POV-Ray : Newsgroups : povray.general : stars are gone Server Time
6 May 2026 08:21:15 EDT (-0400)
  stars are gone (Message 1 to 4 of 4)
Subject: stars are gone
Date: 4 Jan 2005 19:25:01
Message: <web.41db32f66a5cceb5123f95160@news.povray.org>
I did a picture using a sphere with starfield1. when I made the antialiased
version the stars disappeard and the sky was solid black. The non aliased
pictures showed the stars just fine.What could have gone wrong? Thank you.
I used this
sphere{<0,0,0>,1000
 hollow
 texture{Starfield1}
Subject: Re: stars are gone
Date: 4 Jan 2005 20:49:48
Message: <41db47bc$1@news.povray.org>
I am really just guessing here but when we antialias, we are trying to
smooth edges and remove pixelation.  Normally this is done by taking a
desired pixel and the pixels that immediately surround it and then
averaging.
If a star is a single point (pixel) in space surrounded by blackness, then
if we antialias, we will average the single white point by many more black
points reducing the overall value (brightness) of the white point.
One possible (but untested) solution would be to not use "Starfield1" but
instead copy in the texture definition that the Starfield1 symbol represents
and then multiply each of the color values by some multiplying constant.
For example:
#declare My_Starfield1 =
        granite
        color_map {
            [ 0.000  0.270 color rgb < 0, 0, 0>*10 color rgb < 0, 0, 0>*10 ]
            [ 0.270  0.280 color rgb <.5,.5,.4>*10 color rgb <.8,.8,.4>*10 ]
            [ 0.280  0.470 color rgb < 0, 0, 0>*10 color rgb < 0, 0, 0>*10 ]
            [ 0.470  0.480 color rgb <.4,.4,.5>*10 color rgb <.4,.4,.8>*10 ]
            [ 0.480  0.680 color rgb < 0, 0, 0>*10 color rgb < 0, 0, 0>*10 ]
            [ 0.680  0.690 color rgb <.5,.4,.4>*10 color rgb <.8,.4,.4>*10 ]
            [ 0.690  0.880 color rgb < 0, 0, 0>*10 color rgb < 0, 0, 0>*10 ]
            [ 0.880  0.890 color rgb <.5,.5,.5>*10 color rgb < 1, 1, 1>*10 ]
            [ 0.890  1.000 color rgb < 0, 0, 0>*10 color rgb < 0, 0, 0>*10 ]
    turbulence 1
    sine_wave
    scale .5
    finish { diffuse 0 ambient 1 }
Again, not tested ... just a theory thought ...
Neil
"Barehunter" <nomail@nomail> wrote in message
news:web.41db32f66a5cceb5123f95160@news.povray.org...
antialiased
> I used this
> sphere{<0,0,0>,1000
>  hollow
>  texture{Starfield1}
Date: 4 Jan 2005 21:50:01
Message: <web.41db550d47234517123f95160@news.povray.org>
>>>SNIP<<<
Thanks Neil. I tried exactly what you suggested and it seems to work.
Date: 4 Jan 2005 22:18:18
Message: <cjameshuff-1ACF3B.22181204012005@news.povray.org>
In article <41db47bc$1@news.povray.org>,
That's essentially the problem. Those textures rely on aliasing to
create the stars...each pixel is a point sample of a mostly black
pigment. Occasionally one hits a light area, producing a star.
Antialiasing just renders the image more correctly, showing that there
really aren't any stars. It gets worse when you clip colors before
averaging, since even increasing the brightness won't increase the
effect on a pixel. (However, not clipping produces jagged edges on very
bright objects. A real solution will be more complex...)
Simply brightening the stars is unlikely to give good results, it will
probably just reveal the pattern. Pretty much the only way I know of to
get decent stars with AA is to use a big shell of many randomly placed
spheres sized to cover approximately one pixel.
http://tag.povray.org/
