
can see the color of the fluid...  BUT this is obviously flawed.
  So my question is what have i done wrong?  ;)
  other notes:
     glass is "hollow"
     have tried hollow and not hollow fluid...
     As long as the mesh for the fluid is up against the mesh for the glass
then I can see no color... but this is the accurate physical
representation....
ERRRRRR
  Anyone else ever try this...
  I will post some code if asked but note my data files for geometry are to
large to post... I would have to generate something smaller.
TIA lordcontrary
Subject: Re: clear glass with transparent liquid inside...
Date: 3 Jun 2005 15:43:28
Message: <42a0b2e0$1@news.povray.org>
lordcontrary nous apporta ses lumieres en ce 2005-06-03 14:31:
> RESULTS:
>   other notes:
>      glass is "hollow"
> representation....
> ERRRRRR
> TIA lordcontrary
You are experiencing the soincident surfaces problem. When 2 surfaces meet exactly,
you can't tell
whitch one you meet first.
You alreadi tried using a larger iner shape, try a smaler scale increase as your
increase may have
been to large.
Try scaling down by a very small value.
As you are using meshes, try rotating the incide object. Something like rotate 0.1*y
can be enough.
If you post your source, try ZIPing it with maximum compression, it should compress
well as the data
set is quite limited: 0..9+"."+","+"<"+">"+"-"+some letters and the space.
Date: 3 Jun 2005 18:56:52
Message: <42a0e033@news.povray.org>
lordcontrary <lor### [at] yahoocom> wrote:
>      glass is "hollow"
  Why? All the glasses I have seen have been very solid.
  Why? Are you using media?
Date: 4 Jun 2005 18:30:00
Message: <web.42a22a34c1c5ea72b608bc930@news.povray.org>
> >      glass is "hollow"
I actually was fooling with many things at once... have not used povray in
oh... 8 years... refreshing my memory on new concepts...  media was one of
them... and I thought it applied in this context?  yep... media was used and
a bunch of other goodies.   anywho...
I did scale back the volume and now I have "beer" in my mug.  Thanks.
I did have one problem that needed to be fixed as well... before the effect
was perfect...
When I made the "fluid" I did not have wings3d tesselate the geometry...
This was done during a convertion ( possibly .obj ->.pov )...  turns out
the convertion program did a terrible job of it.  When i converted the data
back I learned it tesselated it in a terrible fashion.  ( not a rant - in
the end I actually manually tesselated some geometry one triangle at a time
to get it right )
Now tesselation by itself is not a problem but when it created vertex
normals they were not consistent at the edges... it made all the refraction
a trainwreck.  Lesson learned... rely on convertion programs ONLY to
convert... not to make adjustments to your geometry...
..... thanks for the feedback... off to make a neon bar light to go with my
drink!
Date: 4 Jun 2005 19:09:51
Message: <42a234bf@news.povray.org>
  I just got the impression that you had a confusion about what 'hollow'
does in POV-Ray. That keyword is exclusively related to media (and fog)
and nothing else. If you don't have any media/fog in your scene and
you are getting something weird, 'hollow' will not fix it nor have any
effect whatsoever so it's pretty useless to try it. :)
