POV-Ray : Newsgroups : povray.general : Strange shadow lines (Bug?) Server Time
6 May 2026 16:51:42 EDT (-0400)
  Strange shadow lines (Bug?) (Message 1 to 2 of 2)
Subject: Strange shadow lines (Bug?)
Date: 1 Sep 2004 13:20:00
Message: <web.41360476d5f46917a3fcf12a0@news.povray.org>
I am having strange shadows appear on my image that I can't explain, and
that seem to change and/or disappear under different conditions, as I will
explain in more detail below. First, here is the entire image, so you can
see the problem:
http://www.hentschels.com:8000/~pictures/cgi-bin/album/index.cgi?file=/2004/08August/DansBlocks/block.jpg
The shadows in question are on the blue and yellow balloons in the top
block. The same thing can also be seen in this other image from a different
perspective:
http://www.hentschels.com:8000/~pictures/cgi-bin/album/index.cgi?file=/2004/04April/Blocks/block_04-03-04.jpg
I have simplified my scene significantly to try and isolate the problem, and
I have included the "simplified" code at teh bottom of this message. I put
simplified in quotes because it's still a long file. Sorry. I tried to
remove more, but it has a drastic effect on the shadow that I am trying to
isolate. For example, if I remove the glass_walls, the shadow looks
perfect. If I remove the red balloon, the shadow changes and the defect is
not very noticeable. Same thing if I remove the balloon strings. Ditto with
removing the mirror. All of these objects seem like they are not related to
the shadows in question, but removal of them has a large impact.
Even more puzzling is this: If I render only the portion of the image where
the defect occurs, then the shadow looks correct. If I add "+sc0.397997
+sr0.130217 +ec0.545682 +er0.237062" to the command line and then
re-render, then everything looks as it should. I would not expect that
rendering a section of the image would produce different results than
redering of the entire image, but it does.
I have run the file on three computers, all using either v3.5 or 3.6 for
Windows:
1) AMD Athlon 1700+, 768 MB RAM, Windows XP Pro
2) Intel Celeron 2.6 GHz laptop, 384 MB RAM, Windows XP Home
3) Intel P4 3.2 GHz, 512 MB RAM, Windows XP Pro
The defect is easily visible when rendered at 800x600 and above.
Anti-aliasing doesn't seem to have any impact. Neither does max_trace_level
(I thought it might be an internal-reflections thing).
Is there something else I should try here? Any recommendations? Should I
submit this to the bug group? Please reply to either the e-mail address
provided below, or to the newsgroup. Do not reply to the "dannyb" address
as I might not notice your message among the SPAM. Thanks.
 - dan B hentschel
page-dan( **at!** )hentschels.com
"Simplified" code:
#include "glass.inc"
#include "metals.inc"
#include "math.inc"
#declare block_plastic =
finish { specular 1 roughness 0.002 brilliance 0.5 ambient 0.25 diffuse 0.35
#declare block_lavendar = color rgb <146/255, 131/255, 190/255>;
#declare block_lime = color rgb <130/255, 184/255, 90/255>;
#declare block_yellow = color rgb <249/255, 209/255, 75/255>;
#declare block_red = color rgb <176/255, 42/255, 43/255>;
#declare block_blue = color rgb <47/255, 159/255, 223/255>;
  location  <4.5, 5.5, -7>
  look_at   <0.5, 2.5,  0>
light_source {
  0*x
  color rgb <0.5,0.5,0.5>
  translate <0, 12, -35>
light_source {
  0*x
  color rgb <0.92,0.9,0.85>
  translate <10, 50, -16>
light_source {
  0*x
  color rgb <0.85,0.82,0.8>
  translate <14, 50, -20>
light_source {
  0*x
  color rgb <0.97,0.93,0.9>
  translate <12, 50, -18>
// MIRROR
merge {
    box {
        <-2, 0, 0>
        <4, 6, 0.01>
            finish {
                specular 0.2
                roughness 0.02
                ambient 0
                diffuse 0.01
                reflection {
                    0.08, 0.6
                    fresnel on
                conserve_energy
            pigment { Clear }
        interior {
            ior 1.7
            fade_distance 1.0
            fade_power 2
    box {
        <-3, 0, 0.0099>
        <4, 6, 0.011>
            pigment { White }
            finish {
                specular 0
                roughness 0.001
                ambient 0
