POV-Ray : Newsgroups : povray.general : Image map filenames with extended ASCII characters (PoseRay development) Server Time
27 Jul 2025 14:02:05 EDT (-0400)
  Image map filenames with extended ASCII characters (PoseRay development) (Message 1 to 10 of 22)
Subject: Image map filenames with extended ASCII characters (PoseRay development)
Date: 24 Jul 2003 19:20:01
Message: <web.3f20691cb57395e4e385dc2c0@news.povray.org>
Hello,
This is the last thing that I would like to fix for the next release of
PoseRay (v3.0.1) that hopefully should be during the weekend.
I am using POV-Ray 3.5 in Windows 98 (English language). I was trying to
render a model that used image maps with accents. For example one of the
indicates that it cannot load the image map. If I change the accented
character in the file and the POV-Ray code then it works properly.
I set up the charset to utf8 but that did not help. I know that POV-Ray only
recognizes the lower 128 ASCII characters. Is there a way around this with
filenames? I also tried to use the unicode equivalents in the filename as
"Suba arri\u00E9re.jpg" but that did not work either.
I could make an option to copy/rename the maps without accents and rename
the map names in each material but it would be nicer if POV-Ray could read
these files without modification.
thanks for any info or suggestions,
FlyerX
Subject: Re: Image map filenames with extended ASCII characters (PoseRay development)
Date: 25 Jul 2003 10:12:28
Message: <3f213acc$1@news.povray.org>
In article <web.3f20691cb57395e4e385dc2c0@news.povray.org> , "flyer_2000"
You cannot load files with names outside the ASCII character range.  Unicode
is supported for text, not filenames.  There is no workaround in a portable
program like POV-Ray.  You have to rename your files.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Subject: Re: Image map filenames with extended ASCII characters (PoseRaydevelopment)
Date: 25 Jul 2003 10:16:58
Message: <3f213bda@news.povray.org>
Shouldn't unicode be portable?  I know *NIX supports unicode, thus so
would OSX, and Win2k+ supports it, therefore there is no reason to say
unicode isn't portable.
Tim Cook
Version: 3.12
Date: 25 Jul 2003 10:53:39
Message: <3f214473@news.povray.org>
Unicode implementations are still kind of tricky under many platforms, and
not compiled-in by default on lots of others. Not to mention that Unicode is
not generally used for filenames on *NIX (AFAIK), only for text and
interfaces.
Date: 25 Jul 2003 14:53:40
Message: <3f217cb4$1@news.povray.org>
> interfaces.
*sniffle*  But Unicode is the best thing since sliced bread! T_T
Sucks that a lot of Windows software doesn't support it yet...
Tim Cook
Version: 3.12
Date: 25 Jul 2003 15:17:15
Message: <3f21823b$1@news.povray.org>
In article <3f213bda@news.povray.org> , Tim Cook <z99### [at] bellsouthnet>
It has nothing to do with Unicode.  It has to do with the filesystem and how
it is accessed.  there is no portable way to access files with Unicode names
because you cannot pass Unicode strings.  That is all.
    Thorsten
e-mail: tho### [at] trfde
Subject: Re: Image map filenames with extended ASCII characters(PoseRaydevelopment)
Date: 25 Jul 2003 17:26:38
Message: <MPG.198b4d77e17bd15e989842@news.povray.org>
In article <3f21823b$1@news.povray.org>, tho### [at] trfde says...
>     Thorsten
I doubt this is a unicode file name. File systems don't use it. In fact
the file name is likely using a perfectly valid OEM file name, which
allows for anything from character 32 to 255, with the exception of a few
like ',', '*', '?', etc. The problem is, using the usual complete lack of
common sense, MS decided that the file system itself should 'allow'
characters beyond 127, but that some standard methods for opening,
closing, etc. the same files should only use the main ASCII range.
Obviously POV-Ray falls pray to this same stupidity by either enforcing a
nonexistent restriction or by calling the file handler in a way that
results in it rejecting perfectly valid names. This is ironically a left
over for the days of DOS, when only programs the bypassed the standard
DOS access methods could save or read such a file.
In any case, if POV-Ray won't read them, then it is because it is not
asking the file system to use the name properly, not because the name is
invalid. And it literally "can't" be a unicode name, since he obviously
are NULL + Letter and you can't 'ever' have a NULL value in a file name.
Something is going wrong here, but it is not the fault of the underlying
filesystem, though it might be something in between the two.
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 25 Jul 2003 17:33:36
Message: <3f21a230$1@news.povray.org>
I'm with you, but any such process takes time. Let's hope it doesn't require
as much time as IPv6... :-)
Date: 25 Jul 2003 17:35:31
Message: <3f21a2a3$1@news.povray.org>
> void main () {
>   else
I love your .sig. Is it the source code for "Windows for quantic computers"?
:-D
Date: 25 Jul 2003 17:54:02
Message: <3f21a6fa$1@news.povray.org>
In article <MPG.198b4d77e17bd15e989842@news.povray.org> , Patrick Elliott
Obviously you have no clue what you are talking about.  You either don't
seem to even have read this thread or you don't know what "portable" means.
It has nothing to do with Mircosoft.  It has nothing to do with "POV-Ray
fall[ing] pray to this same stupidity" because this, too, has absolutely
nothing to do with not making Unicode filenames possible.  Your whole
response is just completely on the wrong track and has absolutely nothing to
do with anything discussed in this thread.  Sorry!
    Thorsten
