POV-Ray : Newsgroups : povray.general : Why doesn't PovRay support Obj files? Server Time
6 May 2026 12:41:51 EDT (-0400)
  Why doesn't PovRay support Obj files? (Message 1 to 6 of 6)
Subject: Why doesn't PovRay support Obj files?
Date: 31 Oct 2004 13:40:00
Message: <web.4185306d883f573b174727610@news.povray.org>
I was wondering. Why doesn't PovRay support .obj files (to import in the
scenes), I am actually not certain if it really doesn't. But currently when
I make a 3D model that requires a modeller and when I try saving it as
..pov, I see how big the file becomes as compared to .obj. Since the .pov
are text-based this will naturally be always bigger. It is indeed efficient
if I can work with a more compressed file (as I will usually not need to
alter the object within povray, at most I will put a texture but this does
not require me to edit the output obj file). So how is this question
answered? "Why doesn't PovRay support Obj file, or any other compressed
form of graphic model?"
Sincerely,
Jose Capco
Subject: Re: Why doesn't PovRay support Obj files?
Date: 31 Oct 2004 13:55:02
Message: <cm3ccc$mgr$1@chho.imagico.de>
ShiJie wrote:
> Hi,
.obj files are text format as well - they will not be significantly
smaller than a mesh2.  If the files your modeller generates are much
larger the program is simply inefficient.  Concerning why POV-Ray does
not support any binary geometry files read:
http://tag.povray.org/povQandT/filesQandT.html#binarymeshdata
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 31 Oct 2004 15:00:26
Message: <Xns9593D5B2BBCEseed7@news.povray.org>
If the exported mesh's are the same, yes, but there are programs that
export different things when they export to .pov or .obj Exports to pov
are always triangle mesh's exports to obj can often be polygon mesh'. It
is not nessesceraly so that the mesh's are tesselated.
An other cause can be that when exporting from for example Silo, the pov
export is the subdivided and tesselated mesh and the obj export is always
the unsubdivided untesselated mesh.
Ingo
Date: 31 Oct 2004 16:23:32
Message: <418557d4$1@news.povray.org>
The .obj file format is not restricted to polygons, it allows e.g. NURBS
as well. However, I think that most programs that allow importing .obj
files expect triangles or polygons. Other .obj files may be a lot
smaller, but less portable.
Date: 2 Nov 2004 09:55:00
Message: <web.41879ec66b7bd3e8174727610@news.povray.org>
> Christoph
So, how am I going to put in some .obj file that someone gives me (or that I
made) into a PovRay scene? Should I be converting them? (Crossroad does the
job? or is there a better option?).
Sincerely,
Jose Capco
Date: 2 Nov 2004 11:05:02
Message: <cm8b24$716$1@chho.imagico.de>
There are various programs that do such a conversion (and maybe it would
be possible to do this with a sed oneliner as well).  Quite commonly
used and very flexible is Poseray:
http://user.txcyber.com/~sgalls/
(which runs fine in Wine in case you are using Linux).
