POV-Ray : Newsgroups : povray.general : Image Extrusion Question Server Time
26 Jul 2025 23:19:09 EDT (-0400)
  Image Extrusion Question (Message 1 to 3 of 3)
Subject: Image Extrusion Question
Date: 29 Oct 2003 00:45:01
Message: <web.3f9f529736b6a6bb3c1dcda40@news.povray.org>
Easier question:
I have a black and white image, say for instance, a white circle on a black
background.  Is there a simple way to create an object by extruding the
white circle (lying in, say, the xy plane) some distance along the z-axis?
This would, of course, create a cylinder along the z-axis.  In other words,
how can I extrude portions of a b&w imagemap?
Harder question:
Say I change my 2-bit imagemap into a 16-bit grayscale imagemap.  Can I now
extrude my image in the z-direction... only associate a transparency with
each pixel value?  Black might be completely transparent, while white would
be totally opaque, etc.
Something tells me this should be simple, what with all the nifty patterns
and functions... but my little mind can't seem to get it to work right.
Heightfields don't quite do it for me (at least in the second case) since I
need the entire image to be extruded to the same height, varying only
transparency.  Stacking a myriad of images on top of each other started out
as a Good Idea (tm), until I ran into problems with max_trace_level (which
should have been obvious at the start).
Any ideas?
Subject: Re: Image Extrusion Question
Date: 29 Oct 2003 00:59:40
Message: <cjameshuff-FDB4E2.00574429102003@netplex.aussie.org>
In article <web.3f9f529736b6a6bb3c1dcda40@news.povray.org>,
A start would be a height field. This is far from ideal, however...the
sides of the cone will be vertical surfaces of the height field, and
there will be severe tessellation artifacts. Alternatively, you could
use the image as input as the function for an isosurface...use the image
in an image_pattern image function, and use interpolation. (Isosurfaces
don't handle the infinite gradients between non-interpolated pixels very
well.)
I think what you're really looking for here can be had by using the
image_map as the density for scattering media in a box.
http://tag.povray.org/
Date: 29 Oct 2003 02:25:19
Message: <Xns942355AC23003seed7@netplex.aussie.org>
> black background.  Is there a simple way to create an object by
> extruding the white circle (lying in, say, the xy plane) some
Beside the options Chris already gave you, you could open your image in
The Gimp, use select by color to create a path, convert the path to
something POV-Ray understands and use it in a prism. See:
http://members.home.nl/seedseven/#gimpov
Ingo