                diffuse 0
                reflection 1
    translate <0, 0.0, 6.88>
#declare box_size = 1.0;
#declare wall_thickness = 0.03*box_size;
#declare corner_width = 0.3*box_size;
#declare small_corner_width = 0.1*box_size;
#declare cap_height = 3*(corner_width - small_corner_width)/2;
#declare glass_height = box_size - cap_height - small_corner_width;
#declare cylinder_size = 0.8*box_size;
#declare round_corner_box =
intersection {
    merge {
        // Front left corner
        cylinder {
          <-box_size + corner_width, -2*box_size, -box_size + corner_width>
          <-box_size + corner_width, 2*box_size, -box_size + corner_width>
          corner_width
        // Front right corner
        cylinder {
          <box_size - corner_width, -2*box_size, -box_size + corner_width>
          <box_size - corner_width, 2*box_size, -box_size + corner_width>
          corner_width
        // Back left corner
        cylinder {
          <-box_size + corner_width, -2*box_size, box_size - corner_width>
          <-box_size + corner_width, 2*box_size, box_size - corner_width>
          corner_width
        // Back right corner
        cylinder {
          <box_size - corner_width, -2*box_size, box_size - corner_width>
          <box_size - corner_width, 2*box_size, box_size - corner_width>
          corner_width
        box {
          <-box_size + corner_width, -2*box_size, -box_size>
          <box_size - corner_width, 2*box_size,  box_size>
        box {
          <-box_size, -2*box_size, -box_size + corner_width>
          <box_size, 2*box_size,  box_size - corner_width>
    box {
        <-box_size-0.001, -box_size, -box_size-0.001>
        <box_size+0.001, box_size, box_size+0.001>
#declare glass_walls =
difference {
    object {
        round_corner_box
        scale y*(glass_height/box_size)
    object {
        round_corner_box
        scale <(box_size-wall_thickness)/box_size, 2,
(box_size-wall_thickness)/box_size>
        finish {
            specular 1
            roughness 0.02
            ambient 0
            diffuse 0.1
            reflection {
                0.08, 0.6
                fresnel on
            conserve_energy
        pigment { Clear }
    interior {
        ior 1.7
        fade_distance 1.0
        fade_power 2
#declare block_cover_base =
object {
    round_corner_box
    scale <1, (cap_height/6)/box_size, 1>
    translate y*(cap_height/6)
#declare block_cover_lower_corner =
union {
    // Left side
    cylinder {
        <-box_size + small_corner_width, cap_height/3, -box_size +
corner_width>
        <-box_size + small_corner_width, cap_height/3, box_size -
corner_width>
        small_corner_width
    // Right side
    cylinder {
        <box_size - small_corner_width, cap_height/3, -box_size +
corner_width>
        <box_size - small_corner_width, cap_height/3, box_size -
corner_width>
        small_corner_width
    // Front
    cylinder {
        <-box_size + corner_width, cap_height/3, -box_size +
small_corner_width>
        <box_size - corner_width, cap_height/3, -box_size +
small_corner_width>
        small_corner_width
    //Back
    cylinder {
        <-box_size + corner_width, cap_height/3, box_size -
small_corner_width>
        <box_size - corner_width, cap_height/3, box_size -
small_corner_width>
        small_corner_width
    union {
        torus {
            corner_width - small_corner_width,
            small_corner_width
            translate <-box_size + corner_width, cap_height/3, -box_size +
corner_width>
        cylinder {
            <-box_size + corner_width, cap_height/3-small_corner_width,
            <-box_size + corner_width, cap_height/3+small_corner_width,
            corner_width-small_corner_width
    union {
        torus {
            small_corner_width
            translate <box_size - corner_width, cap_height/3, -box_size +
corner_width>
        cylinder {
            <box_size - corner_width, cap_height/3-small_corner_width,
            <box_size - corner_width, cap_height/3+small_corner_width,
    // Back left corner
    union {
        torus {
            small_corner_width
            translate <-box_size + corner_width, cap_height/3, box_size -
