POV-Ray : Newsgroups : povray.general : cos(pi*3/2) results -0.000 Server Time
12 Sep 2025 11:42:00 EDT (-0400)
  cos(pi*3/2) results -0.000 (Message 1 to 8 of 8)
Subject: cos(pi*3/2) results -0.000
Date: 24 Jan 2003 15:15:16
Message: <web.3e319c0b7f992aa0e1b6456c0@news.povray.org>
pov-ray ver: 3.5.icl.win32
Sys. op: Win xp
cpu: pentium 4, 256 MB
If i do (i.e.) y= cos(x) where 0 < x < 2*pi and i'm testing the following:
   #if(y < 0)
      //block1...
   #else //block2...
the result when x= pi*3/2 is block1! And taking a look at its value, is
-0.00000 and is taken as negative number. By now i correct it simplyly
checking such y value:  #macro correct(num)(num<0?:num=0?0:num:num) #end
Can someone confirm if this is a bug? Thanks
(sorry, but my english is very bad)
Subject: Re: cos(pi*3/2) results -0.000
Date: 24 Jan 2003 15:27:48
Message: <3e31a1c4$1@news.povray.org>
In article <web.3e319c0b7f992aa0e1b6456c0@news.povray.org> , "Jano"
No, the behavior is perfectly correct.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 24 Jan 2003 15:43:44
Message: <3e31a57f@news.povray.org>
Entre otras cosas, Jano tuvo a bien escribir:
>    #if(y < 0)
>       //block1...
>    #else //block2...
What would you expect?
cos(0) = 1
cos(pi*1/2) = 0
cos(pi) = -1
cos(pi*3/2) = 0
Unfortunately, POV-Ray is not perfect and there are (as in most computer
programs) floatin point inaccuracies and rounding errors. That means the
result is not *exactly* 0, but slightly lower, and you see -0.000. This is
normal and expected behaviour, if you are testing against 0 you should in
turn test that abs(y) < tiny_number.
Linux User #289967 (counter.li.org)
PGP Pub Key ID: 0x01A95F99 (pgp.escomplinux.org)
Date: 24 Jan 2003 16:40:05
Message: <web.3e31b1b6939631ece1b6456c0@news.povray.org>
>cos(0) = 1
>cos(pi*1/2) = 0
>cos(pi) = -1
>cos(pi*3/2) = 0
Thak you, i'll remember it next time :)
Date: 24 Jan 2003 16:44:00
Message: <3e31b3a0$1@news.povray.org>
In article <3e31a57f@news.povray.org> , Jellby <jel### [at] M-yahoocom>
It isn't even a rounding error.  PI can never be represented exactly in any
evaluation (assuming certain properties of PI are indeed true).  So while
symbolically the result 0.0 is correct, numerically that cannot be reached.
    Thorsten
e-mail: tho### [at] trfde
Date: 24 Jan 2003 17:47:13
Message: <3e31c271$1@news.povray.org>
Sure it can.  pi = circumference/diameter
There, I just exactly represented Pi. :)
--Tim Cook
Version: 3.12
Date: 25 Jan 2003 08:39:19
Message: <3e329387$1@news.povray.org>
>> in any
...but sybolically, not numerically. The numeric representation
is left as an exercise for the student.  8)
Steve Martin, CPBE CBNT
Date: 25 Jan 2003 08:46:47
Message: <3e329547$1@news.povray.org>
any
Sure it cannot.
Could you please specify what exactly is "circumference" in your formula
(w/o just telling it's "diameter*pi")?
