POV-Ray : Newsgroups : povray.general : #local shapes Server Time
6 May 2026 03:04:25 EDT (-0400)
  #local shapes (Message 1 to 6 of 6)
Subject: #local shapes
Date: 7 Apr 2005 16:05:01
Message: <web.425591b4f49c80836fd49c30@news.povray.org>
Hi there!
Just out of curiousity: while you are free to define nearly everything
#local my_shape =
sphere { ... }
// inside the my_shape.inc
and
#include "my_shape.inc"
object {my_shape}
// inside the main .pov-file
work?
Thanks
Steely
Subject: Re: #local shapes
Date: 7 Apr 2005 16:11:16
Message: <425593e4$1@news.povray.org>
"Steely" <nomail@nomail> wrote in message
news:web.425591b4f49c80836fd49c30@news.povray.org...
> Hi there!
this:
> #local my_shape =
> sphere { ... }
> and
> object {my_shape}
> work?
> Thanks
> Steely
#local is for things that are only available in the file (or in the case of
a macro, available only in the macro) which they are defined in, to my
understanding. if you want it to be available from an included file, it has
to be #declared
3.1.2.2.2  #declare vs. #local
-ross
Date: 7 Apr 2005 21:44:05
Message: <4255e1e5@news.povray.org>
> #local my_shape =
> sphere { ... }
> and
> object {my_shape}
  Well, that's exactly what #local is supposed to do. That's why it
exists in the first place. (Why would it even exist otherwise?)
Date: 8 Apr 2005 03:15:01
Message: <web.42562ec489f8af7c6fd49c30@news.povray.org>
Steely
Date: 8 Apr 2005 07:08:40
Message: <42566638@news.povray.org>
  I don't really understand what you are asking.
  #local is a special version of #declare which limits the visibility
of an identifier inside the include file or the macro in which it is
used. That is the precise purpose of #local. It helps to keep the
global namespace of identifiers cleaner (to avoid name collisions).
  If something has been declared #local in an include file then it is
something private to that include file, not intended to be seen from
the outside (and thus potentially collide with something having the
same name somewhere else).
Date: 12 Apr 2005 07:20:01
Message: <web.425bae2c89f8af7c420f83140@news.povray.org>
Yes, thanks for explaining. I know this, and still there are lots of cases I
can think of, where it would be nice to have different includes with
different shapes with the same identifier. But as I said in the first post,
S.
