POV-Ray : Newsgroups : povray.general : Bug with noise generator Server Time
27 Jul 2025 16:33:45 EDT (-0400)
  Bug with noise generator (Message 1 to 3 of 3)
Subject: Bug with noise generator
Date: 27 Jun 2003 17:50:02
Message: <web.3efcbb174718e7c3d0082e520@news.povray.org>
I think I found a couple of bugs with the noise generator.
I downloaded the source code for POV-Ray 3.5 for windows, to see how noise
is generated. When reviewing the source, I saw the following:
In the POV-Ray Core project,
in the file "Texture.cpp",
in the function "static void InitSolidNoise (void)",
there is a section of code designed to generate random gradient vectors,
which are  uniformly distributed on the unit sphere. There are 2 bugs with
that:
1. There is a loop there, with a condition that is supposed to "trash" any
random vector which is outside the sphere. The condition should be OR, not
AND:
The code for each random vector generation looks something like that:
   do {
      Find a random vector in the unit cube.
      s = the length of the vector, squared.
   } while ((s > 1.0) && (s < 1.0e-5));
   Normalize the vector;
The condition is a contradiction, and should have been:
   "while ((s > 1.0) || (s < 1.0e-05))"
This bug causes the vectors to be non-uniformly distributed on the sphere.
2. In general, this technique will not produce uniform distribution of
vectors even when the bug is fixed (because the random values are actually
a discrete set of values), but I guess some compromises are tolerable, and
probably invisible (Who can tell that the noise is not exactly uniform?...)
Zohar Leder,
zoh### [at] yahoocom
Subject: Re: Bug with noise generator
Date: 28 Jun 2003 03:38:46
Message: <3efd4605@news.povray.org>
You'd better post this to povray.programming.
I'm including a full-quote here so that the complete message appears on
p.programming.
Zohar wrote:
> Hi,
> that:
> AND:
>    do {
ACK.
> uniform?...)
> Zohar Leder,
Date: 28 Jun 2003 04:02:09
Message: <3efd4b81@news.povray.org>
In article <web.3efcbb174718e7c3d0082e520@news.povray.org> , "Zohar"
<zoh### [at] yahoocom> wrote:
>    do {
Indeed, the current code does not make sense.  This is a bug.
    Thorsten
e-mail: tho### [at] trfde