corner_width>
        cylinder {
    union {
        torus {
            small_corner_width
            translate <box_size - corner_width, cap_height/3, box_size -
corner_width>
        cylinder {
#declare block_cover_slant_walls =
difference {
    union {
        cone {
            <-box_size + small_corner_width*(1-sind(45)) +
corner_width-small_corner_width*(1-sind(45)), cap_height/3 +
small_corner_width*sind(45), -box_size + small_corner_width*(1-sind(45)) +
corner_width-small_corner_width*(1-sind(45))>,
corner_width-small_corner_width*(1-sind(45)), cap_height +
small_corner_width-small_corner_width*(1-sind(45))
        cone {
            <box_size - small_corner_width*(1-sind(45)) -
corner_width+small_corner_width*(1-sind(45)), cap_height/3 +
corner_width+small_corner_width*(1-sind(45)), cap_height +
        // Back left corner
        cone {
small_corner_width*sind(45), box_size - small_corner_width*(1-sind(45)) -
corner_width+small_corner_width*(1-sind(45))>,
        cone {
        // Left
        box {
            <-sqrt(2)*cap_height/3, -box_size, -box_size + corner_width>
            <sqrt(2)*cap_height/3, wall_thickness/2, box_size -
corner_width>
            rotate z*45
            translate <-box_size + small_corner_width*(1-sind(45)) +
cap_height/3 + wall_thickness*sind(45)/2, 2*cap_height/3 +
small_corner_width*sind(45) - wall_thickness*sind(45)/2, 0>
        // Right
        box {
corner_width>
            rotate z*-45
            translate <box_size - small_corner_width*(1-sind(45)) -
cap_height/3 - wall_thickness*sind(45)/2, 2*cap_height/3 +
        // Front
        box {
            <-box_size + corner_width, -box_size, -sqrt(2)*cap_height/3>
            <box_size - corner_width, wall_thickness/2,
            rotate x*-45
            translate <0, 2*cap_height/3 + small_corner_width*sind(45) -
wall_thickness*sind(45)/2, -box_size + small_corner_width*(1-sind(45)) +
cap_height/3 + wall_thickness*sind(45)/2>
        // Back
        box {
            rotate x*45
wall_thickness*sind(45)/2, box_size - small_corner_width*(1-sind(45)) -
cap_height/3 - wall_thickness*sind(45)/2>
    box {
        <-box_size, -box_size, -box_size>
        <box_size, cap_height/3-0.001, box_size>
#declare block_cover_upper_corner =
union {
    // Left side
    cylinder {
        <-box_size + 2*cap_height/3 + small_corner_width, cap_height,
-box_size + 2*cap_height/3 + small_corner_width>
box_size - 2*cap_height/3 - small_corner_width>
        small_corner_width
    // Left side
    cylinder {
        <box_size - 2*cap_height/3 - small_corner_width, cap_height,
        small_corner_width
    // Front
    cylinder {
        small_corner_width
    //Back
    cylinder {
        small_corner_width
    sphere {
        small_corner_width
    sphere {
        small_corner_width
    // Back left corner
    sphere {
        small_corner_width
    sphere {
        small_corner_width
    // Top
    box {
        <box_size - 2*cap_height/3 - small_corner_width, cap_height +
small_corner_width, box_size - 2*cap_height/3 - small_corner_width>
        <-box_size + 2*cap_height/3 + small_corner_width, 0.001, -box_size +
#declare block_cover =
union {
    object { block_cover_base }
    object { block_cover_lower_corner }
    object { block_cover_slant_walls }
    object { block_cover_upper_corner }
#declare rough_block_cover =
difference {
    box {
        <-box_size, 0, -box_size>
        <box_size, cap_height+small_corner_width, box_size>
    box {
        <-box_size*2, 0, 0>
        <box_size*2, box_size, box_size>
        rotate x*-45
        translate z*(-box_size-cap_height/3)
        rotate y*0
    box {
        <-box_size*2, 0, 0>
        rotate x*-45
        rotate y*90
    box {
        <-box_size*2, 0, 0>
        rotate x*-45
        rotate y*180
    box {
        <-box_size*2, 0, 0>
        rotate x*-45
        rotate y*-90
 *       BALLOON BLOCK
#declare balloon_block_top =
difference {
    object { block_cover }
    intersection {
        object {
            round_corner_box
            scale <0.99, 2, 0.99>
            translate y*-box_size
        union {
            object {
                rough_block_cover
