POV-Ray : Newsgroups : povray.general : Can use TWO image_map on ONE heigh_field? Server Time
21 Jul 2025 04:05:11 EDT (-0400)
  Can use TWO image_map on ONE heigh_field? (Message 1 to 5 of 5)
Subject: Can use TWO image_map on ONE heigh_field?
Date: 14 Apr 2004 13:30:00
Message: <web.407d73dd1e4177bdaf9f3afa0@news.povray.org>
I try to use two image_map on the heigh_field.
But the result always show the later one.
Here is the simplified scene:
height_field {jpeg "mount.jpg" smooth
pigment {image_map{jpeg "mount_green.jpg"}}
pigment {image_map{jpeg "road.jpg"}}
finish  {ambient 0.1 diffuse 0.9 phong 0.5}
I also try to use pigment_map. But the result
is not change. It always only show the later one
(road.jpg) on the heigh_field.
Is there any mistake in the syntax?
How can I do to show both of them?
Thanks all,
Shiann-Jong
Subject: Re: Can use TWO image_map on ONE heigh_field?
Date: 14 Apr 2004 14:42:17
Message: <Khme2DAb2XfAFwwa@econym.demon.co.uk>
Wasn't it jong who wrote:
>Hi,
1. You can't layer just the pigments, you can only layer complete
textures.
2. When you layer textures, the last one needs to have some sort of
transparency (filter or transmit) otherwise you can't see through it to
the underlying layer.
   texture {pigment {image_map{jpeg "mount_green.jpg"}}}
     pigment {image_map{jpeg "road.jpg" transmit all 0.75}}
Mike Williams
Gentleman of Leisure
Date: 14 Apr 2004 16:01:32
Message: <407D9847.6070407@hotmail.com>
jong wrote:
> Hi,
> I try to use two image_map on the heigh_field.>
Do not worry, Shiann-Jong. There is a way to average two images together
for use in a height_field. Unfortunately each image must be in 24-bit
color or 8-bit grayscale. 16-bit grayscale images will *not* work with
this method.
Here's some code which I just tested:
height_field{
  function 200,200{
   pigment{
    average
    pigment_map{
     [1
      image_map{tga"image_1.tga"
      interpolate 2}
     [1
      image_map{
      jpeg"image_2.jpg" interpolate 2
Look for 'average' in the POV-Ray documentation to learn how to control
the average pattern and its pigment_map.
-Samuel Benge
Date: 14 Apr 2004 21:29:30
Message: <407de57a$1@news.povray.org>
jong nous apporta ses lumieres ainsi en ce 2004/04/14 13:26... :
>Hi,
>Thanks all,
>Shiann-Jong
OK you have the hight_map and want to apply both images to it.
Have the second image be a 4 chanels PNG or TGA (RedGreenBlueAlpha). The
alpha chanel can make the image transparent where you want the
underlaying image to be seen.
Your third sample line will then read as: pigment{image_map{png "road.png"}}
This should work on any type of object, not just height_fields.
POVRay, Gimp, Paintshop can produce 4 chanels PNGs and TGAs. Others can
surely do the same.
Date: 15 Apr 2004 07:25:00
Message: <web.407e70da94e902359735c0c0@news.povray.org>
"jong" <sjl### [at] earthsinicaedutw> wrote:
> Hi,
I'd probably use a pigment_pattern{} block. If you can produce an image that
is white where you want the road and black elsewhere (call it something
like 'road_binary.jpg') then this might work:-
height_field {
    pigment_pattern{image_map{jpeg "road_binary.jpg"}}
    pigment_map{
      [0.5 image_map{jpeg "mount_green.jpg"}]
      [0.5 image_map{jpeg "road.jpg"}]
> Thanks all,
> Shiann-Jong
Bye for now,
Mike Andrews.
