POV-Ray : Newsgroups : povray.general : Calling external Math functions from .dll or .so Server Time
6 May 2026 05:27:28 EDT (-0400)
  Calling external Math functions from .dll or .so (Message 1 to 10 of 103)
Subject: Calling external Math functions from .dll or .so
Date: 10 Feb 2005 10:25:01
Message: <web.420b7c34c551b3d17485eb850@news.povray.org>
I'd like to call Library-Functions from SDL. Is there already an extension
to POV-Ray that enables declaration of external user-defined functions?
I think of something like the JNI, only more simple. At least support for
double-type parameters and -arrays (for return-parameters) would be useful.
Regards, Arne
ps.: no, i dont want to generate pov-scene files and i dont want to create
data files and read them with sdl
Subject: Re: Calling external Math functions from .dll or .so
Date: 10 Feb 2005 10:39:45
Message: <420b8041@news.povray.org>
The source code of POV-Ray is available, so just compile it.
	Thorsten
Date: 10 Feb 2005 12:20:00
Message: <web.420b978b3223e4997485eb850@news.povray.org>
Yes, I already downloaded the code. Just wanted to check if any extension
already exists and if a feature like library support is going to be added
some day.
Sounds like a good idea to me, you know like in MATLAB for instance.
Thanks,
Arne
>  Thorsten
Date: 10 Feb 2005 12:37:01
Message: <420b9bbd$1@news.povray.org>
> some day.
No, it is an extremely bad idea as it is not portable and all this has been
explained several times in these groups.  It is never going to be added to
any official version of POV-Ray.
	Thorsten
Date: 10 Feb 2005 13:29:13
Message: <420ba7f9$1@news.povray.org>
> been explained several times in these groups.  It is never going to be
> added to any official version of POV-Ray.
Not only that, but all it would take is one badly written plugin to
corrupt POV-Ray's memory and crash POVRay with the blame on the POV-Team.
Though, I suppose you could use CORBA, COM, SOAP or any other IPC
technology... <g,duck>
~Mike
Things! Billions of them!
Date: 10 Feb 2005 14:37:06
Message: <Xns95F9D1BD7FE35seed7@news.povray.org>
> has been explained several times in these groups.  It is never going
> to be added to any official version of POV-Ray.
I've seen this awnser so often to similar questions, but I'm wondering,
why does it work for other programming/scripting languages. I what way is
POV-Ray different. I can imagine that it would be complex to add a new
ray-traceable object through a module, but how about other stuff like, for
example a database interface.
http://python.active-venture.com/ext/intro.html
http://www.rubycentral.com/book/ext_ruby.html
Ingo
Date: 10 Feb 2005 14:47:22
Message: <Xns95F9D37A8908Dseed7@news.povray.org>
probably not the best example, her's another one: write the core of a slow
mesh-creation macro in C and use it as if it is an include file or a part
of an includefile package.
Date: 10 Feb 2005 18:05:13
Message: <420be8a9$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:420b9bbd$1@news.povray.org...
Yes, it does sound like a good idea - however, for reasons Thorsten so
vigorously defended but didn't bother to explain, it probably won't happen.
been
I've often wondered. Bearing in mind my ignorance of high-end programming,
wouldn't it be possible to run a binary with a command line switch to tell
it to take advantage of specified system-specific libaries?
Bugs would be the responsibility of the library author, unless the bug was
repeatable w/o the library being loaded.
Or would such libraries be horribly inefficient?
Date: 11 Feb 2005 11:41:31
Message: <420ce03b$1@news.povray.org>
>> some day.
I would like to ask why this would be not portable? Any platform POVRay
runs on should support dynamic loading. Or does POVRay compiles under
plain DOS?
For my self I don't have any application to use such an interface off
POVRay because my .pov's are written from another programm or by hand.
It's only a technical question.
mat### [at] matweide
http://www.matwei.de
Date: 11 Feb 2005 11:51:05
Message: <420ce279@news.povray.org>
>>> extension
>>> added
>>> some day.
> plain DOS?
Dynamic loading and linking is not standardised across platforms. Each
OS has it's own way of loading an external module and "fixing up" the
procedure addresses.
~Mike
