POV-Ray : Newsgroups : povray.general : CSG mesh bug Server Time
12 Sep 2025 05:06:51 EDT (-0400)
  CSG mesh bug (Message 1 to 7 of 7)
Subject: CSG mesh bug
Date: 27 Mar 2003 02:10:09
Message: <web.3e82a371ff88dac376ced8e90@news.povray.org>
The same results with difference or intersection of two meshes.
Please, see next simple sample
Jozef Gatial
// Persistence of Vision Ray Tracer Scene Description File
#version 3.5;
global_settings { assumed_gamma 1.0 }
camera {location <0.0, 0.5, -4.0> direction 1.5*z right
x*image_width/image_height look_at<0,0,0> }
sky_sphere { pigment { gradient y color_map { [0 rgb <0.6,0.7,1.0>] [0.7 rgb
<0.0,0.1,0.8>] } } }
light_source { <0, 0, 0> color rgb <1, 1, 1> translate <-30, 30, -30> }
plane { y, -1 pigment { color rgb <0.7,0.5,0.3> } }
#declare Object1Material1 = material {
  pigment { color rgbf <1, 1, 1, 0> }
  finish  { ambient .5 diffuse .5 }
#declare Object1Material2 = material {
  pigment { color rgbf <1, 1, 0, 0> }
#declare Object1 = mesh {
   inside_vector <0, 0, 1>
   smooth_triangle { <-1, -1, -1>, <0, 1, 0>, <1, -1, -1>, <0, 1, 0>, <1,
-1, 1>, <0, 1, 0> }
   smooth_triangle { <1, -1, 1>, <0, 1, 0>, <-1, -1, 1>, <0, 1, 0>, <-1, -1,
-1>, <0, 1, 0> }
   smooth_triangle { <-1, 1, -1>, <0, -1, 0>, <1, 1, 1>, <0, -1, 0>, <1, 1,
-1>, <0, -1, 0> }
   smooth_triangle { <1, 1, 1>, <0, -1, 0>, <-1, 1, -1>, <0, -1, 0>, <-1, 1,
1>, <0, -1, 0> }
   smooth_triangle { <-1, -1, -1>, <0, 0, 1>, <1, 1, -1>, <0, 0, 1>, <1, -1,
-1>, <0, 0, 1> }
   smooth_triangle { <1, 1, -1>, <0, 0, 1>, <-1, -1, -1>, <0, 0, 1>, <-1, 1,
-1>, <0, 0, 1> }
   smooth_triangle { <1, -1, -1>, <-1, 0, 0>, <1, 1, 1>, <-1, 0, 0>, <1, -1,
1>, <-1, 0, 0> }
   smooth_triangle { <1, 1, 1>, <-1, 0, 0>, <1, -1, -1>, <-1, 0, 0>, <1, 1,
-1>, <-1, 0, 0> }
   smooth_triangle { <1, -1, 1>, <0, 0, -1>, <-1, 1, 1>, <0, 0, -1>, <-1,
-1, 1>, <0, 0, -1> }
   smooth_triangle { <-1, 1, 1>, <0, 0, -1>, <1, -1, 1>, <0, 0, -1>, <1, 1,
1>, <0, 0, -1> }
   smooth_triangle { <-1, -1, 1>, <1, 0, 0>, <-1, 1, -1>, <1, 0, 0>, <-1,
-1, -1>, <1, 0, 0> }
   smooth_triangle { <-1, 1, -1>, <1, 0, 0>, <-1, -1, 1>, <1, 0, 0>, <-1, 1,
1>, <1, 0, 0> }
difference
//intersection
object { Object1 material { Object1Material1 } scale .5 rotate <45,45,45>
translate <-.5,0,0>}
object { Object1 material { Object1Material2 } scale .5 rotate <45,45,45>
translate <.5,0,0>}
Subject: Re: CSG mesh bug
Date: 27 Mar 2003 04:32:28
Message: <3E82C865.3040302@informatik.uni-freiburg.de>
Just as I would expect. difference {A B} does the same as
intersection {A object {B inverse}}. inverse can have no effect on
patch objects such as a mesh, because they have no inside or outside.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 27 Mar 2003 05:30:04
Message: <web.3e82d27b9c39944cf7cbce3c0@news.povray.org>
Well, closed ("well-behaving") meshes DO have a well defined interior, and
the "insideness" algorithm is rather trivial (just trace a ray from the
point in question to some direction (inside_vector), if there are an even
number of intersections, the point is outside, else inside). It can fail,
though, if the ray happens to on the exactly same plane as some of the
triangles being tested. This is what seems to be happening here. The
inside_vector should be chosen carefully to not be parallel to any of the
triangles in a mesh.
Date: 27 Mar 2003 06:15:56
Message: <3E82E0A5.6030702@informatik.uni-freiburg.de>
Oh, so that is what I don't know from never using meshes. I wonder why
inside_vector is not allowed for arbitrary objects (mostly unions of
patch primitives).
Date: 27 Mar 2003 07:00:09
Message: <web.3e82e6c39c39944c76ced8e90@news.povray.org>
Inside_vector is point defined where is interior of mesh but it is probably
not fully function (in this example only value <0, 0, 0> show differences).
Mesh and mesh2 are fully function in CSG operations when they are combined
with some other objects. Problem is only with two meshes
Jozef
#declare Object2 = sphere { <0, 0 0> 1 }
// A - ok
difference
object { Object2 material { Object1Material2 } scale .5 rotate <45,45,45>
translate <.5,0,0>}
// B - ok
difference
translate <.5,0,0>}
object { Object2 material { Object1Material1 } scale .5 rotate <45,45,45>
// A + B - error
Date: 27 Mar 2003 10:58:07
Message: <3e831f8e@news.povray.org>
This phenomenon might be related to the bug that a (solid) mesh cannot
be the second object in a CSG.
  IIRC this will be fixed in the next release.
Date: 27 Mar 2003 21:09:24
Message: <3E83AFCE.78C70FF7@pacbell.net>
I confirm that what you say is true.
Ken Tyler
