POV-Ray : Newsgroups : povray.general : Re: POV-Ray & Databases Server Time
6 May 2026 12:38:06 EDT (-0400)
  Re: POV-Ray & Databases (Message 1 to 1 of 1)
Subject: Re: POV-Ray & Databases
Date: 4 Nov 2004 20:20:01
Message: <web.418ad308e4dee74da3009e2a0@news.povray.org>
Here is a working example (2 files).
It needs wxBasic
http://wxbasic.sourceforge.net/bleed.php
Run it with
wxbasic povexec.wxb
(Linux: ./wxbasic povexec.wxb)
I just tested it on Linux, it should work on Windows as well.
povexec.wxb
#!/usr/bin/wxbasic
//-- start povray without blocking this one --
// on Windows98, try to replace "wxExecute" with "Shell",
// if wxExecute blocks this program
 wxExecute("povray povexec.pov")
 Dim frame = new wxframe( nothing, -1,"PoV-exec",
                      wxPoint(1,1),wxSize(-1,-1))
 dim vsizer = new wxBoxSizer( wxVERTICAL)
 dim button=new wxButton(frame, -1, "exit")
 connect(button,wxEVT_COMMAND_BUTTON_CLICKED,"onQuit")
 vsizer.AddWindow(button,1,wxEXPAND)
 timer = new wxTimer( frame )
 timer.Start( 250 )
 Connect( frame, -1, wxEVT_TIMER, "myProcess" )
 frame.SetSizer( vsizer  )
 frame.Show( 1 )
sub myProcess( event )
  if wxFileExists("povexec.txt") then
   handle = fOpen("povexec.txt" , "r" )
    buffer= fGets( handle )
   fclose( handle )
   timer.Stop()
   wxExecute(buffer)
   wxMessagebox("Your program should have started now... exiting...")
   end // quit program after Execution of Pov-Generated Command
  end if
end sub
Sub onQuit( event )
   end
End Sub
povexec.pov
#fopen MyFile "povexec.txt" write
// windows:
//#write(MyFile,"notepad.exe")
// linux:
#write(MyFile,"kedit")
#fclose MyFile
