POV-Ray : Newsgroups : povray.general : Radiosity: is this appropriate? Server Time
6 May 2026 11:22:05 EDT (-0400)
  Radiosity: is this appropriate? (Message 1 to 10 of 12)
Subject: Radiosity: is this appropriate?
Date: 11 Dec 2004 14:05:00
Message: <web.41bb441e2c73d0f48f722dab0@news.povray.org>
After a couple of IRTC submissions that used radiosity, and then getting
comments suggesting I should try using radiosity, I mean to get it right
this time. I have been using two-pass radiosity. I will post the image on
P.B.I.
Here is my problem. If I use a lower-quality first pass (count 500
error_bound .4 at 100*60) My lighting is just as flat on the second pass as
it always was. So now I am trying to use a 500*300 with the following
settings:
  radiosity {
        #if (pass1)
         pretrace_start .04
          pretrace_end   .01
         error_bound .1
         minimum_reuse .0025
         nearest_count 20
         count 1200
         recursion_limit 5
         brightness 1
         max_sample 2
         low_error_factor 1
         adc_bailout 0.01/20
         save_file "radios"
        #else
     pretrace_start 1
      pretrace_end   1
      count 1200
      recursion_limit 5
      low_error_factor .5
      gray_threshold 0.0
      brightness 1.25
      error_bound .8
      minimum_reuse .0025
      nearest_count 20
      low_error_factor 1
      adc_bailout 0.01/20
      load_file "radios"
      always_sample off
      max_sample 1
but this, even with the simplified first pass scene, will take over 11 days
to render! By the time I get the second pass done, I'll have run out of
time. Have I forgotten something, or does a good render just take this
long? It seems like I have seen high quality images that did not take quite
so long.
Also, I am having trouble with the smoothed second pass. It seems to lose a
lot of detail in small areas (see the ceiling in the posted image)
I have read the docs several times though, as well as Tim Nikias' two-pass
radiosity experiments, but I'm still not quite getting that clean, crisp,
complex shadowed look.
Thank you for any advice you can give.
-S
5TF!
Subject: Re: Radiosity: is this appropriate?
Date: 11 Dec 2004 14:08:46
Message: <41bb45be$1@news.povray.org>
I'm not an expert but I would lower your count by a lot. I saw no
visible difference in my POVCOMP entry when I lowered it from 1200 to
about 50, but it cut my time exponentially.
~Mike
> P.B.I.
> settings:
>   radiosity {
>         #if (pass1)
>          pretrace_start .04
>           pretrace_end   .01
>          error_bound .1
>          minimum_reuse .0025
>          nearest_count 20
>          count 1200
>          recursion_limit 5
>          brightness 1
>          max_sample 2
>          low_error_factor 1
>          adc_bailout 0.01/20
>          save_file "radios"
>         #else
>      pretrace_start 1
>       pretrace_end   1
>       count 1200
>       recursion_limit 5
>       low_error_factor .5
>       gray_threshold 0.0
>       brightness 1.25
>       error_bound .8
>       minimum_reuse .0025
>       nearest_count 20
>       low_error_factor 1
>       adc_bailout 0.01/20
>       load_file "radios"
>       always_sample off
>       max_sample 1
>      #end
> so long.
> -S
> 5TF!
Date: 11 Dec 2004 14:20:00
Message: <web.41bb4790420c6eda8f722dab0@news.povray.org>
There is DEFINITELY a difference in my image. At 50, 100, all the way up to
about 600 it has flat shadows, artefacting in the corners, and all over
boring lighting. I need my count to be at least 750 to look OK.
-S
5TF!
Date: 11 Dec 2004 17:18:27
Message: <41bb7233$1@news.povray.org>
news:web.41bb4790420c6eda8f722dab0@news.povray.org...
to
> -S
> 5TF!
how are set your finish{ambient}s?
if ambients are more than 0, you get luminous and flat shadows
set ambients to 0 unless you want texture to emit light (sky or light object
for instance)
if no ambient value is specified, default is 0.1
you can put #default {finish{ambient 0}} in global_settings block to set
your own default value
Marc
Date: 11 Dec 2004 17:30:01
Message: <web.41bb746d420c6eda3947da9a0@news.povray.org>
Yeah, I had trouble with that previously, but the default ambient IS zero in
this image. Only the lights upstairs, and the sky are higher ambient. BTW,
it has speeded up a little, so it will now only take 8 days for a 500*300
render :(
-S
5TF!
