POV-Ray : Newsgroups : povray.general : Rotation to Normal Vector help Server Time
16 Jul 2025 06:05:38 EDT (-0400)
  Rotation to Normal Vector help (Message 1 to 4 of 4)
Subject: Rotation to Normal Vector help
Date: 5 Nov 2004 14:05:00
Message: <web.418bce1ed18cb197b78c017a0@news.povray.org>
Hello-
I am trying to cover a surface with discs (flattened spheres), such that
each disc lies flat on the surface.  I have the normals at each point
(thanks to Tim Nikias' Mesh-Maker-Macros), and need to know how to rotate
my spheres (discs) so that they will be perpendicular to the normal at each
point.
I have tried many approaches, but none are giving the result I want.  Can
anyone help?
Thanks,
Leo
Leo Bleicher
http://porterbleicher.g2gm.net/computed-paintings.htm
Subject: Re: Rotation to Normal Vector help
Date: 5 Nov 2004 15:35:19
Message: <418be407@news.povray.org>
each
> point.
Well, the normal should be the "up" vector of the disc, right?
What you could use <shameless plug> is my Look_At-Macro </shameless plug>
which returns the rotation vector needed to rotate the -z direction towards
the given position/vector. So
rotate Look_At(Insert_Normal)
should work when the top of the sphere/disc is facing -z.
There's also a macro called "Orient" or something within the
POV-Shipped-Includes, but I'm the self-made guy, so I can't help you much
with that...
Tim
"Tim Nikias v2.0"
Date: 5 Nov 2004 15:58:25
Message: <418be971@news.povray.org>
> anyone help?
  Look at the documentation about transforms.inc in the POV-Ray
documentation.
Date: 5 Nov 2004 17:00:00
Message: <web.418bf7b6c5347800b78c017a0@news.povray.org>
Thank you.  That has solved my problem nicely.
 Leo
 Leo Bleicher
