POV-Ray : Newsgroups : povray.general : Problem: Colours and Effects aren't the same as Predefined Shapes in Isosur= Server Time
15 Jul 2025 06:09:49 EDT (-0400)
  Problem: Colours and Effects aren't the same as Predefined Shapes in Isosur= (Message 1 to 3 of 3)
Subject: Problem: Colours and Effects aren't the same as Predefined Shapes in Isosur=
Date: 23 Jan 2005 03:40:01
Message: <web.41f3617e4a90639f3d54f5180@news.povray.org>
Isosurface?
I'm unable to achieve the Translucent effect in the Isosurface Code. The
Translucent effect is NICE in the Predefined Shapes Code.
[Isosurface Code]
global_settings
  assumed_gamma 1.0
camera
  location  <0.0, .5, -4.5>
  direction 1.5*z
  right     4/3*x
  look_at   <0.0, 0.0, 0.0>
light_source
  0*x // light's position (translated below)
  color red 1.0  green 1.0  blue 1.0  // light's color
  translate <-30, 30, -30>
union
// Cylinder Middle
isosurface {
  function { pow(x,2) + pow(z,2) - pow(0.215,2) }
        accuracy 0.001
        threshold 0
        max_gradient 2
        contained_by{box{<-1,-0.5,-1>, <1,0.5,1>}}
        //texture{pigment {White} finish{specular 1}}
        texture{pigment {White filter 0.7} finish{specular 1}}
//Sphere Top
isosurface {
  function { pow(x,2) + pow(y,2) + pow(z,2) - pow(0.5,2) }
        accuracy 0.001
        threshold 0
        max_gradient 2
        //contained_by{sphere{0,0.78}}
        pigment {rgb .9}
        translate <0, 0.78, 0>
//Sphere Bottom
isosurface {
        accuracy 0.001
        threshold 0
        max_gradient 2
        //contained_by{sphere{0,-0.78}}
        pigment {rgb .9}
        translate <0, -0.78, 0>
// Cylinder Top
isosurface {
  function { pow(x,2) + pow(z,2) - pow(0.5,2) }
        accuracy 0.001
        threshold 0
        max_gradient 2
        contained_by{box{<-1,0.78,-1>, <1,1,1>}}
// Cylinder Bottom
isosurface {
        accuracy 0.001
        threshold 0
        max_gradient 2
        contained_by{box{<-1,-0.78,-1>, <1,-1,1>}}
[/Isosurface Code]
[Predefined Shape Code]
global_settings
  assumed_gamma 1.0
camera
  direction 1.5*z
  right     4/3*x
light_source
union
  cylinder{<0,-0.5,0>, <0,0.5,0>, 0.215}
  sphere{<0, .78, 0> 0.5}
  sphere{<0, -.78, 0> 0.5}
  cylinder{<0, .78, 0>, <0, 1, 0>, .5}
  cylinder{<0, -.78, 0>, <0, -1, 0>, .5}
[/Predefined Shape Code]
Subject: Re: Problem: Colours and Effects aren't the same as Predefined Shapes in Isosur=
Date: 23 Jan 2005 04:20:12
Message: <why$3BAFx28BFwbb@econym.demon.co.uk>
>Isosurface?
You just forgot to remove the line that says
        pigment {rgb .9}
in some of the isosurfaces.
If you have two textures on an object, then they act as "layered
textures" (read the docs if you're unfamiliar with that concept) and you
see the opaque underlying {rgb 0.9} texture layer through the partially
transparent {White filter 0.7} texture layer.
>//Sphere Top
>isosurface {
>        accuracy 0.001
>        threshold 0
>        max_gradient 2
>        pigment {rgb .9}
Mike Williams
Gentleman of Leisure
Date: 23 Jan 2005 13:32:40
Message: <41f3edc8$1@news.povray.org>
> Isosurface?
After doing what Mike Williams said, you may also want to look at the
all_intersections keyword in the documentation.
 - Slime
 [ http://www.slimeland.com/ ]