                scale <1-2*wall_thickness, 1.0, 1-2*wall_thickness>
                translate y*-0.001
            object {
                rough_block_cover
                translate y*0.001
    translate y*glass_height
        pigment { block_lavendar }
        finish { block_plastic }
#declare balloon_block_top_window =
intersection {
    difference {
        object {
            rough_block_cover
        object {
            rough_block_cover
            scale <1-4*wall_thickness, 1-wall_thickness, 1-4*wall_thickness>
            translate y*-0.001
    object {
        round_corner_box
        finish {
            specular 0.9
            roughness 0.02
            ambient 0
            diffuse 0
            reflection {
                0.08, 0.6
                fresnel on
            conserve_energy
        pigment { Clear }
    interior {
        ior 1.7
        fade_distance 1.0
        fade_power 2
#declare balloon_size = 0.35;
#declare balloon_block_balloon =
union {
    intersection
        sphere {
            <0, 0, 0>
            balloon_size
        box {
            <-balloon_size-0.001, -0.001, -balloon_size-0.001>
            <balloon_size+0.001, balloon_size+0.001, balloon_size+0.001>
    intersection
        sphere {
            <0, 0, 0>
            balloon_size
        box {
            <-balloon_size-0.001, -balloon_size-0.001, -balloon_size-0.001>
            <balloon_size+0.001, 0.001, balloon_size+0.001>
        scale y*1.5
    cone {
        <0, -balloon_size*1.5-0.1, 0>, 0.12
        <0, -balloon_size*1.5+0.1, 0>, 0.06
#declare balloon_block_string =
cylinder {
    <0, 0, 0>
    <0, -1, 0>
    0.01
    texture { T_Chrome_3E }
#declare balloon_block =
union {
    object { glass_walls }
    object { balloon_block_top }
    object { balloon_block_top_window }
    union {
        object { balloon_block_string }
        object {
                pigment { block_yellow }
        rotate x*-20
        translate <0, 0.3, -0.4>
    union {
        object {
                pigment { block_red }
        rotate x*-20
        rotate y*135
        translate <-0.4, 0.3, 0.4>
    union {
        object {
                pigment { block_blue }
        rotate x*-20
        rotate y*-135
        translate <0.4, 0.3, 0.4>
object {
    balloon_block
    translate <0, box_size*5, 0>
Subject: Re: Strange shadow lines (Bug?)
Date: 1 Sep 2004 20:46:49
Message: <41366d79@news.povray.org>
news:web.41360476d5f46917a3fcf12a0@news.povray.org...
> see the problem:
There's indeed something weird. Apparently, turning off the light buffers
fixes it (-UL) but it still looks like a bug.
Here's a much simplified version that shows the problem. It's apparent when
you compare the full render with the partial render +sc0.358121 +sr0.026110
+ec0.532290 +er0.258486
The shadow on the sphere is truncated on the full render and correct in the
partial one. The incomplete shadows cause the banding you see on your other
images.
Perhaps you can try to simplify it even more to see if it wouldn't be caused
by a coincident surfaces problem. If nobody comes up with an explanation,
you may file a bug report (see the guidelines).
//global_settings{max_trace_level 100}
camera {location  <4.5, 5.5, -7> look_at <0.5, 2.5,  0>}
light_source {<10, 50, -16>  color 2}
box {<-2, 0, 5>,<4, 6, 5.01> texture {finish {reflection 1}}}
#declare D =difference {
    box {<-1, 0, -1>,<1, 0.6, 1>}
    box {<-2, 0, 0>,<2, 1, 1> rotate x*-45 translate -z}
union {
    cylinder {<-0.7, -2, 0.7>,<-0.7, 2, 0.7>,0.3 pigment {Clear}}
    box {<-2, 0, 0>,<2, 1, 1> rotate x*-45 translate -z translate y*0.6
pigment {Clear}}
    difference {
        cylinder {<0.7, 0.3,-0.7>,<-0.7, 0.3,-0.7>,0.1}
        intersection {
            union {
                cylinder {<0.7, -3, -0.7>,<0.7, 1, -0.7>,0.3}
                cylinder {<-0.7, -3, 0.7>,<-0.7, 1, 0.7>,0.3}
            union {
                object {D translate y*-0.001}
                object {D translate y*0.001}
        translate y*0.6
    sphere {<0, 0.3, -0.4>, 0.35}
    sphere {<-0.4, 0.3, 0.4>, 0.35}
    texture {pigment {Yellow}}
    translate y*5
G.
http://www.oyonale.com
- Graphic experiments
- Posters