Date: 11 Dec 2004 18:15:02
Message: <cpfuog$2kk$1@chho.imagico.de>
> P.B.I.
> settings:
Those settings don't appear very useful - start with the default or with
one of the settings from rad_def.inc and only modify something when you
know it has the intended effect.  Simply randomly trying out numbers
won't lead you anywhere except to long render times.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 11 Dec 2004 19:55:00
Message: <web.41bb95d4420c6eda607ddbe00@news.povray.org>
> Christoph
Well, let me explain why I used them, and hopefully someone can tell me
where I went wrong.
 radiosity {
        #if (pass1)
         pretrace_start .04    <--- The pretraces, I reduced in size to get
a little more variation in the colors and shadows of that big, blank far
wall, by avoinding large sample areas.
          pretrace_end   .01   <--- See above
         error_bound .1 <-- I reduced the error bound until it looked good.
Larger is too low quality, and lower changes very little.
         minimum_reuse .0025 <--  The default.
         nearest_count 20 <--I was using this because that's what Tim Nikias
reccomended for 2 pass radiosity. Ensures more even samples, as I
understand it.
         count 1200 <-- I used a high count because it looked better. Low
count gives the bland results I posted in p.b.i.
         recursion_limit 5 <--- I have several panes of glass in the scene.
Without a higher recursion limit, the scene gets very dark.
         brightness 1 <-- The Default
         max_sample 2 <-- Increaced for the lights upstairs, which have a
high ambient.
         low_error_factor 1 <-- Tim Nikias' value, again.
         adc_bailout 0.01/20 <-- default, I believe.
         save_file "radios" <--'Nuff said
        #else
      pretrace_start 1 <-- Pretraces set to one for second pass
      pretrace_end   1
      count 1200 <-- count set the same as above.
      recursion_limit 5 <--same as above
      low_error_factor .5 <-- Looking at this again, I realize I never
deleted this. Correct number is below.
      gray_threshold 0.0 <-- Default
      brightness 1.25 <--Looked better this way. The room is a little dark
w/o
      error_bound .8 <-- Value multiplied to smooth out samples
      minimum_reuse .0025 <-- Default
      nearest_count 20 <-- Tim, again
      low_error_factor 1 <-- Same as above
      adc_bailout 0.01/20 <--Default
      load_file "radios" <--'Nuff said
      always_sample off <-- Two pass radiosity
      max_sample 1 <--So I can see the partitions in the lights, now that
the light from them is calculated
Thanks for your help!
-s
5TF!
Date: 11 Dec 2004 20:10:00
Message: <web.41bb9933420c6eda607ddbe00@news.povray.org>
'scuse me. Turns out this value is NOT the default. I reduced it to gain
more
data, and smooth out the effects, so that all that interest in the shadows
I want looks OK.
-S
5TF!
Date: 11 Dec 2004 21:45:00
Message: <web.41bbb010420c6edaacced0c50@news.povray.org>
Can anyone tell me what values they use? If mine are *that* far off, maybe I
am texturing improperly.
Thanks, though, for all the help so far. From the reactions, I obviously
don't have *something* right.
-S
5TF!
Date: 12 Dec 2004 05:00:02
Message: <cph4nu$271$1@chho.imagico.de>
> where I went wrong.
>  radiosity {
>         #if (pass1)
Pretrace settings only influence the way samples are taken, you will
hardy achieve any general change except in artefacts.  The pretrace_end
should be choosen with respect to the error_bound so the majority of the
samples are taken during pretrace.  Your value probably is too high.
Lower error_bound != higher quality!
> understand it.
This first of all immensly increases render time and memory use.  And
your argument does not even mention it increases quality in this case.
You mostly need a high count because your other settings require it.
Transparent surfaces are influenced by max_trace_level but have no
relation to recursion_limit - this is only relevant for the diffuse
reflection iteration.  The idea of two pass radiosity is to avoid
refractive/reflective surfaces in the first pass.
> high ambient.
max_sample *limits* the brightness of samples and does not increase it.
complete nonsense in combination with 'always_sample off'.
Changing this in the second pass is a possible artefact creator.
Again my recommendation: start with the default and only change settings
when you see they have the intended effect.
